[GSOC] CTF generator configuration files
Vidushi Vashishth reachvidu at gmail.com
Wed May 30 11:27:01 UTC 2018
Hi Sebastian!
Yes I have been working on the documentation. I wrote a blog about the the
tracing framework use cases a while ago. It can be seen here
https://vidushivashishth.github.io/Third-post-copy/
I will write a blog about trace buffer generation which would explain all
the questions you have posed too. As suggested by Gedare the blog posts
will somewhat be the first draft of what is to go in the user manual. I
would appreciate your feedback on the blogpost.
Thanks!
On Wed, May 30, 2018 at 11:03 AM, Sebastian Huber <
> Hello Vidushi,
> could you please also work on the user documentation and the use cases. I
> am not an expert in this CTF stuff. Without an introduction in the user
> manual I am pretty helpless. I don't know which tools I have to install. I
> don't know the workflow. I don't know why I need a "CTF generator
> configuration file". I have no time to read all the documents here and
> there. Users have no time and are impatient.
> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/2870561b/attachment-0002.html>
