[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu May 31 19:52:27 UTC 2018
On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com> wrote:
> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
> >> wrote:
> >>> Add support in tester to run covoar and generate an html report to
> >>> display
> >>> the summary of the coverage reports generated from covoar.
> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
> >>>  tester/rt/coverage.py                         | 379
> >>>  tester/rt/test.py                             |  36 ++-
> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
> >>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
> >>>  tester/rtems/testing/qemu.cfg                 |   4 +-
> >>>  5 files changed, 446 insertions(+), 12 deletions(-)
> >>>  create mode 100644 tester/rt/coverage.py
> >>>  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> >>> new file mode 100644
> >>> index 0000000..25fbb9d
> >>> --- /dev/null
> >>> +++ b/tester/rt/coverage.py
> >>> @@ -0,0 +1,379 @@
> >>> +# RTEMS Tools Project (http://www.rtems.org/)
> >>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
> >>> +# All rights reserved.
> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> >>> +# Redistribution and use in source and binary forms, with or without
> >>> +# modification, are permitted provided that the following conditions
> are
> >>> met:
> >>> +# 1. Redistributions of source code must retain the above copyright
> >>> notice,
> >>> +# this list of conditions and the following disclaimer.
> >>> +# 2. Redistributions in binary form must reproduce the above copyright
> >>> notice,
> >>> +# this list of conditions and the following disclaimer in the
> >>> documentation
> >>> +# and/or other materials provided with the distribution.
> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> >>> 'AS IS'
> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO,
> >>> THE
> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> >>> PURPOSE
> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> CONTRIBUTORS
> >>> BE
> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> >>> BUSINESS
> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> >>> IN
> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> >>> OTHERWISE)
> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF
> >>> THE
> >>> +# POSSIBILITY OF SUCH DAMAGE.
> >>> +from rtemstoolkit import error
> >>> +from rtemstoolkit import path
> >>> +from rtemstoolkit import log
> >>> +from rtemstoolkit import execute
> >>> +from rtemstoolkit import macros
> >>> +from datetime import datetime
> >>> +from . import options
> >>> +import shutil
> >>> +import os
> >>> +try:
> >>> +    import configparser
> >>> +except:
> >>> +    import ConfigParser as configparser
> >>> +class summary:
> >>> +    def __init__(self, p_summary_dir):
> >>> +        self.summary_file_path = path.join(p_summary_dir,
> 'summary.txt')
> >>> +        self.index_file_path = path.join(p_summary_dir, 'index.html')
> >>> +        self.bytes_analyzed = 0
> >>> +        self.bytes_not_executed = 0
> >>> +        self.percentage_executed = 0.0
> >>> +        self.percentage_not_executed = 100.0
> >>> +        self.ranges_uncovered = 0
> >>> +        self.branches_uncovered = 0
> >>> +        self.branches_total = 0
> >>> +        self.branches_always_taken = 0
> >>> +        self.branches_never_taken = 0
> >>> +        self.percentage_branches_covered = 0.0
> >>> +        self.is_failure = False
> >>> +    def parse(self):
> >>> +        if(not path.exists(self.summary_file_path)):
> >>> +            log.notice('summary file %s does not exist!' %
> >>> +            self.is_failure = True
> >>> +            return
> >>> +        with open(self.summary_file_path,'r') as summary_file:
> >>> +           self.bytes_analyzed = self._get_next_with_colon(
> summary_file)
> >>> self._get_next_with_colon(summary_file)
> >>> +           self.branches_total = self._get_next_with_colon(
> summary_file)
> >>> self._get_next_without_colon(summary_file)
> >>> +        if len(self.branches_uncovered) > 0 and
> len(self.branches_total)
> >>> > 0:
> >>> +            self.percentage_branches_covered = \
> >>> +            1 - (float(self.branches_uncovered) /
> >>> float(self.branches_total))
> >>> +        else:
> >>> +        return
> >>> +    def _get_next_with_colon(self, summary_file):
> >>> +        line = summary_file.readline()
> >>> +        if ':' in line:
> >>> +            return line.split(':')[1].strip()
> >>> +        else:
> >>> +            return ''
> >>> +    def _get_next_without_colon(self, summary_file):
> >>> +        return line.strip().split(' ')[0]
> >>> +class report_gen_html:
> >>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
> >>> +        self.symbol_sets_list = ['score']
> >>> +        self.build_dir = build_dir
> >>> +        self.partial_reports_files = list(["index.html",
> "summary.txt"])
> >>> +        self.number_of_columns = 1
> >>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
> >>> +    def _find_partial_reports(self):
> >>> +        partial_reports = {}
> >>> +        for symbol_set in self.symbol_sets_list:
> >>> +            set_summary = summary(path.join(self.build_dir,
> "coverage",
> >>> +                                  symbol_set))
> >>> +            set_summary.parse()
> >>> +            partial_reports[symbol_set] = set_summary
> >>> +        return partial_reports
> >>> +    def _prepare_head_section(self):
> >>> +        head_section = '''
> >>> +        <head>
> >>> +        <title>RTEMS coverage report</title>
> >>> +        <style type="text/css">
> >>> +            progress[value] {
> >>> +              -webkit-appearance: none;
> >>> +               appearance: none;
> >>> +              width: 150px;
> >>> +              height: 15px;
> >>> +        </style>
> >>> +        </head>'''
> >>> +        return head_section
> >>> +    def _prepare_index_content(self, partial_reports):
> >>> +        header = "<h1> RTEMS coverage analysis report </h1>"
> >>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
> >>> +        table = "<table>"
> >>> +        table += self._header_row()
> >>> +        for symbol_set in partial_reports:
> >>> +            table += self._row(symbol_set,
> partial_reports[symbol_set])
> >>> +        table += "</table> </br>"
> >>> +        timestamp = "Analysis performed on " + datetime.now().ctime()
> >>> +        return "<body>\n" + header + table + timestamp + "\n</body>"
> >>> +    def _row(self, symbol_set, summary):
> >>> +        row = "<tr>"
> >>> +        row += "<td>" + symbol_set + "</td>"
> >>> +        if summary.is_failure:
> >>> +            row += ' <td colspan="' + str(self.number_of_columns-1) \
> >>> +            + '" style="background-color:red">FAILURE</td>'
> >>> +        else:
> >>> +            row += " <td>" + self._link(summary.index_file_
> path,"Index")
> >>> +            + "</td>"
> >>> +            row += " <td>" +
> >>> self._link(summary.summary_file_path,"Summary") \
> >>> +            + "</td>"
> >>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
> >>> +            row += " <td>" + summary.bytes_not_executed + "</td>"
> >>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
> >>> +            row += " <td>" + summary.percentage_executed + "%</td>"
> >>> +            row += " <td>" + summary.percentage_not_executed +
> "%</td>"
> >>> +            row += ' <td><progress value="' +
> >>> summary.percentage_executed \
> >>> +            + '" max="100"></progress></td>'
> >>> +            row += " <td>" + summary.branches_uncovered + "</td>"
> >>> +            row += " <td>" + summary.branches_total + "</td>"
> >>> +            row += " <td> {:.3%}
> >>> </td>".format(summary.percentage_branches_covered)
> >>> +            row += ' <td><progress value="{:.3}"
> >>> max="100"></progress></td>'.format(100*summary.percentage_
> branches_covered)
> >>> +            row += "</tr>\n"
> >>> +        return row
> >>> +    def _header_row(self):
> >>> +        row = "<tr>"
> >>> +        row += "<th> Symbols set name </th>"
> >>> +        row += "<th> Index file </th>"
> >>> +        row += "<th> Summary file </th>"
> >>> +        row += "<th> Bytes analyzed </th>"
> >>> +        row += "<th> Bytes not executed </th>"
> >>> +        row += "<th> Uncovered ranges </th>"
> >>> +        row += "<th> Percentage covered </th>"
> >>> +        row += "<th> Percentage uncovered </th>"
> >>> +        row += "<th> Instruction coverage </th>"
> >>> +        row += "<th> Branches uncovered </th>"
> >>> +        row += "<th> Branches total </th>"
> >>> +        row += "<th> Branches covered percentage </th>"
> >>> +        row += "<th> Branches coverage </th>"
> >>> +        row += "</tr>\n"
> >>> +        self.number_of_columns = row.count('<th>')
> >>> +        return row
> >>> +    def _link(self, address, text):
> >>> +        return '<a href="' + address + '">' + text + '</a>'
> >>> +    def _create_index_file(self, head_section, content):
> >>> +        with open(path.join(self.build_dir,"report.html"),'w') as f:
> >>> +            f.write(head_section)
> >>> +            f.write(content)
> >>> +    def generate(self):
> >>> +        partial_reports = self._find_partial_reports()
> >>> +        head_section = self._prepare_head_section()
> >>> +        index_content = self._prepare_index_content(partial_reports)
> >>> +        self._create_index_file(head_section,index_content)
> >>> +    def add_covoar_src_path(self):
> >>> +        table_js_path = path.join(self.covoar_src_path, 'table.js')
> >>> +        covoar_css_path = path.join(self.covoar_src_path,
> 'covoar.css')
> >>> +            symbol_set_dir = path.join(self.build_dir, "coverage",
> >>> symbol_set)
> >>> +            html_files = os.listdir(symbol_set_dir)
> >>> +            for html_file in html_files:
> >>> +                html_file = path.join(symbol_set_dir, html_file)
> >>> +                if path.exists(html_file) and 'html' in html_file:
> >>> +                    with open(html_file, 'r') as f:
> >>> +                        file_data = f.read()
> >>> +                    file_data = file_data.replace('table.js',
> >>> table_js_path)
> >>> +                    file_data = file_data.replace('covoar.css',
> >>> +                                                  covoar_css_path)
> >>> +                    with open(html_file, 'w') as f:
> >>> +                        f.write(file_data)
> >>> +class build_path_generator(object):
> >>> +    Generates the build path from the path to executables
> >>> +    def __init__(self, executables, target):
> >>> +        self.executables = executables
> >>> +        self.target = target
> >>> +    def run(self):
> >>> +        build_path = '/'
> >>> +        Path = self.executables[0].split('/')
> >>> +        for P in Path:
> >>> +            if P == self.target:
> >>> +                break;
> >>> +            else:
> >>> +                build_path = path.join(build_path, P)
> >>> +        return build_path
> >>> +class symbol_parser(object):
> >>> +    Parse the symbol sets ini and create custom ini file for covoar
> >>> +    def __init__(self, symbol_config_path,
> >>> +                 symbol_select_path, coverage_arg, build_dir):
> >>> +        self.symbol_select_file = symbol_select_path
> >>> +        self.symbol_file = symbol_config_path
> >>> +        self.symbol_sets = {}
> >>> +        self.cov_arg = coverage_arg
> >>> +        self.ssets = []
> >>> +    def parse(self):
> >>> +        config = configparser.ConfigParser()
> >>> +        try:
> >>> +            config.read(self.symbol_file)
> >>> +            if self.cov_arg:
> >>> +                self.ssets = self.cov_arg.split(',')
> >>> +            else:
> >>> +                self.ssets = config.get('symbol-sets',
> >>> 'sets').split(',')
> >>> +                self.ssets = [ sset.encode('utf-8') for sset in
> >>> self.ssets]
> >>> +            for sset in self.ssets:
> >>> +                lib = path.join(self.build_dir,
> >>> +                                config.get('libraries', sset))
> >>> +                self.symbol_sets[sset] = lib.encode('utf-8')
> >>> +        except:
> >>> +            raise error.general('Symbol set parsing failed')
> >>> +    def _write_ini(self):
> >>> +        try:
> >>> +            sets = ', '.join(self.symbol_sets.keys())
> >>> +            config.add_section('symbol-sets')
> >>> +            config.set('symbol-sets', 'sets', sets)
> >>> +            for key in self.symbol_sets.keys():
> >>> +                config.add_section(key)
> >>> +                config.set(key, 'libraries', self.symbol_sets[key])
> >>> +            with open(self.symbol_select_file, 'w') as conf:
> >>> +                config.write(conf)
> >>> +        except:
> >>> +            raise error.general('write failed')
> >>> +    def run(self):
> >>> +        self.parse()
> >>> +        self._write_ini()
> >>> +class covoar(object):
> >>> +    Covoar runner
> >>> +    def __init__(self, base_result_dir, config_dir, executables,
> >>> explanations_txt):
> >>> +        self.base_result_dir = base_result_dir
> >>> +        self.config_dir = config_dir
> >>> +        self.executables = ' '.join(executables)
> >>> +        self.explanations_txt = explanations_txt
> >>> +        self.project_name = 'RTEMS-5'
> >>> +    def run(self, set_name, symbol_file):
> >>> +        covoar_result_dir = path.join(self.base_result_dir, set_name)
> >>> +        if (not path.exists(covoar_result_dir)):
> >>> +            path.mkdir(covoar_result_dir)
> >>> +        if (not path.exists(symbol_file)):
> >>> +            raise error.general('symbol set file: coverage %s was not
> >>> created for covoar, skipping %s'% (symbol_file, set_name))
> >>> +        command = ('covoar -S ' + symbol_file
> >>> +                  + ' -O ' + covoar_result_dir
> >>> +                  + ' -E ' + self.explanations_txt
> >>> +                  + ' -p ' + self.project_name + ' ' +
> self.executables)
> >>> +        log.notice('Running covoar for %s' % (set_name))
> >>> +        print( 'covoar results directory:\n' + covoar_result_dir )
> >>> +        executor = execute.execute(verbose = True, output =
> >>> self.output_handler)
> >>> +        exit_code = executor.shell(command, cwd=os.getcwd())
> >>> +        if (exit_code[0] != 0):
> >>> +            raise error.general('covoar failure exit code: %d' %
> >>> (exit_code[0]))
> >>> +        log.notice('Coverage run for %s finished successfully.' %
> >>> (set_name))
> >>> +        log.notice('-----------------------------------------------')
> >>> +    def output_handler(self, text):
> >>> +        log.notice('%s' % (text))
> >>> +class coverage_run(object):
> >>> +    Coverage analysis support for rtems-test
> >>> +    def __init__(self, p_macros, coverage_arg, target):
> >>> +        Constructor
> >>> +        self.macros = p_macros
> >>> +        self.build_dir = self.macros['_cwd']
> >>> self.macros.expand(self.macros['cov_explanations'])
> >>> +        self.test_dir = path.join(self.build_dir, 'coverage')
> >>> +        if (not path.exists(self.test_dir)):
> >>> +            path.mkdir(self.test_dir)
> >>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
> >>> +        self.rtscripts = self.macros.expand(self.
> macros['_rtscripts'])
> >>> +        self.coverage_config_path = path.join(self.rtscripts,
> >>> 'coverage')
> >>> +        self.symbol_config_path = path.join(self.coverage_
> config_path,
> >>> +                                            'symbol-sets.ini')
> >>> +        self.symbol_select_path = path.join(self.coverage_
> config_path,
> >>> +                                            'symbol-select.ini')
> >>> +        self.executables = None
> >>> +        self.symbol_sets = []
> >>> +        self.no_clean = int(self.macros['_no_clean'])
> >>> +        self.report_format = self.macros['cov_report_format']
> >>> +        self.coverage_arg = coverage_arg
> >>> +    def run(self):
> >>> +        try:
> >>> +            if self.executables is None:
> >>> +                raise error.general('no test executables provided.')
> >>> +            build_dir = build_path_generator(self.executables,
> >>> self.target).run()
> >>> +            parser = symbol_parser(self.symbol_config_path,
> >>> +                                   self.symbol_select_path,
> >>> +                                   self.coverage_arg,
> >>> +                                   build_dir)
> >>> +            parser.run()
> >>> +            covoar_runner = covoar(self.test_dir,
> >>> +                                   self.executables,
> >>> self.explanations_txt)
> >>> +            covoar_runner.run('score', self.symbol_select_path)
> >>> +            self._generate_reports();
> >>> +            self._summarize();
> >>> +        finally:
> >>> +            self._cleanup();
> >>> +    def _generate_reports(self):
> >>> +        log.notice('Generating reports')
> >>> +        if self.report_format == 'html':
> >>> +            report = report_gen_html(self.symbol_sets,
> >>> +                                     self.build_dir,
> >>> +                                     self.rtdir)
> >>> +            report.generate()
> >>> +            report.add_covoar_src_path()
> >>> +    def _cleanup(self):
> >>> +        if not self.no_clean:
> >>> +            log.notice('***Cleaning tempfiles***')
> >>> +            for exe in self.executables:
> >>> +                trace_file = exe + '.cov'
> >>> +                if path.exists(trace_file):
> >>> +                    os.remove(trace_file)
> >>> +    def _summarize(self):
> >>> +        log.notice('Coverage analysis finished. You can find results
> in
> >>> %s' % (self.build_dir))
> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
> >>> index f4d9b5c..84dff01 100644
> >>> --- a/tester/rt/test.py
> >>> +++ b/tester/rt/test.py
> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
> >>>  from rtemstoolkit import reraise
> >>>  from rtemstoolkit import stacktraces
> >>>  from rtemstoolkit import version
> >>> +from rtemstoolkit import check
> >>>  from . import bsps
> >>>  from . import config
> >>>  from . import console
> >>>  from . import report
> >>> +from . import coverage
> >>>  class log_capture(object):
> >>>      def __init__(self):
> >>> @@ -147,7 +149,7 @@ class test_run(object):
> >>>      def run(self):
> >>>          self.thread = threading.Thread(target = self.runner,
> >>> -                                       name = 'test[%s]' %
> >>> path.basename(self.executable))
> >>> +                            name = 'test[%s]' %
> >>>          self.thread.start()
> >>>      def is_alive(self):
> >>> @@ -214,6 +216,10 @@ def killall(tests):
> >>>      for test in tests:
> >>>          test.kill()
> >>> +def coverage_run(opts, coverage, executables):
> >>> +    coverage.executables = executables
> >>> +    coverage.run()
> >>>  def run(command_path = None):
> >>>      import sys
> >>>      tests = []
> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
> >>>      opts = None
> >>>      default_exefilter = '*.exe'
> >>>      try:
> >>> -        optargs = { '--rtems-tools': 'The path to the RTEMS tools',
> >>> -                    '--rtems-bsp':   'The RTEMS BSP to run the test
> on',
> >>> -                    '--user-config': 'Path to your local user
> >>> configuration INI file',
> >>> -                    '--report-mode': 'Reporting modes, failures
> >>> (default),all,none',
> >>> -                    '--list-bsps':   'List the supported BSPs',
> >>> -                    '--debug-trace': 'Debug trace based on specific
> >>> flags',
> >>> -                    '--filter':      'Glob that executables must match
> >>> to run (default: ' +
> >>> +        optargs = { '--rtems-tools':    'The path to the RTEMS tools',
> >>> +                    '--rtems-bsp':      'The RTEMS BSP to run the test
> >>> on',
> >>> +                    '--user-config':    'Path to your local user
> >>> +                    '--report-mode':    'Reporting modes, failures
> >>> +                    '--list-bsps':      'List the supported BSPs',
> >>> +                    '--debug-trace':    'Debug trace based on specific
> >>> flags',
> >>> +                    '--filter':         'Glob that executables must
> >>> match to run (default: ' +
> >>>                                default_exefilter + ')',
> >>> -                    '--stacktrace':  'Dump a stack trace on a user
> >>> termination (^C)' }
> >>> +                    '--stacktrace':     'Dump a stack trace on a user
> >>> termination (^C)',
> >>> +                    '--coverage':       'Perform coverage analysis of
> >>> test executables.'}
> >>>          mailer.append_options(optargs)
> >>>          opts = options.load(sys.argv,
> >>>                              optargs = optargs,
> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
> >>>              raise error.general('RTEMS BSP not provided or an invalid
> >>> option')
> >>>          bsp = config.load(bsp[1], opts)
> >>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
> >>> +        coverage_enabled = opts.find_arg('--coverage')
> >>> +        if coverage_enabled:
> >>> +            if len(coverage_enabled) == 2:
> >> Is this to check if sets have been provided to --coverage=score,sapi,
> that
> >> kind of thing? If so the variable name coverage_enabled doesn't make
> sense
> >> any more. Probably if symbol_sets and if len(symbol_sets) will make more
> >> sense for both cases.
> > That's a good point.
> > How about changing it to just 'coverage' instead ?
> > Because it's still checking whether the option is given or
> > not. symbol_sets might create confusion.
> > Will that be OK ?
> That name might collide with your class object (coverage)?
That's actually why I kept it as coverage_enabled.
I think we can go for coverage_option (?)
> >>> +                coverage_runner = coverage.coverage_run(opts.
> defaults,
> >>> +                                                coverage_enabled[1],
> opts.defaults['target'])
> >>> +            else:
> defaults,
> >>> 0,
> >>>          report_mode = opts.find_arg('--report-mode')
> >>>          if report_mode:
> >>>              if report_mode[1] != 'failures' and \
> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
> >>>                      reports.failures(),
> >>>                      'Log', '===', ''] + output.get()
> >>>              mail.send(to_addr, subject, os.linesep.join(body))
> >>> +            coverage_run(opts, coverage_runner, executables)
> >>>      except error.general as gerr:
> >>>          print(gerr)
> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> index 6b5e7e6..2f89117 100644
> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>> @@ -31,9 +31,10 @@
> >>>  # The Leon 3 QEMU BSP
> >>> -[leon3-qemu]
> >>> +[leon3-qemu-cov]
> >>>  bsp               = leon3-qemu
> >>>  arch              = sparc
> >>> +target            = sparc-rtems5
> >>>  tester            = %{_rtscripts}/qemu.cfg
> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
> >>> index 0000000..a2ec7bc
> >>> --- /dev/null
> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> >>> @@ -0,0 +1,36 @@
> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
> are
> >>> met:
> >>> notice,
> >>> notice,
> >>> documentation
> >>> "AS IS"
> TO,
> >>> THE
> >>> PURPOSE
> CONTRIBUTORS
> >>> BE
> >>> BUSINESS
> >>> IN
> >>> OTHERWISE)
> OF
> >>> THE
> >>> +[symbol-sets]
> >>> +sets = score,rtems
> >>> +[libraries]
> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> >>> diff --git a/tester/rtems/testing/qemu.cfg
> >>> b/tester/rtems/testing/qemu.cfg
> >>> index bfcd2f5..52a3752 100644
> >>> --- a/tester/rtems/testing/qemu.cfg
> >>> +++ b/tester/rtems/testing/qemu.cfg
> >>> @@ -51,8 +51,8 @@
> >>>  # Qemu common option patterns.
> >>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
> >>> -nographic
> >>> -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
> >>> -nographic
> >>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
> >>> -nographic
> >>> +#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
> >>> -nographic
> >>>  %define qemu_opts_no_net -net none
> >>> 2.14.3
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/1c78aafd/attachment-0002.html>
