How do I convert a C program to an .exe file?
Danxue Huang
danxue.huang at gmail.com
Sat May 12 21:59:01 UTC 2018
Hey Amaan,
Thank you so much for your detailed answer! I have figured it out following
the instructions. Since I read various versions of staring instructions,
files are kind of messed up in my machine, I just redo everything from the
beginning and then it works. I really appreciate your help!
Best,
Dannie
On Sat, May 12, 2018 at 1:40 AM Amaan Cheval <amaan.cheval at gmail.com> wrote:
> Hey!
> It looks like you're trying to compile the testsuite within the core
> repository itself. This isn't how it's done because the core repo
> provides the basis for specific BSP targets - for eg. how would the
> Makefile for the core repo know which cross-compiler to use, with
> which configure options you provided, etc.? This is generally called
> an in-tree build (i.e. within the source-tree itself). My
> understanding is that RTEMS does not do any in-tree builds whatsoever.
> You need an out-of-tree build (i.e. where you have "build-dir-sparc"
> and "rtems-kernel" directories as siblings, for eg.). This is
> described as a quickstart in the docs here:
> https://docs.rtems.org/branches/master/user/start/index.html
> Since you want to also build the testsuite, i.e. an ".exe", you need
> to also supply the "--enable-tests" option to the "configure" command.
> This is the procedure for the testsuite, which is what you seem to
> want. For compiling with RTEMS _in general_, for eg. with the
> examples-v2 repo:
> https://git.rtems.org/examples-v2/
> You need to use the RTEMS_MAKEFILE_PATH variable. For eg.
> make RTEMS_MAKEFILE_PATH=~/repos/rtems/b-i386/i386-rtems5/c/pc386/make
> Where b-i386 is the name of my build-directory, i386-rtems5 is the
> name of the target architecture (same as the "--target" option to the
> configure command earlier), and "pc386" is the name of the BSP (same
> as the "--enable-rtemsbsp" option in the configure command earlier).
> What I've listed above is the "developer" method. For most users, the
> RSB will be used to install both the target tools (for eg.
> i386-rtems5-gcc) _and_ the RTEMS kernel itself. See the note about
> RTEMS Releases here:
> > The RSB found in a release will automatically build and install RTEMS.
> If you do not want a released version of the RSB to build RTEMS add
> --without-rtems to the command line. The development version requires
> adding --with-rtems to build RTEMS. Use this option to create a single
> command to build the tools and RTEMS.
> > The source used in release builds is downloaded from the RTEMS FTP
> server. This ensures the source is always available for a release.
> Source:
> https://docs.rtems.org/branches/master/rsb/quick-start.html#building
> For future reference: this seems like a question more suitable for the
> rtems-users mailing list, I believe.
> Hope that helps!
> On Sat, May 12, 2018 at 9:11 AM, Danxue Huang <danxue.huang at gmail.com>
> wrote:
> > Hi there,
> > How do I convert a C program to an .exe file? I already got a
> "Makefile", I
> > tried to run "make" but it doesn't work, the output is as below. Thank
> you
> > so much for checking for me!
> > dannie at dannie-VirtualBox
> :~/development/rtems/kernel/rtems/testsuites/samples/hello$
> > make
> > Makefile:14: /Makefile.inc: No such file or directory
> > Makefile:16: /make/leaf.cfg: No such file or directory
> > make: *** No rule to make target '/make/leaf.cfg'. Stop.
> > Best,
> > Dannie
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180512/b70a9504/attachment-0002.html>
