LIST OF IO BENCHMARKS
Udit agarwal dev.madaari at gmail.com
Sat May 19 22:06:00 UTC 2018
Hi,
On Fri, May 18, 2018 at 11:19 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Udit,
> Can you please compare pros/cons of FIO, IOZONE, and Bonnie++,
> probably in a blog post is a good idea.
Done, here
<http://81.4.107.225/wordpress/index.php/2018/05/19/comparing-io-benchmarks-fio-iozone-and-bonnie/>
is the comparison.
> The GPLv2 is not a problem for test suites / benchmarks. It is only a
> problem for code that should get merged into the rtems.git.
> Gedare
> On Thu, May 17, 2018 at 5:20 AM, Udit agarwal <dev.madaari at gmail.com>
> wrote:
> > Hi all,
> > As discussed in yesterday's IRC meeting, here is the list of different IO
> > benchmarks(which are supported by FreeBSD) in the decreasing order of
> their
> > popularity  :
> > FIO - License type:  GPLv2 - Widely accepted for storage device
> benchmarking
> > IOZONE - License: Customized - Large number of features, Also used for
> > storage benchmarking
> > Bonnie++ - GPLv2 - Widely known filesystem benchmark, Not much used for
> > storage benchmarking.
> > IOMETER -  GPLv2 - Out of active development.
> > IORATE - Flexible - Out of active development
> > I have performed SDIO-SDHCI performance analysis using IOZONE. Here are
> the
> > results. And i have documented the process on my blog.
> > Regards,
> > Udit Agarwal
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180520/a952b457/attachment-0002.html>
