[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sat May 19 12:59:26 UTC 2018
On 19 May 2018 at 18:28, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Sat, 19 May 2018, 13:28 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 19 May 2018 at 17:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> On 19 May 2018 at 17:50, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> On 19 May 2018 at 17:44, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> On Sat, 19 May 2018, 12:28 Vijay Kumar Banerjee, <
>>>>> vijaykumar9597 at gmail.com> wrote:
>>>>>> On 19 May 2018 at 16:47, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> God these messages again... at least I'm an expert in fixing these
>>>>>>> :) Vijay I'm only seeing the headings in the report on my end using your
>>>>>>> branch. How are you running it and from where? Is there any changes you
>>>>>>> haven't pushed?
>>>>>> I'm rurrning it from top of build tree, the latest change I pushed
>>>>>> was yesterday
>>>>>> <https://github.com/thelunatic/rtems-tools/commit/8b4d90821c2af3dc37282c06722cd3eadb5223f4> and
>>>>>> I haven't made any changes after that. the report seems to be running here.
>>>>> Strange.. if you clean everything away that covoar outputs and run it
>>>>> again, can it still find the data?
>>>> please see the attached image.
>>>> It seems to be working pretty fine.
>>>> Can you please try cleaning out everything, fetching my
>>> cov-tester-support branch, ./waf build install it and then try running
>>> tester form the top of the build tree?
>> please run it for samples only, running it for whole testsuites is not
>> generating proper report currently.
> Yeah I'll give it another try when I get home. At the beach at the moment.
sure , enjoy !
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/4d1e5345/attachment-0002.html>
