BSPs with Same Name, Different Architecture
Joel Sherrill
joel at rtems.org
Mon May 14 15:39:04 UTC 2018
On Mon, May 14, 2018, 10:16 AM Gedare Bloom <gedare at rtems.org> wrote:
> This is an excellent rule. BSP names should be unique.
I am not sure the current logic ensures that but it did break one of my
name reuses.
> On Mon, May 14, 2018 at 8:36 AM, Joel Sherrill <joel at rtems.org> wrote:
> > Hi
> > Just a note that I had used the BSP name deos for three architectures.
> This
> > worked until Chris added the BSP/architecture check.
> > I am ok with the rule thank a bsp name is unique across all architectures
> > but wanted to make sure this was a conscious rule now.
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180514/10a2827e/attachment-0002.html>
