[PATCH] covoar.cc: Correct build path checks for multiple executables.
Mon May 21 19:03:42 UTC 2018
On Mon, May 21, 2018, 1:54 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 21 May 2018 at 23:07, Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, May 21, 2018, 12:01 PM Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 21 May 2018 at 21:42, Joel Sherrill <joel at rtems.org> wrote:
>>>> On Mon, May 21, 2018 at 10:13 AM, Vijay Kumar Banerjee <
>>>>> On 21 May 2018 at 20:37, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Mon, May 21, 2018 at 9:52 AM, Vijay Kumar Banerjee <
>>>>>>> On 21 May 2018 at 17:39, Joel Sherrill <joel at rtems.org> wrote:
>>>>>>>> CPU-rtems5-objdump
>>>>>>>> sparc-rtems5-objdump worked  , thanks .
>>>>>>> I can see some mismatches in the disassembly .
>>>>>> I'm building sparc now. What mismatches do you see?
>>>>>> I started another thread for CSWTCH.*. That's not the type of
>>>>>> mismatch Cillian
>>>>>> worked on last summer. It is a symbol that isn't even code and
>>>>>> shouldn't be
>>>>>> in the symbol set.
>>>>> I saw the other thread . In sparc I'm getting CSWTCH.* in local text
>>>>> segment "t" .
>>>> Grr... this may require us to toss out some symbol patterns that are
>>>> generated
>>>> by GCC.
>>>>> [lunatic at lunatic samples]$ sparc-rtems5-nm base_sp/base_sp.exe | grep
>>>>> -i csw
>>>>> 40010c18 t CSWTCH.1
>>>> I see this also on the sparc. On the i386, it is rodata.
>>>>> I followed the INFO messages for a mismatch in
>>>>> _Workspace_Allocate_or_fatal_error
>>>>> here's what I came up with
>>>>> --------------- capture.exe
>>>>> [lunatic at lunatic samples]$ sparc-rtems5-objdump -d
>>>>> capture/capture.exe | grep "_Workspace_Allocate_or_fatal_error"
>>>>> 40010c5c: 40 00 15 8c call  4001628c
>>>>> <_Workspace_Allocate_or_fatal_error>
>>>>> 400117ac: 40 00 12 b8 call  4001628c
>>>>> 40011938: 40 00 12 55 call  4001628c
>>>>> 40015c94: 40 00 01 7e call  4001628c
>>>>> 4001628c <_Workspace_Allocate_or_fatal_error>:
>>>>> 400162ac: 02 80 00 04 be  400162bc
>>>>> <_Workspace_Allocate_or_fatal_error+0x30>
>>>>> 4002cb14: 7f ff a5 de call  4001628c
>>>>> -------------- base_sp.exe
>>>>> base_sp/base_sp.exe | grep "_Workspace_Allocate_or_fatal_error"
>>>>> 40008068: 40 00 11 49 call  4000c58c
>>>>> 400089f4: 40 00 0e e6 call  4000c58c
>>>>> 40008b80: 40 00 0e 83 call  4000c58c
>>>>> 4000c0e0: 40 00 01 2b call  4000c58c
>>>>> 4000c58c <_Workspace_Allocate_or_fatal_error>:
>>>>> 4000c5ac: 02 80 00 04 be  4000c5bc
>>>> That shows the references to the symbol not the size. You need to look
>>>> at the start of
>>>> the symbol and start of the following symbol.
>>>> I looked at the "nm -N" output for base_sp.
>>>> 0200ba0c T _Workspace_Allocate_or_fatal_error
>>>> 0200ba48 T _SPARC_Counter_read_address
>>>> I get this for base_sp
>>> 4000c58c T _Workspace_Allocate_or_fatal_error
>>> 4000c5e0 T syscall
>>> 0xe0 - 0x8c = 0x54 ==> 84
>>>> And for capture:
>>>> 02015c3c T _Workspace_Allocate_or_fatal_error
>>>> 02015c78 T rtems_shell_wait_for_explicit_input
>>>>  4001628c T _Workspace_Allocate_or_fatal_error
>>> 400162c8 T rtems_shell_wait_for_explicit_input
>>> 0xc8 - 0x8c = 0x3C ==> 60
>> OK. In base_sp.exe, what is at the end of the method
>> _Workspace_Allocate_or_fatal_error before the beginning of syscall?
>  _Internal_error( INTERNAL_ERROR_WORKSPACE_ALLOCATION );
> 4000c5bc:       7f ff eb 70     call  4000737c <_Internal_error>
> 4000c5c0:       90 10 20 03     mov  3, %o0
> 4000c5c4:       01 00 00 00     nop
> When you compare the code for  _Workspace_Allocate_or_fatal_error in both
>> .exe files, are they the same? They should be since the code is coming from
>> a library and it always has matched in the past. But...
> it looks the same though.
Are you sure those are the two executables which it is tripping over?
I have never seen a case where the code matched by hand and covoar messed
up. But there is always the first. :)
Are you running with just those two executables?
If the input Is the same and covoar doesn't believe it, then gdb is your
friend. Or you will have to add some helpful verbose messages that Cillian
and I couldn't.
>>> base_sp: 0x48 - 0x0c = 0x3C ==> 60
>>>> capture: 0x78 - 0x3c = 0x3c ==> 60
>>>> Based on that alone, they are the same size. Now let's look at the
>>>> objdump and see what's
>>>> at the end that might look like padding:
>>>> base_sp.exe ========================
>>>>  200ba3c:       7f ff ea d4     call  200658c <_Internal_error>
>>>>  200ba40:       90 10 20 03     mov  3, %o0
>>>>  200ba44:       01 00 00 00     nop
>>>> The nop would be considered padding by covoar since it is at the end of
>>>> the method.
>>>> capture.exe ===========================
>>>>  2015c6c:       7f ff e6 53     call  200f5b8 <_Internal_error>
>>>>  2015c70:       90 10 20 03     mov  3, %o0
>>>>  2015c74:       01 00 00 00     nop
>>>> Comparing the body of the two methods based on objdump output, I don't
>>>> see any difference for sparc/erc32 at -O2.
>>>> I repeated looking at the objdump output at -Os and they were the same
>>>> instructions
>>>> and length.
>>>> You will have to investigate to see why they are different on your side.
>>>> What am I doing different ? Is it because of the covoar patches ?
>>> (have you applied the patches ?)
>> I got my results comparing the .exe's by hand with no involvement of
>> covoar.
>> I am getting the above result by hand. running covoar
> shows the same size mismatch that I'm getting by hand
>> What compiler flags are you using? -O2 or -Os? Gcov arguments? Any other
>> changes to them?
> -O2 . No Gcov arguments or any other changes.
> PS: For Gcov I'm actually waiting for the discussion on changing the gcc
> flags
Change them by hand in the .cfg file for now.
Changege them -joelel
>>>>>>> Probably i386. Aren't you running pc386?
>>>>>>>> I'm running sparc
>>>>>>>> Not sparc/erc32 or Leon
>>>>>>>> On Mon, May 21, 2018, 6:35 AM Cillian O'Donnell <
>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>> On Mon, 21 May 2018, 12:18 Vijay Kumar Banerjee, <
>>>>>>>>>> On 21 May 2018 at 16:39, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>>>> > wrote:
>>>>>>>>>>> On Mon, 21 May 2018, 12:08 Cillian O'Donnell, <
>>>>>>>>>>>> On Mon, 21 May 2018, 11:49 Vijay Kumar Banerjee, <
>>>>>>>>>>>>> On 21 May 2018 at 11:56, Cillian O'Donnell <
>>>>>>>>>>>>>> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>> On 21 May 2018 at 02:29, Cillian O'Donnell <
>>>>>>>>>>>>>>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <
>>>>>>>>>>>>>>>>>>> It works.. Sorry I was using the right covoar but the
>>>>>>>>>>>>>>>>>>> wrong rtems-test. Ahh its nice to see the data back in the reports again.
>>>>>>>>>>>>>>>>>>> Did you manage to track down 2 exes with the mismatch in symbol size?
>>>>>>>>>>>>>>>>>> Great! so next is the parsing of the symbol file.
>>>>>>>>>>>>>>>>>> I couldn't manage to track down the mismatch.
>>>>>>>>>>>>>>>>>> I have pushed these to my master branch.
>>>>>>>>>>>>>>>>> The latest update to cov-tester-support branch (please
>>>>>>>>>>>>>>>>> have a look)
>>>>>>>>>>>>>>>>> parses the symbol-set ini file from the coverage script.
>>>>>>>>>>>>>>>>> The parsing
>>>>>>>>>>>>>>>>> is working but currently it's not generating reports, as
>>>>>>>>>>>>>>>>> covoar
>>>>>>>>>>>>>>>>> needs to be updated .
>>>>>>>>>>>>>>>> It's best if covoar reads it's own config file, otherwise
>>>>>>>>>>>>>>>> it creates a dependency on the tester. Scanning over the recent changes to
>>>>>>>>>>>>>>>> covoar there, it looks like it can already handle multiple sets, so the one
>>>>>>>>>>>>>>>> ini with multiple sets in it is the way to go.
>>>>>>>>>>>>>>> Okay, Understood.
>>>>>>>>>>>>>>>> Here are the things that I have done and that needs to be
>>>>>>>>>>>>>>>>> done in order to generate reports :
>>>>>>>>>>>>>>>>> I have added a symbol-sets.ini file and parsed it from the
>>>>>>>>>>>>>>>>> coverage script
>>>>>>>>>>>>>>>>> this is how it works :
>>>>>>>>>>>>>>>>>    - The ini file can be updated with all the symbols,
>>>>>>>>>>>>>>>>>    separated by ' , ' (comma)
>>>>>>>>>>>>>>>> This is the way covoar is actually handling it now. You
>>>>>>>>>>>>>>>> should test a multi set ini and see if that's working.
>>>>>>>>>>>>>>> Yeah, I have seen it. will try with multiple sets.
>>>>>>>>>>>>>>>>>    - The coverages splits them and makes a list of all
>>>>>>>>>>>>>>>>>    the sets
>>>>>>>>>>>>>>>>>    -  The respective libraries are parsed from the
>>>>>>>>>>>>>>>>>    libraries section.
>>>>>>>>>>>>>>>>>    - It returns a dict with all the symbols and thir
>>>>>>>>>>>>>>>>>    resp. library addresses.
>>>>>>>>>>>>>>>>>    - The library addresses are absolute so it can be run
>>>>>>>>>>>>>>>>>    from anywhere
>>>>>>>>>>>>>>>>>    top of build tree is not necessary.
>>>>>>>>>>>>>>>>> This was a good idea but it's just that dependency issue
>>>>>>>>>>>>>>>> we want to stay away from. Covoar has something to find the build directory
>>>>>>>>>>>>>>>> too, it just hasn't been connected up yet, so running it from the top of
>>>>>>>>>>>>>>>> the build directory is ok for the moment.
>>>>>>>>>>>>>>> yes it can find the build directory. I was giving it a shot
>>>>>>>>>>>>>>> to do it from the script.
>>>>>>>>>>>>>>> If covoar's standalone working is a necessity then it surely
>>>>>>>>>>>>>>> needs to be working
>>>>>>>>>>>>>>> from covoar and shouldn't depend on the script.
>>>>>>>>>>>>>> It should be working from covoar and it will.
>>>>>>>>>>>>>>>> Probably the most pressing thing now is investigating those
>>>>>>>>>>>>>>>> mismatch in symbol size.
>>>>>>>>>>>>>>> any advice on where/how to look for it ?
>>>>>>>>>>>>>> Before what I was doing was examining the objdump of 2 exes,
>>>>>>>>>>>>>> looking there on the weekend i think the info messages mentioned which ones
>>>>>>>>>>>>>> were having trouble for which symbol. It says something like "couldn't
>>>>>>>>>>>>>> merge coverage map for some_symbol because sizes from exe != to size of
>>>>>>>>>>>>>> other_exe. Look at the objdump of exe and other_exe, search for some_symbol
>>>>>>>>>>>>>> and compare the dissasembly. There'll be more lines in one than the other,
>>>>>>>>>>>>>> nop padding probably. Then you had to find a check that was strict enough
>>>>>>>>>>>>>> to chop the end of the symbol in question at the right place but not so
>>>>>>>>>>>>>> strict that it chopped other symbols in the wrong place. However the method
>>>>>>>>>>>>>> of obtaining the symbols has changed, I'll have to have a look over the
>>>>>>>>>>>>>> covoar changes tonight to see what would be the equivalent method of
>>>>>>>>>>>>>> checking this now. Unless Chris or Joel come back with the answer before
>>>>>>>>>>>>>> then.
>>>>>>>>>>>>>> Please have a look into this as I'm confused .
>>>>>>>>>>>>> From the messages it seems like there's something with
>>>>>>>>>>>>> the base_sp.exe .
>>>>>>>>>>>>> I tried to run objdum with -d , I'm getting an error
>>>>>>>>>>>>> objdump: can't disassemble for architecture UNKNOWN!
>>>>>>>>>>>>> what am I missing ?
>>>>>>>>>>>> It'll be a sparc-objdump that was built with the rsb in 5/bin/.
>>>>>>>>>>>> I'm not sure if we're still grabbing the objdump using rtems-tools
>>>>>>>>>>> can't run sparc-objdump.
>>>>>>>>> That might not be the exact name. Is there something that looks
>>>>>>>>> like it in that directory.
>>>>>>>>>> Sorry *rtemstoolkit
>>>>>>>>>>>> now, so not 100% sure that this still the way to investigate
>>>>>>>>>>>> this.
>>>>>>>>>>>>> Also there will probably be multiple ini's with different
>>>>>>>>>>>>>> collections of sets that the user could run so it would be good to give
>>>>>>>>>>>>>> them some method of choosing which ini they want, like coverage=score will
>>>>>>>>>>>>>> feed score.ini to covoar. You could try have a go at that.
>>>>>>>>>>>>> yeah I was planning something similar with the script
>>>>>>>>>>>>> to let users  choose the sets, and run all by default .
>>>>>>>>>>>>> I guess it needs to be done from covoar to avoid dependancy.
>>>>>>>>>>>>> I can have look into this.
>>>>>>>>>>>> This is different in that it's just allowing the user an easier
>>>>>>>>>>>> way of choosing the right ini. So it wouldn't be a dependency like the
>>>>>>>>>>>> other thing, if you run it manually you will still have to select the ini
>>>>>>>>>>>> you want. So this will be part of the script.
>>>>>>>>>>> Oh , I will look into this then. :)
>>>>>>>>>>> This way we can parse all the symbols from the same ini file.
>>>>>>>>>>>>>>>>> what needs to be done :
>>>>>>>>>>>>>>>>>    - I have added #FIXME s in the code , those are the
>>>>>>>>>>>>>>>>>    small fixes that
>>>>>>>>>>>>>>>>>    would be needed .
>>>>>>>>>>>>>>>>>    - The covoar needs to be updated. My proposal is that
>>>>>>>>>>>>>>>>>    we can feed the
>>>>>>>>>>>>>>>>>    parsed  dict to the covoar instead of feeding the
>>>>>>>>>>>>>>>>>    symbol file and letting
>>>>>>>>>>>>>>>>>    covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/d5af1bc3/attachment-0002.html>
