How to download the required tar file?
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri May 11 18:37:54 UTC 2018
On Fri, 11 May 2018, 23:59 Danxue Huang, <danxue.huang at gmail.com> wrote:
> Hey Vijay,
> Thank you so much for answering my question! Please don't feel sorry about
> that, it's great that I also got you to help me so I can figure out my
> problem faster :D
> I double checked the files in my machine, there are no such files like
> "kernel", "erc32" and "testsuites", do you know why do I miss these files?
> Or how can I get these files? Thank you!
maybe I didn't understand the current status of set up.
are you trying to run hello world ?
> Best,
> Dannie
> On Fri, May 11, 2018 at 12:57 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hello Dannie,
>> I guess you're looking for the testsuites direcotry under the build
>> directory.
>> It can be found somewhere like this
>> $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites
>> If you're looking for the c code then you can find it under the
>> RTEMS_ROOT directory.
>> In my set up the root directory is here:
>> $HOME/development/rtems/kernel/rtems/testsuites
>> You can refer to this link to understand the directory structure properly
>> https://docs.rtems.org/branches/master/develenv/directory.html
>> Hopefully it was helpful.
>> regards,
>> Vijay
>> PS: Apologies to Chris, if it was disrespectful to respond to a question
>> that was addressed to him. I certainly didn't mean any disrespect.
>> On 11 May 2018 at 22:33, Danxue Huang <danxue.huang at gmail.com> wrote:
>>> Chris,
>>> I have managed to build the tools, but I got another question about
>>> testing. I am supposed to have a "testsuites" folder in my machine from the
>>> instruction but I did not find it. So I make a "test.exe" file by myself,
>>> the output of running "test.exe" is as below.
>>> dannie at dannie-VirtualBox:~/development/rtems/4.11/sparc-rtems4.11$
>>> sparc-rtems4.11-gdb test.exe
>>> GNU gdb (GDB) 7.9
>>> Copyright (C) 2015 Free Software Foundation, Inc.
>>> License GPLv3+: GNU GPL version 3 or later <
>>> http://gnu.org/licenses/gpl.html>
>>> This is free software: you are free to change and redistribute it.
>>> There is NO WARRANTY, to the extent permitted by law.  Type "show
>>> copying"
>>> and "show warranty" for details.
>>> This GDB was configured as "--host=x86_64-linux-gnu
>>> --target=sparc-rtems4.11".
>>> Type "show configuration" for configuration details.
>>> For bug reporting instructions, please see:
>>> <http://www.gnu.org/software/gdb/bugs/>.
>>> Find the GDB manual and other documentation resources online at:
>>> <http://www.gnu.org/software/gdb/documentation/>.
>>> For help, type "help".
>>> Type "apropos word" to search for commands related to "word"...
>>> "/home/dannie/development/rtems/4.11/sparc-rtems4.11/test.exe": not in
>>> executable format: File format not recognized
>>> (gdb) tar sim
>>> Connected to the simulator.
>>> (gdb) load
>>> No executable file specified.
>>> Use the "file" or "exec-file" command.
>>> (gdb) r
>>> Starting program:
>>> warning: No executable file specified.
>>> warning: No program loaded.
>>> [Inferior 1 (process 42000) exited normally]
>>> (gdb) quit
>>> Now I think the gdb session is working, but the "test.exe" is not
>>> executable since it is coded by myself (there are bugs in it). Is there any
>>> way I can get the testing files?
>>> Thank you so much!
>>> -Dannie
>>> On Fri, May 11, 2018 at 12:07 AM, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 11/5/18 4:01 pm, Danxue Huang wrote:
>>>> > Hi there,
>>>> > I got stuck on 2.5 installing a tar file ( I have attached the
>>>> website below).
>>>> You can skip that section. It does not really belong in the Quick Start
>>>> chapter.
>>>> > https://docs.rtems.org/branches/master/rsb/quick-start.html#building
>>>> > <https://docs.rtems.org/branches/master/rsb/quick-start.html#building
>>>> > The tar file is supposed that I have downloaded in my machine, but
>>>> there is not
>>>> > a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my
>>>> files ends
>>>> > at .bz2 are as below.
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/gmp-5.0.5.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/binutils-2.26.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/rtems-tools-25863503edb513e7501481ff2074c02bf219f519.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/binutils-2.30.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/gmp-6.1.0.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/gcc-4.9.3.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/mpfr-3.0.1.tar.bz2
>>>> ./development/rtems/src/rtems-source-builder/rtems/sources/mpfr-3.1.4.tar.bz2
>>>> > Is there any other way I can download the required tar file? Thank
>>>> you!
>>>> You should not needed it.
>>>> Have you managed to build the tools?
>>>> Chris
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180512/da04dcd9/attachment-0002.html>
