[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell cpodonnell8 at gmail.com
Sat May 19 12:14:27 UTC 2018
On Sat, 19 May 2018, 12:28 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 19 May 2018 at 16:47, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> God these messages again... at least I'm an expert in fixing these :)
>> Vijay I'm only seeing the headings in the report on my end using your
>> branch. How are you running it and from where? Is there any changes you
>> haven't pushed?
> I'm rurrning it from top of build tree, the latest change I pushed was
> yesterday
> <https://github.com/thelunatic/rtems-tools/commit/8b4d90821c2af3dc37282c06722cd3eadb5223f4> and
> I haven't made any changes after that. the report seems to be running here.
Strange.. if you clean everything away that covoar outputs and run it
again, can it still find the data?
>> Coverage run for score finished successfully.
>>>> --joel
>>>>>> --joel
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/160c684e/attachment-0002.html>
