<offllist> Coverage support for tester
Cillian O'Donnell cpodonnell8 at gmail.com
Wed May 30 17:12:29 UTC 2018
On Wed, 30 May 2018, 16:58 Gedare Bloom, <gedare at rtems.org> wrote:
> On Wed, May 30, 2018 at 11:32 AM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > On 30 May 2018 at 20:18, Gedare Bloom <gedare at rtems.org> wrote:
> >> Hello Vijay,
> >> Do you expect/need an answer to something in here?
> >> gedare
> > Hello,
> > I wanted to know if there were any plans on how covoar
> > should store the reports when running for multisets.
> > Earlier it used to be done by the coverage script,
> > after the recent changes covoar can process multi sets.
> > I think, covoar should store the reports into separate directories
> > for each set . eg. score/ , rtems/ . As the coverage can already read
> > from separate directories.
Sorry I thought all questions had been answered here. I think you have the
right idea. Each set should be a sub-directory of coverage directory.
By the way I tested your changes and everything seems fine. Still have to
do a review of coverage.py to see how close we are to merging.
> > Any advice on how should it be approached ?
> It would help me if you could draw/write a diagram of what the
> filesystem tree might look like with separate directories, and what
> will go in each subdirectory.
> I don't have enough context to give any useful advice on this question.
> -Gedare
> >> On Wed, May 30, 2018 at 10:29 AM, Vijay Kumar Banerjee
> >> > On 30 May 2018 at 00:54, Joel Sherrill <joel at rtems.org> wrote:
> >> >> On Tue, May 29, 2018 at 11:27 AM, Vijay Kumar Banerjee
> >> >>> On Tue, 29 May 2018, 20:10 Joel Sherrill, <joel at rtems.org> wrote:
> >> >>>> On Mon, May 28, 2018 at 11:08 PM, Chris Johns <chrisj at rtems.org>
> >> >>>> wrote:
> >> >>>>> On 29/5/18 4:26 am, Joel Sherrill wrote:
> >> >>>>> > On Mon, May 28, 2018 at 5:43 AM, Vijay Kumar Banerjee
> >> >>>>> > <mailto:vijaykumar9597 at gmail.com>> wrote:
> >> >>>>> >     Hello,
> >> >>>>> >     The coverage reports are now showing results.
> >> >>>>> >     The current branch that holds all the changes is
> >> >>>>> >     the cov-tester-support branch in my forked repo
> https://github.com/thelunatic/rtems-tools/tree/cov-tester-support
> https://github.com/thelunatic/rtems-tools/tree/cov-tester-support>
> >> >>>>> >     (Please have a look into the code and test it.)
> >> >>>>> >     It is close to merging (hopefully). These are the issues
> >> >>>>> >     that would need a fix before it can be merged :
> >> >>>>> >     1. I have added some #FIXME in the code (have a look)
> >> >>>>> >         in coverage script. I have set the value of the targe to
> >> >>>>> > be
> >> >>>>> >         sparc-rtems5, which makes it limited to sparc-rtems5
> only.
> >> >>>>> > We
> >> >>>>> > can
> >> >>>>> >     include the target in the bsp ini file, That would
> >> >>>>> >     be a quick fix for this.
> >> >>>>> > Yes. This needs to be fixed.
> >> >>>>> > My hack to add 4 in ObjdumpProcessor.cc needs to be addressed
> >> >>>>> > also.
> >> >>>>> > I am thinking of adding a method to Target_*.cc to ask for the
> >> >>>>> > size
> >> >>>>> > of an
> >> >>>>> > instruction.
> >> >>>>> > Then pass it the last instruction. That way we can throw on
> other
> >> >>>>> > architectures for
> >> >>>>> > now. If Chris solves this with his changes before we try another
> >> >>>>> > architecture,
> >> >>>>> > great.
> >> >>>>> > If not, it will be easy to fix.
> >> >>>>> What is the overall requirement?
> >> >>>> To know the ending address of the function.
> >> >>>> Technically there are three pieces of information:
> >> >>>> + start address
> >> >>>> + end address
> >> >>>> + size
> >> >>>> If you know two of those, you can compute the third.
> >> >>>> I don't care if this comes from DWARF, ELF, or parsing the
> >> >>>> disassembly.
> >> >>>> It just needs to be reliable.
> >> >>>> And.. I am not proposing my solution as permanent. Just to keep us
> >> >>>> moving. You want to change to an internal disassembler (which
> >> >>>> would also need to have the source interspersed) and DWARF. So
> >> >>>> this code would go away then.
> >> >>>>> What defines the function and so size are attempting to get
> coverage
> >> >>>>> of? What if
> >> >>>>> that function calls an inline function and that function is
> inlined?
> >> >>>>> What if
> >> >>>>> that inlined function calls another inlined function?
> >> >>>> Then it is all inlined. It is done consistently now. I have never
> >> >>>> seen a
> >> >>>> case
> >> >>>> where two instances of a method differed as the assembly level. [1]
> >> >>>> The actual body of the inlined method is evaluated at each
> expansion
> >> >>>> point.
> >> >>>> That is why a few years ago, I pushed hard to reduce the complexity
> >> >>>> of
> >> >>>> inline methods because we got test patch explosion when an inlined
> >> >>>> method
> >> >>>> included complex conditionals.
> >> >>>> Similarly, I think it would be helpful to coverage and verification
> >> >>>> efforts to
> >> >>>> follow the **shudder** MISRA rule which want you to write simple
> >> >>>> conditional
> >> >>>> expressions rather than compound ones. I have taken to writing code
> >> >>>> this
> >> >>>> way as much as possible. But haven't pushed it as a coding rule.
> >> >>>>   if (a) {
> >> >>>>     if (b) {
> >> >>>>       do x;
> >> >>>> Versus
> >> >>>>   if (a && b) {
> >> >>>>     do x;
> >> >>>> The reason is that the first is easier to analyse coverage on.
> >> >>>> [1] We both expect LTO could change this.
> >> >>>> [2] ESA did specifically mention this one though. Also in general
> >> >>>> terms,
> >> >>>> an RTEMS Project response to MISRA rules. Which ones we follow,
> >> >>>> reject, etc.. But I refuse to adopt hard rules which can't be
> >> >>>> enforced
> >> >>>> by free open source tools.
> >> >>>>> The DWARF data provides details about the PC low and PC high of
> what
> >> >>>>> is
> >> >>>>> called
> >> >>>>> concrete functions and then it provides the details about inlines.
> >> >>>> We don't (currently) report on the inlines as independent methods.
> >> >>>>> >     2. coverage used to feed ini file for each symbol to covoar
> >> >>>>> >         in a loop and store the result in a separate directory
> >> >>>>> >         for each symbol . Which is needed no more needed as
> >> >>>>> >         covoar can now process multi sets from a
> >> >>>>> >          single ini file. I think the results from covoar should
> >> >>>>> > be
> >> >>>>> >         store in a separate directory for each symbol
> >> >>>>> >         example :- score/
> >> >>>>> > A bit of history will help here. Originally covoar was run
> against
> >> >>>>> > a
> >> >>>>> > single set of
> >> >>>>> > code by the scripting framework. We would do coverage on either
> >> >>>>> > "core
> >> >>>>> > parts"
> >> >>>>> > or "developmental" (e.g. nearly all non-networked code). The
> >> >>>>> > optimization was
> >> >>>>> > either at -O2 or -Os. So there were four coverage variants.
> >> >>>>> > Turned out that when we added something to "all", the percentage
> >> >>>>> > would drop
> >> >>>>> > and reflect badly on the rest of the code. I remember adding the
> >> >>>>> > dosfs and
> >> >>>>> > the coverage dropped almost 20 percent.
> >> >>>>> > This led to the idea that we should report on a per
> >> >>>>> > directory/subsystem basis.
> >> >>>>> > The score, rtems, posix, sapi, and libcsupport should have high
> >> >>>>> > coverage now
> >> >>>>> > and the reports should reflect that independent of whether the
> >> >>>>> > dosfs
> >> >>>>> > needs a
> >> >>>>> > lot more tests.
> >> >>>>> > Before each directory/subsystem required a completely separate
> run
> >> >>>>> > of
> >> >>>>> > covoar.
> >> >>>>> > If we are headed to a solution where one analysis run of covoar
> >> >>>>> > generates different
> >> >>>>> > reports, that should speed up the processing time a lot!
> >> >>>>> > The other issue is what should the top directory look
> like/contain
> >> >>>>> > when a single
> >> >>>>> > run produces multiple subsystem reports. Seems like we would
> need
> >> >>>>> > at
> >> >>>>> > least a
> >> >>>>> > top level html and text file.
> >> >>>>> >     3. currently we are using the leon3-qemu-cov as the bsp.
> >> >>>>> >         Are we going to have two ini file for each bsp ? ( one
> >> >>>>> > without coverage
> >> >>>>> >     and one with coverage support)
> >> >>>>> >     Earlier the approach was to include a section 'coverage'
> >> >>>>> >     to the bsp ini to put the values we needed for coverage.
> >> >>>>> >     I think that approach would be more "convenient" for the
> user.
> >> >>>>> > This was something Chris suggested. I think it was to avoid
> adding
> >> >>>>> > to
> >> >>>>> > the bsp ini file until the code was closer to merging.
> >> >>>>> > Chris.. what do you think? Long term, a section would be nice.
> >> >>>>> Sorry I cannot remember without looking it up and I am currently
> >> >>>>> buried
> >> >>>>> in
> >> >>>>> family issues.
> >> >>>> OK. Having the Python scripting loop over the sets or covoar
> looping
> >> >>>> over them
> >> >>>> is an open issue. Historically, looping over desired symbol sets
> was
> >> >>>> outside
> >> >>>> covoar. So looping inside covoar may take some work.
> >> >>> covoar can already loop over the
> >> >>> sets it seems, which is implemented
> >> >>> in DesiredSymbols. But it stores all the
> >> >>> reports generated from into the same directory.
> >> >> If there is an index that makes its possible to navigate through the
> >> >> different "subsystems", then that's the key thing. You don't want
> >> >> to think score is poorly covered due to dosfs.
> >> >>> P.S:Sorry for the previous mail with no message
> >> >>>> --joel
> >> >>>>> Chris
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/9c8aeac0/attachment-0002.html>
