RTEMS Block Driver Execution Flow
Sat May 19 05:53:31 UTC 2018
On 19/5/18 9:45 am, Joel Sherrill wrote:
> I am starting to write a block driver which doesn't have a media matching
> any of the existing ones. I was trying to get a feel for the flow of operations
> and having trouble figuring it out. flashdisk looks to be a good guide except
> it is using rtems_disk_create_phys() which #3358 marks as deprecated.
> RAM disk and NV disk still use it also.
> Where's the best discussion of this?
Doxygen's ...
https://docs.rtems.org/doxygen/branches/master/group__rtems__libblock.html
>  Any other guidance?
As documented in the "Detailed Description" section
https://docs.rtems.org/doxygen/branches/master/group__rtems__bdbuf.html#details
the pool's memory can be used in pools of different sizes. This lets you have a
block size to read a file system's details from a superblock of some form and
from that the file system's block size which is then set.
The output workers can run in parallel if you have separate drivers configured.
I hope this helps.
