[PATCH] Updating trace buffer configuration
Vidushi Vashishth
reachvidu at gmail.com
Wed May 30 13:54:05 UTC 2018
>Based on this error, I believe you need to drop the "struct", given
>that Thread_Control is the typedef for "struct _Thread_Control".
Oh yes you are right. It was originally written with the "struct" so I
somehow overlooked it. I tired it this way. It works thanks.
>Minor, but in most other places in RTEMS, I've seen pointers declared
>with the asterisk on the variable not on the type ("int *ptr;" instead
>of "int* ptr;").
The trace linker code was last updated couple of years ago and this isn't
the convention used in it. I don't know if the convention has changed but I
stuck with how it was done in the configuration files of the trace linker.
On Wed, May 30, 2018 at 7:05 PM, Amaan Cheval <amaan.cheval at gmail.com>
wrote:
> On Wed, May 30, 2018 at 6:33 PM, Vidushi Vashishth <reachvidu at gmail.com>
> wrote:
> > Could you please change the
> > to
> > Thread_Control
> > and check if it still works.
> > In RTEMS, we use typedefs for structures in general.
> > I tried to include the threadq.h header file so that I could use the
> > variable Thread_Control instead of _Thread_Control. This header file has
> the
> > following typedef statement:
> > typedef struct _Thread_Control Thread_Control;
> > However this leads to the following error:
> > fileio-wrapper.c:389:31: warning: initialization from incompatible
> pointer
> > type [-Wincompatible-pointer-types]
> > struct Thread_Control* tc = _Thread_Get_executing();
> of "int* ptr;").
> > fileio-wrapper.c:390:32: warning: passing argument 1 of
> > '_Thread_Get_priority' from incompatible pointer type
> > return (_Thread_Get_priority(tc) << 8) | tc->Real_priority.priority;
> > I had tried this earlier too. So it doesn't work.
> > On Wed, May 30, 2018 at 10:59 AM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 29/05/18 17:36, Vidushi Vashishth wrote:
> >>> linkers/rtld-trace-buffer.ini | 5 +++--
> >>> 1 file changed, 3 insertions(+), 2 deletions(-)
> >>> diff --git a/linkers/rtld-trace-buffer.ini
> >>> b/linkers/rtld-trace-buffer.ini
> >>> index af9fc31..ee68d55 100644
> >>> --- a/linkers/rtld-trace-buffer.ini
> >>> +++ b/linkers/rtld-trace-buffer.ini
> >>> @@ -26,6 +26,7 @@ buffer-local = " uint8_t* in;"
> >>> header = "#include <stdint.h>"
> >>> header = "#include <rtems.h>"
> >>> header = "#include <rtems/rtems/tasksimpl.h>"
> >>> +header = "#include <rtems/score/threadimpl.h>"
> >>> [trace-buffer-tracers]
> >>> code = <<<CODE
> >>> @@ -84,8 +85,8 @@ static inline uint32_t __rtld_tbg_executing_id(void)
> >>> static inline uint32_t __rtld_tbg_executing_status(void)
> >>> /* @fixme Add the current CPU for SMP. */
> >>> - struct Thread_Control* tc = _Thread_Get_executing();
> >> to
> >> Thread_Control
> >>> - return (tc->current_priority << 8) | tc->real_priority;
> >>> + struct _Thread_Control* tc = _Thread_Get_executing();
> >>> + return (_Thread_Get_priority(tc) << 8) | tc->Real_priority.priority;
> >>> static inline uint32_t __rtld_tbg_executing_state(void)
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/e3325344/attachment-0002.html>
