[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell cpodonnell8 at gmail.com
Fri May 18 20:00:49 UTC 2018
On Fri, 18 May 2018, 14:55 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 18 May 2018 at 19:09, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Cool, you should run it for the full testsuite and take a look at that
>>>> report (takes a while.. around 575 tests)
>>>>>> When I try to run the full testsuites it gives the following error .
>>> What could be causing this ?
>> If you run the full testsuite without the coverage options, does it still
>> happen?
> No it seems to run fine without coverage.
I vaguely remember seeing this before last year, I suspect that when things
are cleared up in coverage.py it will dissappear. So don't worry about it
for now, carry on with what you're doing. What branch are you working on at
the moment?
>>> self.__bootstrap_inner()
>>>   File "/usr/lib64/python2.7/threading.py", line 817, in
>>> __bootstrap_inner
>>>     (self.name, _format_exc()))
>>> IOError: [Errno 11] Resource temporarily unavailable
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/768e187d/attachment-0002.html>
