V2 Add DWARF support to the rtemstoolkit and put it to use.
Cillian O'Donnell cpodonnell8 at gmail.com
Thu May 10 17:37:04 UTC 2018
On Thu, 10 May 2018, 11:48 Chris Johns, <chrisj at rtems.org> wrote:
> On 10/5/18 2:43 pm, Chris Johns wrote:
> > On 10/5/18 8:47 am, Cillian O'Donnell wrote:
> >> GDB
> >> (gdb) bt
> >> #0  0x00007ffff74aa428 in __GI_raise (sig=sig at entry=6)
> >>     at ../sysdeps/unix/sysv/linux/raise.c:54
> >> #1  0x00007ffff74ac02a in __GI_abort () at abort.c:89
> >> #2  0x00007ffff7ae484d in __gnu_cxx::__verbose_terminate_handler() ()
> >>    from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
> >> #3  0x00007ffff7ae26b6 in ?? () from
> >> #4  0x00007ffff7ae2701 in std::terminate() ()
> >> #5  0x00007ffff7ae2919 in __cxa_throw ()
> >> #6  0x000000000042ad4a in rld::dwarf::address::path[abi:cxx11]() const (
> >>     this=this at entry=0x7fffffffcc10) at
> ../rtemstoolkit/rld-dwarf.cpp:129
> >> #7  0x000000000042dfad in rld::dwarf::file::get_source (this=this at entry
> =0x6be568,
> >>     addr=<optimized out>, source_file="unknown",
> source_line=@0x7fffffffccdc: -1)
> >>     at ../rtemstoolkit/rld-dwarf.cpp:860
> >> #8  0x000000000040d541 in Coverage::ExecutableInfo::getSourceAndLine (
> >>     this=this at entry=0x6be3c0, address=<optimized out>, line="")
> >>     at ../tester/covoar/ExecutableInfo.cc:134
> >> #9  0x000000000040a115 in
> Coverage::DesiredSymbols::determineSourceLines (
> >>     this=this at entry=0xafee70, theRanges=theRanges at entry=0xd626f0,
> >>     theExecutable=0x6be3c0) at ../tester/covoar/DesiredSymbols.cc:411
> >> #10 0x000000000040a24f in
> Coverage::DesiredSymbols::findSourceForUncovered (
> >>     this=0xafee70) at ../tester/covoar/DesiredSymbols.cc:440
> >> #11 0x0000000000406028 in main (argc=<optimized out>, argv=<optimized
> out>)
> >>     at ../tester/covoar/covoar.cc:526
> > This looks like an exception being thrown in a destructor path.
> I can reproduce this on MacOS with the hello.cov file. Thank you for it.
Cool was hoping that would work for you. Quicker debugging without me as
man in the middle.
> It is not a exception in an exception or in a stack unwind path, it is an
> exception being thrown with no catch.
> The covoar `main()` is  like C with return vales, stderr prints and exits
> or
> there are calls to exit in some paths taken from main. The RLD code
> expects a
> top level single catch which prints a message to stderr then exits. It is
> mixing
> this these two approaches which resulted in no catch. I am so use to not
> needing
> to think about it. Maybe I should look at main and clean it up.
Ahhh I see, more c++ conversion for the rest of covoar, or at least the
parts called in main. That's something Vijay could do, the blueprint for
the conversion is in one of Chris last patches updating covoar.cc Any
objections to him doing it Joel, Chris?
> I also need to figure out why the address has lost it's reference to the
> source
> table.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180510/b749adf4/attachment-0002.html>
