[PATCH] c-user: Fix rtems_region_create() return status
Wed May 30 12:13:31 UTC 2018
Why is improperly aligned not an error?
On Wed, May 30, 2018, 3:53 AM Sebastian Huber <
>  c-user/region_manager.rst | 5 +++--
>  1 file changed, 3 insertions(+), 2 deletions(-)
> diff --git a/c-user/region_manager.rst b/c-user/region_manager.rst
> index 1bebd8a..713fb07 100644
> --- a/c-user/region_manager.rst
> +++ b/c-user/region_manager.rst
> @@ -255,12 +255,13 @@ DIRECTIVE STATUS CODES:
>         - ``id`` is NULL
>       * - ``RTEMS_INVALID_ADDRESS``
>         - ``starting_address`` is NULL
> -     * - ``RTEMS_INVALID_ADDRESS``
> -       - address not on four byte boundary
>       * - ``RTEMS_TOO_MANY``
>         - too many regions created
>       * - ``RTEMS_INVALID_SIZE``
>         - invalid page size
> +     * - ``RTEMS_INVALID_SIZE``
> +       - the memory area defined by the starting address and the length
> +         parameters is too small
>  DESCRIPTION:
>      This directive creates a region from a physically contiguous memory
> space
> 2.13.6
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/eceabbab/attachment-0002.html>
