[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri May 18 11:36:11 UTC 2018
On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Cool, you should run it for the full testsuite and take a look at that
> report (takes a while.. around 575 tests)
>>> When I try to run the full testsuites it gives the following error .
What could be causing this ?
self.__bootstrap_inner()
  File "/usr/lib64/python2.7/threading.py", line 817, in __bootstrap_inner
    (self.name, _format_exc()))
IOError: [Errno 11] Resource temporarily unavailable
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/82fe65cc/attachment-0002.html>
