[PATCH 2/2] covoar/Target_sparc.cc: Add unimpl as nop
    Joel Sherrill
    joel at rtems.org
    Thu May 24 03:24:46 UTC 2018
On Wed, May 23, 2018, 10:01 PM Chris Johns <chrisj at rtems.org> wrote:
> On 24/5/18 12:07 pm, Joel Sherrill wrote:
> >  tester/covoar/Target_sparc.cc | 4 ++++
> >  1 file changed, 4 insertions(+)
> > diff --git a/tester/covoar/Target_sparc.cc
> b/tester/covoar/Target_sparc.cc
> > index 0e4ab2e..deeafef 100644
> > --- a/tester/covoar/Target_sparc.cc
> > +++ b/tester/covoar/Target_sparc.cc
> > @@ -64,6 +64,10 @@ namespace Target {
> >        size = 4;
> >        return true;
> > +    if (!strcmp( &line[strlen(line)-6], "unimpl")) {
It's matching the last N characters on the line. It should be backing off
one extra for a new line.
> I have not looked at the code around this for C++.
> Also these calls should be "::strcmp()".
Ok. The same pattern is every Target*.cc
> Chris
> > +      size = 4;
> > +      return true;
> >      if (!strcmp( &line[strlen(line)-7], "unknown")) {
> >        size = 4;
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180523/0a6bac66/attachment-0002.html>
