V2 Add DWARF support to the rtemstoolkit and put it to use.
Cillian O'Donnell cpodonnell8 at gmail.com
Thu May 10 20:32:45 UTC 2018
On 10 May 2018 at 19:39, Chris Johns <chrisj at rtems.org> wrote:
> On 11/5/18 5:37 am, Cillian O'Donnell wrote:
> > On Thu, 10 May 2018, 11:48 Chris Johns, <chrisj at rtems.org
> >     It is not a exception in an exception or in a stack unwind path, it
> is an
> >     exception being thrown with no catch.
> >     The covoar `main()` is  like C with return vales, stderr prints and
> exits or
> >     there are calls to exit in some paths taken from main. The RLD code
> expects a
> >     top level single catch which prints a message to stderr then exits.
> It is mixing
> >     this these two approaches which resulted in no catch. I am so use to
> not needing
> >     to think about it. Maybe I should look at main and clean it up.
> > Ahhh I see, more c++ conversion for the rest of covoar, or at least the
> parts
> > called in main. That's something Vijay could do, the blueprint for the
> > conversion is in one of Chris last patches updating covoar.cc Any
> objections to
> > him doing it Joel, Chris?
> Thank for you the offer. The change to main is in response to my changes
> to add
> DWARF support and those changes are not yet working so I feel I have to
> make the
> change as part of this work or Vijay ends up on my broken version of
> rtems-tools
> and that is not productive.
> I also think the other listed work is better value for us and more fun for
> Vijay. :)
Fair enough :) I thought you might want to lighten your load. You're doing
all the heavy lifting.
> I have moved my changes to a personal repo to make it easier to manage:
>  https://git.rtems.org/chrisj/rtems-tools.git/?h=covoar-dwarf
> I think the git commands to use are:
>  $ git remote add chrisj git://git.rtems.org/chrisj/rtems-tools.git
>  $ git fetch chrisj
> You should then be able to see the 'covoar-dwarf' branch. I have not tested
> these commands.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180510/0072038e/attachment-0002.html>
