[GSOC] Weekly report
    Vidushi Vashishth
    reachvidu at gmail.com
    Tue May 15 15:37:18 UTC 2018
Oh okay, will keep that in mind from the next time!
On Tue, May 15, 2018 at 6:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Minor nit: please put a short description of your project in the title
> (e.g., "tracing") just to avoid overly plain and possibly confusing
> titles if multiple students start to do this. Thanks for the update!
> On Mon, May 14, 2018 at 9:12 PM, Vidushi Vashishth <reachvidu at gmail.com>
> wrote:
> > Hi!
> > As asked by my mentor, I am going to post my weekly project target on the
> > mailing list every Monday. For this week I have the following planned:
> > 1) Develop use cases (common development problems catered to, etc) for
> the
> > rtems tracing support and identify what all needs to be implemented
> around
> > with it. This would be documented first in my blog then the users manual.
> > 2) Create a babeltrace conversion formula for CTF conversion. Document it
> > with sufficient example test cases.
> > 3) Fixing the buffering sample test cases which is currently failing a
> > rtems-path check on execution.
> > 4) Gain familiarity with barectf, identify methods of integrating it with
> > rtems-tld output and working on array support for barectf.
> > Best,
> > Vidushi
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180515/1a4af4da/attachment-0002.html>
