[PATCH v2] tester: Add script to generate html coverage report from covoar output
Cillian O'Donnell cpodonnell8 at gmail.com
Thu May 31 19:37:41 UTC 2018
On 31 May 2018 at 19:07, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Add support in tester to run covoar and generate an html report to display
> the summary of the coverage reports generated from covoar.
> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>  tester/rt/coverage.py                         | 379
>  tester/rt/test.py                             |  36 ++-
>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>  tester/rtems/testing/qemu.cfg                 |   4 +-
>  5 files changed, 446 insertions(+), 12 deletions(-)
>  create mode 100644 tester/rt/coverage.py
>  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> new file mode 100644
> index 0000000..25fbb9d
> --- /dev/null
> +++ b/tester/rt/coverage.py
> @@ -0,0 +1,379 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS 'AS
> IS'
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +from rtemstoolkit import error
> +from rtemstoolkit import path
> +from rtemstoolkit import log
> +from rtemstoolkit import execute
> +from rtemstoolkit import macros
> +from datetime import datetime
> +from . import options
> +import shutil
> +import os
> +try:
> +    import configparser
> +except:
> +    import ConfigParser as configparser
> +class summary:
> +    def __init__(self, p_summary_dir):
> +        self.summary_file_path = path.join(p_summary_dir, 'summary.txt')
> +        self.index_file_path = path.join(p_summary_dir, 'index.html')
> +        self.bytes_analyzed = 0
> +        self.bytes_not_executed = 0
> +        self.percentage_executed = 0.0
> +        self.percentage_not_executed = 100.0
> +        self.ranges_uncovered = 0
> +        self.branches_uncovered = 0
> +        self.branches_total = 0
> +        self.branches_always_taken = 0
> +        self.branches_never_taken = 0
> +        self.percentage_branches_covered = 0.0
> +        self.is_failure = False
> +    def parse(self):
> +        if(not path.exists(self.summary_file_path)):
> +            log.notice('summary file %s does not exist!' %
> +            self.is_failure = True
> +            return
> +        with open(self.summary_file_path,'r') as summary_file:
> +           self.bytes_analyzed = self._get_next_with_colon(summary_file)
> +           self.bytes_not_executed = self._get_next_with_colon(
> summary_file)
> +           self.percentage_executed = self._get_next_with_colon(
> summary_file)
> +           self.percentage_not_executed = self._get_next_with_colon(
> summary_file)
> +           self.ranges_uncovered = self._get_next_with_colon(
> summary_file)
> +           self.branches_total = self._get_next_with_colon(summary_file)
> +           self.branches_uncovered = self._get_next_with_colon(
> summary_file)
> +           self.branches_always_taken = self._get_next_without_colon(
> summary_file)
> +           self.branches_never_taken = self._get_next_without_colon(
> summary_file)
> +        if len(self.branches_uncovered) > 0 and len(self.branches_total)
> > 0:
> +            self.percentage_branches_covered = \
> +            1 - (float(self.branches_uncovered) /
> float(self.branches_total))
> +        else:
> +        return
> +    def _get_next_with_colon(self, summary_file):
> +        line = summary_file.readline()
> +        if ':' in line:
> +            return line.split(':')[1].strip()
> +        else:
> +            return ''
> +    def _get_next_without_colon(self, summary_file):
> +        return line.strip().split(' ')[0]
> +class report_gen_html:
> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
> +        self.symbol_sets_list = ['score']
> +        self.build_dir = build_dir
> +        self.partial_reports_files = list(["index.html", "summary.txt"])
> +        self.number_of_columns = 1
> +        self.covoar_src_path = path.join(rtdir, 'covoar')
> +    def _find_partial_reports(self):
> +        partial_reports = {}
> +        for symbol_set in self.symbol_sets_list:
> +            set_summary = summary(path.join(self.build_dir, "coverage",
> +                                  symbol_set))
> +            set_summary.parse()
> +            partial_reports[symbol_set] = set_summary
> +        return partial_reports
> +    def _prepare_head_section(self):
> +        head_section = '''
> +        <head>
> +        <title>RTEMS coverage report</title>
> +        <style type="text/css">
> +            progress[value] {
> +              -webkit-appearance: none;
> +               appearance: none;
> +              width: 150px;
> +              height: 15px;
> +        </style>
> +        </head>'''
> +        return head_section
> +    def _prepare_index_content(self, partial_reports):
> +        header = "<h1> RTEMS coverage analysis report </h1>"
> +        header += "<h3>Coverage reports by symbols sets:</h3>"
> +        table = "<table>"
> +        table += self._header_row()
> +        for symbol_set in partial_reports:
> +            table += self._row(symbol_set, partial_reports[symbol_set])
> +        table += "</table> </br>"
> +        timestamp = "Analysis performed on " + datetime.now().ctime()
> +        return "<body>\n" + header + table + timestamp + "\n</body>"
> +    def _row(self, symbol_set, summary):
> +        row = "<tr>"
> +        row += "<td>" + symbol_set + "</td>"
> +        if summary.is_failure:
> +            row += ' <td colspan="' + str(self.number_of_columns-1) \
> +            + '" style="background-color:red">FAILURE</td>'
> +        else:
> +            row += " <td>" + self._link(summary.index_file_path,"Index")
> +            + "</td>"
> +            row += " <td>" + self._link(summary.summary_file_path,"Summary")
> +            + "</td>"
> +            row += " <td>" + summary.bytes_analyzed + "</td>"
> +            row += " <td>" + summary.bytes_not_executed + "</td>"
> +            row += " <td>" + summary.ranges_uncovered + "</td>"
> +            row += " <td>" + summary.percentage_executed + "%</td>"
> +            row += " <td>" + summary.percentage_not_executed + "%</td>"
> +            row += ' <td><progress value="' + summary.percentage_executed
> +            + '" max="100"></progress></td>'
> +            row += " <td>" + summary.branches_uncovered + "</td>"
> +            row += " <td>" + summary.branches_total + "</td>"
> +            row += " <td> {:.3%} </td>".format(summary.
> percentage_branches_covered)
> +            row += ' <td><progress value="{:.3}"
> max="100"></progress></td>'.format(100*summary.percentage_
> branches_covered)
> +            row += "</tr>\n"
> +        return row
> +    def _header_row(self):
> +        row = "<tr>"
> +        row += "<th> Symbols set name </th>"
> +        row += "<th> Index file </th>"
> +        row += "<th> Summary file </th>"
> +        row += "<th> Bytes analyzed </th>"
> +        row += "<th> Bytes not executed </th>"
> +        row += "<th> Uncovered ranges </th>"
> +        row += "<th> Percentage covered </th>"
> +        row += "<th> Percentage uncovered </th>"
> +        row += "<th> Instruction coverage </th>"
> +        row += "<th> Branches uncovered </th>"
> +        row += "<th> Branches total </th>"
> +        row += "<th> Branches covered percentage </th>"
> +        row += "<th> Branches coverage </th>"
> +        row += "</tr>\n"
> +        self.number_of_columns = row.count('<th>')
> +        return row
> +    def _link(self, address, text):
> +        return '<a href="' + address + '">' + text + '</a>'
> +    def _create_index_file(self, head_section, content):
> +        with open(path.join(self.build_dir,"report.html"),'w') as f:
> +            f.write(head_section)
> +            f.write(content)
> +    def generate(self):
> +        partial_reports = self._find_partial_reports()
> +        head_section = self._prepare_head_section()
> +        index_content = self._prepare_index_content(partial_reports)
> +        self._create_index_file(head_section,index_content)
> +    def add_covoar_src_path(self):
> +        table_js_path = path.join(self.covoar_src_path, 'table.js')
> +        covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
> +            symbol_set_dir = path.join(self.build_dir, "coverage",
> symbol_set)
> +            html_files = os.listdir(symbol_set_dir)
> +            for html_file in html_files:
> +                html_file = path.join(symbol_set_dir, html_file)
> +                if path.exists(html_file) and 'html' in html_file:
> +                    with open(html_file, 'r') as f:
> +                        file_data = f.read()
> +                    file_data = file_data.replace('table.js',
> table_js_path)
> +                    file_data = file_data.replace('covoar.css',
> +                                                  covoar_css_path)
> +                    with open(html_file, 'w') as f:
> +                        f.write(file_data)
> +class build_path_generator(object):
> +    Generates the build path from the path to executables
> +    def __init__(self, executables, target):
> +        self.executables = executables
> +        self.target = target
> +    def run(self):
> +        build_path = '/'
> +        Path = self.executables[0].split('/')
> +        for P in Path:
> +            if P == self.target:
> +                break;
> +            else:
> +                build_path = path.join(build_path, P)
> +        return build_path
> +class symbol_parser(object):
> +    Parse the symbol sets ini and create custom ini file for covoar
> +    def __init__(self, symbol_config_path,
> +                 symbol_select_path, coverage_arg, build_dir):
> +        self.symbol_select_file = symbol_select_path
> +        self.symbol_file = symbol_config_path
> +        self.symbol_sets = {}
> +        self.cov_arg = coverage_arg
> +        self.ssets = []
> +    def parse(self):
> +        config = configparser.ConfigParser()
> +        try:
> +            config.read(self.symbol_file)
> +            if self.cov_arg:
> +                self.ssets = self.cov_arg.split(',')
> +            else:
> +                self.ssets = config.get('symbol-sets', 'sets').split(',')
> +                self.ssets = [ sset.encode('utf-8') for sset in
> self.ssets]
> +            for sset in self.ssets:
> +                lib = path.join(self.build_dir,
> +                                config.get('libraries', sset))
> +                self.symbol_sets[sset] = lib.encode('utf-8')
> +        except:
> +            raise error.general('Symbol set parsing failed')
> +    def _write_ini(self):
> +        try:
> +            sets = ', '.join(self.symbol_sets.keys())
> +            config.add_section('symbol-sets')
> +            config.set('symbol-sets', 'sets', sets)
> +            for key in self.symbol_sets.keys():
> +                config.add_section(key)
> +                config.set(key, 'libraries', self.symbol_sets[key])
> +            with open(self.symbol_select_file, 'w') as conf:
> +                config.write(conf)
> +        except:
> +            raise error.general('write failed')
> +    def run(self):
> +        self.parse()
> +        self._write_ini()
> +class covoar(object):
> +    Covoar runner
> +    def __init__(self, base_result_dir, config_dir, executables,
> explanations_txt):
> +        self.base_result_dir = base_result_dir
> +        self.config_dir = config_dir
> +        self.executables = ' '.join(executables)
> +        self.explanations_txt = explanations_txt
> +        self.project_name = 'RTEMS-5'
> +    def run(self, set_name, symbol_file):
> +        covoar_result_dir = path.join(self.base_result_dir, set_name)
> +        if (not path.exists(covoar_result_dir)):
> +            path.mkdir(covoar_result_dir)
> +        if (not path.exists(symbol_file)):
> +            raise error.general('symbol set file: coverage %s was not
> created for covoar, skipping %s'% (symbol_file, set_name))
> +        command = ('covoar -S ' + symbol_file
> +                  + ' -O ' + covoar_result_dir
> +                  + ' -E ' + self.explanations_txt
> +                  + ' -p ' + self.project_name + ' ' + self.executables)
> +        log.notice('Running covoar for %s' % (set_name))
> +        print( 'covoar results directory:\n' + covoar_result_dir )
> +        executor = execute.execute(verbose = True, output =
> self.output_handler)
> +        exit_code = executor.shell(command, cwd=os.getcwd())
> +        if (exit_code[0] != 0):
> +            raise error.general('covoar failure exit code: %d' %
> (exit_code[0]))
> +        log.notice('Coverage run for %s finished successfully.' %
> (set_name))
> +        log.notice('-----------------------------------------------')
> +    def output_handler(self, text):
> +        log.notice('%s' % (text))
> +class coverage_run(object):
> +    Coverage analysis support for rtems-test
> +    def __init__(self, p_macros, coverage_arg, target):
> +        Constructor
> +        self.macros = p_macros
> +        self.build_dir = self.macros['_cwd']
> +        self.explanations_txt = self.macros.expand(self.
> macros['cov_explanations'])
> +        self.test_dir = path.join(self.build_dir, 'coverage')
> +        if (not path.exists(self.test_dir)):
> +            path.mkdir(self.test_dir)
> +        self.rtdir = path.abspath(self.macros['_rtdir'])
> +        self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
> +        self.coverage_config_path = path.join(self.rtscripts, 'coverage')
> +        self.symbol_config_path = path.join(self.coverage_config_path,
> +                                            'symbol-sets.ini')
> +        self.symbol_select_path = path.join(self.coverage_config_path,
> +                                            'symbol-select.ini')
> +        self.executables = None
> +        self.symbol_sets = []
> +        self.no_clean = int(self.macros['_no_clean'])
> +        self.report_format = self.macros['cov_report_format']
> +        self.coverage_arg = coverage_arg
> +    def run(self):
> +        try:
> +            if self.executables is None:
> +                raise error.general('no test executables provided.')
> +            build_dir = build_path_generator(self.executables,
> self.target).run()
> +            parser = symbol_parser(self.symbol_config_path,
> +                                   self.symbol_select_path,
> +                                   self.coverage_arg,
> +                                   build_dir)
> +            parser.run()
> +            covoar_runner = covoar(self.test_dir, self.symbol_select_path,
> +                                   self.executables,
> self.explanations_txt)
> +            covoar_runner.run('score', self.symbol_select_path)
> +            self._generate_reports();
> +            self._summarize();
> +        finally:
> +            self._cleanup();
> +    def _generate_reports(self):
> +        log.notice('Generating reports')
> +        if self.report_format == 'html':
> +            report = report_gen_html(self.symbol_sets,
> +                                     self.build_dir,
> +                                     self.rtdir)
> +            report.generate()
> +            report.add_covoar_src_path()
> +    def _cleanup(self):
> +        if not self.no_clean:
> +            log.notice('***Cleaning tempfiles***')
> +            for exe in self.executables:
> +                trace_file = exe + '.cov'
> +                if path.exists(trace_file):
> +                    os.remove(trace_file)
> +    def _summarize(self):
> +        log.notice('Coverage analysis finished. You can find results in
> %s' % (self.build_dir))
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index f4d9b5c..84dff01 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>  from rtemstoolkit import reraise
>  from rtemstoolkit import stacktraces
>  from rtemstoolkit import version
> +from rtemstoolkit import check
>  from . import bsps
>  from . import config
>  from . import console
>  from . import report
> +from . import coverage
>  class log_capture(object):
>      def __init__(self):
> @@ -147,7 +149,7 @@ class test_run(object):
>      def run(self):
>          self.thread = threading.Thread(target = self.runner,
> -                                       name = 'test[%s]' %
> path.basename(self.executable))
> +                            name = 'test[%s]' %
>          self.thread.start()
>      def is_alive(self):
> @@ -214,6 +216,10 @@ def killall(tests):
>      for test in tests:
>          test.kill()
> +def coverage_run(opts, coverage, executables):
> +    coverage.executables = executables
> +    coverage.run()
>  def run(command_path = None):
>      import sys
>      tests = []
> @@ -221,15 +227,16 @@ def run(command_path = None):
>      opts = None
>      default_exefilter = '*.exe'
>      try:
> -        optargs = { '--rtems-tools': 'The path to the RTEMS tools',
> -                    '--rtems-bsp':   'The RTEMS BSP to run the test on',
> -                    '--user-config': 'Path to your local user
> configuration INI file',
> -                    '--report-mode': 'Reporting modes, failures
> (default),all,none',
> -                    '--list-bsps':   'List the supported BSPs',
> -                    '--debug-trace': 'Debug trace based on specific
> flags',
> -                    '--filter':      'Glob that executables must match to
> run (default: ' +
> +        optargs = { '--rtems-tools':    'The path to the RTEMS tools',
> +                    '--rtems-bsp':      'The RTEMS BSP to run the test
> on',
> +                    '--user-config':    'Path to your local user
> +                    '--report-mode':    'Reporting modes, failures
> +                    '--list-bsps':      'List the supported BSPs',
> +                    '--debug-trace':    'Debug trace based on specific
> flags',
> +                    '--filter':         'Glob that executables must match
> to run (default: ' +
>                                default_exefilter + ')',
> -                    '--stacktrace':  'Dump a stack trace on a user
> termination (^C)' }
> +                    '--stacktrace':     'Dump a stack trace on a user
> termination (^C)',
> +                    '--coverage':       'Perform coverage analysis of
> test executables.'}
>          mailer.append_options(optargs)
>          opts = options.load(sys.argv,
>                              optargs = optargs,
> @@ -279,6 +286,15 @@ def run(command_path = None):
>              raise error.general('RTEMS BSP not provided or an invalid
> option')
>          bsp = config.load(bsp[1], opts)
>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
> +        coverage_enabled = opts.find_arg('--coverage')
> +        if coverage_enabled:
> +            if len(coverage_enabled) == 2:
Is this to check if sets have been provided to --coverage=score,sapi, that
kind of thing? If so the variable name coverage_enabled doesn't make sense
any more. Probably if symbol_sets and if len(symbol_sets) will make more
sense for both cases.
+                coverage_runner = coverage.coverage_run(opts.defaults,
> +                                                coverage_enabled[1],
> +                                                opts.defaults['target'])
> +            else:
> +                coverage_runner = coverage.coverage_run(opts.defaults, 0,
>          report_mode = opts.find_arg('--report-mode')
>          if report_mode:
>              if report_mode[1] != 'failures' and \
> @@ -365,6 +381,8 @@ def run(command_path = None):
>                      reports.failures(),
>                      'Log', '===', ''] + output.get()
>              mail.send(to_addr, subject, os.linesep.join(body))
> +            coverage_run(opts, coverage_runner, executables)
>      except error.general as gerr:
>          print(gerr)
> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> index 6b5e7e6..2f89117 100644
> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> @@ -31,9 +31,10 @@
>  # The Leon 3 QEMU BSP
> -[leon3-qemu]
> +[leon3-qemu-cov]
>  bsp               = leon3-qemu
>  arch              = sparc
> +target            = sparc-rtems5
>  tester            = %{_rtscripts}/qemu.cfg
>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
> b/tester/rtems/testing/coverage/symbol-sets.ini
> index 0000000..a2ec7bc
> --- /dev/null
> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> @@ -0,0 +1,36 @@
> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
> met:
> notice,
> notice,
> documentation
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> THE
> PURPOSE
> BE
> THE
> +[symbol-sets]
> +sets = score,rtems
> +[libraries]
> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
> index bfcd2f5..52a3752 100644
> --- a/tester/rtems/testing/qemu.cfg
> +++ b/tester/rtems/testing/qemu.cfg
> @@ -51,8 +51,8 @@
>  # Qemu common option patterns.
> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
> -nographic
> -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
> -nographic
> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio -nographic
> +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
> -nographic
>  %define qemu_opts_no_net -net none
> 2.14.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/486c0685/attachment-0002.html>
