[GSOC] Weekly report
Vidushi Vashishth
reachvidu at gmail.com
Mon May 21 13:48:05 UTC 2018
Hey!
I was facing a lot of problems trying to get everything running on MacOS.
Babeltrace in particular had a lot of dependencies and it became
exceedingly difficult to build it. So after Gedare's suggestion during the
weekly meeting, I switched to Ubuntu on my old laptop. The process took a
lot of time hence I couldn't accomplish all of my tasks. I did however
accomplish 1) and some bits of 4). Here is the link of my blog discussing
the use cases you asked for:
https://vidushivashishth.github.io/Third-post-copy/ . Let me know if you
have suggestions about the use cases.
I setup everything including ubuntu 16.04 to rtems sparc-erc32 architecture
again on the new machine. I have an idea of what needs to be done to setup
CTF conversion. I hope to deliver something concrete in another day's time.
I hope that's okay. I however, have learnt to build stuff quicker now.
On Mon, May 21, 2018 at 4:04 PM, Sebastian Huber <
> Hello Vidushi,
> do you already have something that we can try out?
> ----- Vidushi Vashishth <reachvidu at gmail.com> schrieb:
> > Hi!
> > As asked by my mentor, I am going to post my weekly project target on the
> > mailing list every Monday. For this week I have the following planned:
> > 1) Develop use cases (common development problems catered to, etc) for
> the
> > rtems tracing support and identify what all needs to be implemented
> around
> > with it. This would be documented first in my blog then the users manual.
> > 2) Create a babeltrace conversion formula for CTF conversion. Document it
> > with sufficient example test cases.
> > 3) Fixing the buffering sample test cases which is currently failing a
> > rtems-path check on execution.
> > 4) Gain familiarity with barectf, identify methods of integrating it with
> > rtems-tld output and working on array support for barectf.
> > Best,
> > Vidushi
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/71020a04/attachment-0002.html>
