[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon May 14 18:10:41 UTC 2018
On Mon, 14 May 2018, 23:24 Cillian O'Donnell, <cpodonnell8 at gmail.com> wrote:
> On Mon, 14 May 2018, 09:50 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 14 May 2018 at 12:10, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On Sun, 13 May 2018, 22:15 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 14 May 2018 at 02:15, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>>  tester/covoar/covoar.cc | 10 +++-------
>>>>>  1 file changed, 3 insertions(+), 7 deletions(-)
>>>>> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
>>>>> index 5c87402..c6b0589 100644
>>>>> --- a/tester/covoar/covoar.cc
>>>>> +++ b/tester/covoar/covoar.cc
>>>>> @@ -75,7 +75,7 @@ static void createBuildPath(Executables&
>>>>> executablesToAnalyze,
>>>>>          if (buildPrefix.empty()) {
>>>>>            buildPrefix = *pri;
>>>>>          } else {
>>>>> -          if (buildBSP != *pri) {
>>>>> +          if (buildPrefix != *pri) {
>>>>>              fail = "executable build prefix does not match: " +
>>>>> buildPrefix;
>>>>>              break;
>>>>> @@ -97,7 +97,7 @@ static void createBuildPath(Executables&
>>>>>          if (buildPath.empty()) {
>>>>>            buildPath = thisBuildPath;
>>>>>          } else {
>>>>> +          if (buildPath != thisBuildPath) {
>>>>>              fail = "executable build path does not match: " +
>>>>> buildPath;
>>>>> @@ -316,11 +316,7 @@ int main(
>>>>>          std::cerr << "warning: Unable to read executable: " <<
>>>>> argv[i] << std::endl;
>>>>>        } else {
>>>>>          coverageFileName = argv[i];
>>>>> -        coverageFileName.replace(
>>>>> -          coverageFileName.length() - executableExtension.size(),
>>>>> -          coverageExtension
>>>>> +        coverageFileName.append( "." + coverageExtension );
>>>>>          if (!FileIsReadable( coverageFileName.c_str() )) {
>>>>>            std::cerr << "warning: Unable to read coverage file: " <<
>>>>> coverageFileName
>>>>> 2.7.4
>>>>> This worked !
>>> Cool, looks like we're onto fixing the reports then. If you take a look
>>> at report.html only the headings are there. I think what might be wrong
>>> there is it's just searching in the wrong place for the results. The fix
>>> for that will lie in coverage.py. Warning about coverage.py, there could be
>>> whole sections in there that might just be deleted, it's still being
>>> reorganized.
>>> Are you working on it ?
> Yeah I'll be hacking away at that, won't make much of a dent till the
> weekend though.
>> Also the absolute path needs to be parsed form the score-symbol.ini for
>> running it from out of the build tree
> This is true.
>> Or seeing as covoar is in good shape now and I think the txt report is ok
>>> (you should check and make sure of that). You could move onto gcov, lcov
>>> stuff. Figure out the state of the gcov support in covoar, generate gcov
>>> reports, compare the results.
>> I'll creat a new thread for gcov report then.
> Cool, you're gonna do the gcov stuff then.
yeah. hopefully it will show some movement soon. :)
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180514/7f76b270/attachment-0002.html>
