[PATCH] covoar: fixing the extension mismatch in trace file
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun May 13 12:35:08 UTC 2018
On Sun, 13 May 2018, 17:32 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> I understand but that's a separate issue. I can do a full coverage run
> from the top of the build tree by changing hello.exe.cov to hello.cov
> manually using current master. Then I add your patch which is supposed to
> fix the problem of having to change those manually so it looks for
> hello.exe.cov instead but I can't even make it to the point of doing the
> coverage runs anymore so it must of  had some unintended consequences.
it's building fine here.
have you tried ./waf build install after the changes to covoar.cc?
can you please try the v2 of the patch, ./waf build install it and see if
it's behaving the same ?
> I know its frustrating to work on a problem for a while and you finally
> come up with the solution only to have all of us complain that it's not
> quite right but that's just collaborative development, you'll have to get
> used to it :)...
That's alright. :)
> On 13 May 2018 at 12:39, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On Sun, 13 May 2018, 17:02 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>> wrote:
>>> But you see the thing is that if you remove the changes you made and run
>>> the tester from the top of the build tree it makes it past those checks and
>>> does full coverage analysis runs for all trace files that end in only .cov.
>>> So only hello.cov here because I've changed it manually.
>> from the top of the build tree, it does work if you just manually change
>> the extension .
>> But it doesn't building from outside the directory, say from
>> coverage_test directory . The change I'm suggesting is to make it work from
>> there .
>> For that we need to take the absolute path of the lib . maybe by
>> implementing something like realpath() from rld::path will do it.
>>> warning: Unable to read coverage file:
>>> /home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/testsuites/samples/unlimited/unlimited.cov
>>> Processing multiple executable/coverage file pairs
>>> Coverage Format : html
>>> Target          : sparc-rtems5
>>> Coverage file
>>> /home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.cov
>>> for executable:
>>> /home/cpod/development/rtems/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>> Loading symbol sets:
>>> /home/cpod/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/score-symbols.ini
>>>  Symbol set: score
>>>  Loading library: sparc-rtems5/c/leon3/cpukit/score/libscore.a
>>> Analyzing 382 symbols
>>> Extracting information from:
>>> Created unified coverage map for _RTEMS_Lock_allocator (0x0 - 0x13)
>>> Created unified coverage map for _RTEMS_Unlock_allocator (0x0 - 0x13)
>>> Created unified coverage map for _API_Mutex_Lock (0x0 - 0x2f)
>>> Processing coverage file
>>> for executable
>>> Preprocess uncovered ranges and branches
>>> Computing uncovered ranges and branches
>>> Branch always taken found in _API_Mutex_Lock (0x40005f98 - 0x40005f9b)
>>> Branch always taken found in _API_Mutex_Unlock (0x40005fc0 - 0x40005fc3)
>>> Branch never taken found in _Chain_Initialize (0x4000600c - 0x4000600f)
>>> Branch always taken found in _Freechain_Get (0x40006070 - 0x40006073)
>>> Branch never taken found in _Freechain_Get (0x40006084 - 0x40006087)
>>> Branch never taken found in _Heap_Allocate_aligned_with_boundary
>>> (0x40006108 - 0x4000610b)
>>> Calculate statistics
>>> Looking up source lines for uncovered ranges and branches
>>> Looking up source lines for uncovered ranges in CSWTCH.1
>>> Looking up source lines for uncovered branches in _API_Mutex_Lock
>>> Looking up source lines for uncovered ranges in _API_Mutex_Unlock
>>> Looking up source lines for uncovered branches in _API_Mutex_Unlock
>>> Looking up source lines for uncovered branches in _Chain_Initialize
>>> Looking up source lines for uncovered ranges in _Freechain_Get
>>> Generate Reports
>>> Generate index.txt
>>> Generate annotated.txt
>>> Generate branch.txt
>>> Generate uncovered.txt
>>> Generate sizes.txt
>>> Generate symbolSummary.txt
>>> Generate index.html
>>> Generate annotated.html
>>> Generate branch.html
>>> Generate uncovered.html
>>> Generate sizes.html
>>> Generate symbolSummary.html
>>> Writing Not Found Report
>>> (/home/cpod/development/rtems/leon3/coverage/score/ExplanationsNotFound.txt)
>>> Coverage run for score finished successfully.
>>> Generating reports
>>> Coverage analysis finished. You can find results in
>>> ***Cleaning tempfiles***
>>> So there does seem to be some knock on effect of just tacking on .cov
>>> there. Can't see all the consequences immediately but I'm having a look
>>> now. I'll let you know if I find anything.
>>> On 13 May 2018 at 12:07, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> On 13 May 2018 at 16:16, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>>> > wrote:
>>>>> On Sun, 13 May 2018, 16:15 Vijay Kumar Banerjee, <
>>>>> vijaykumar9597 at gmail.com> wrote:
>>>>>> On Sun, 13 May 2018, 16:09 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> It does seem to be having some knock on effect. Covoar made it past
>>>>>>> these checks before.
>>>>>>> Total:         13
>>>>>>> Average test time: 0:00:03.178923
>>>>>>> Testing time     : 0:00:41.326000
>>>>>>> Running covoar for score
>>>>>>> covoar results directory:
>>>>>>> ERROR: executable build prefix does not match: sparc-rtems5
>>>>>>> error: covoar failure exit code: 1
>>>>>>> Not sure how thats related.
>>>>>>> Its checking
>>>>>>>  if (buildPrefix.empty())
>>>>>>>  76           buildPrefix =
>>>>>>> *pri;
>>>>>>>  77         } else
>>>>>>>  78           if (buildPrefix != *pri)
>>>>>>>  79             std::cout << "buildBSP: " + buildBSP << "\n*pri: " +
>>>>>>> *pri << std::en
>>>>>>>     dl;
>>>>>>>  80             fail = "executable build prefix does not match: " +
>>>>>>> buildPrefix;
>>>>>>>  81
>>>>>>> break;
>>>>>>>  82
>>>>>>>  83         }
>>>>>>> I added those checks, Its stepping back through the path and
>>>>>>> checking if each directory makes sense. It seems to be out of line now
>>>>>>> buildBSP: leon3
>>>>>>> *pri: sparc-rtems5
>>>>>> initially there were two problems
>>>>>> +exe.cov and .cov mismatch
>>>>>> +access library from outside the leon3 directory.
>>>>>> The patch solves the first one, that's one step .
>>>>>> The next step can be solved by adding the path to the build-target ,
>>>>>> i.e. sparc-rtems5 , from HOME directory, you can manually add it and see it
>>>>>> running for now. That tells us that inclusion of the path in more standard
>>>>>> way will solve it.
>>>>> in score-symbol.ini file
>>>> To state it clearly :
>>>> I added this to the score-symbol.ini
>>>> [score]
>>>>  libraries=/home/lunatic/development/rtems/kernel/leon3/@BUILD-TARGET@
>>>> /c/@BSP@/cpukit/score/libscore.a
>>>> and that worked .
>>>> To do it in proper way we can do it from the script by using something
>>>> like the path.abspath() and that will fix this I think.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180513/69a67976/attachment-0002.html>
