[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu May 31 21:04:44 UTC 2018
On 1 June 2018 at 02:15, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, May 31, 2018 at 4:44 PM, Cillian O'Donnell
> <cpodonnell8 at gmail.com> wrote:
> > There is now a seperate bsp config for coverage, leon3-qemu-cov. That is
> > enough to trigger coverage now and --coverage could be reserved for
> picking
> > sets, probably renamed to --coverage-sets=... Or require sets to be
> chosen
> > --coverage-sets=all or specific sets --coverage-sets=score,sapi,core
> Yes, and it should work for more than 1 or 2.
> It can work for any number of sets.
> > On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
> vijaykumar9597 at gmail.com>
> > wrote:
> >> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
> >>> So is it checking whether it's --coverage or --coverage=set1,set2? Are
> >>> those the 2 possibilities your checking?
> >> Yes, right. :)
> >>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee,
> >>> <vijaykumar9597 at gmail.com> wrote:
> >>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
> >>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
> >>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
> >>>>> > wrote:
> >>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee
> >>>>> >> wrote:
> >>>>> >>> Add support in tester to run covoar and generate an html report
> to
> >>>>> >>> display
> >>>>> >>> the summary of the coverage reports generated from covoar.
> >>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
> >>>>> >>>  tester/rt/coverage.py                         | 379
> >>>>> >>>  tester/rt/test.py                             |  36 ++-
> >>>>> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
> >>>>> >>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
> >>>>> >>>  tester/rtems/testing/qemu.cfg                 |   4 +-
> >>>>> >>>  5 files changed, 446 insertions(+), 12 deletions(-)
> >>>>> >>>  create mode 100644 tester/rt/coverage.py
> >>>>> >>>  create mode 100644 tester/rtems/testing/coverage/
> symbol-sets.ini
> >>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> >>>>> >>> new file mode 100644
> >>>>> >>> index 0000000..25fbb9d
> >>>>> >>> --- /dev/null
> >>>>> >>> +++ b/tester/rt/coverage.py
> >>>>> >>> @@ -0,0 +1,379 @@
> >>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
> >>>>> >>> +# Copyright 2014 Krzysztof Miesowicz
> >>>>> >>> (krzysztof.miesowicz at gmail.com)
> >>>>> >>> +# All rights reserved.
> >>>>> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> >>>>> >>> +# Redistribution and use in source and binary forms, with or
> >>>>> >>> without
> >>>>> >>> +# modification, are permitted provided that the following
> >>>>> >>> conditions are
> >>>>> >>> met:
> >>>>> >>> +# 1. Redistributions of source code must retain the above
> >>>>> >>> copyright
> >>>>> >>> notice,
> >>>>> >>> +# this list of conditions and the following disclaimer.
> >>>>> >>> +# 2. Redistributions in binary form must reproduce the above
> >>>>> >>> copyright
> >>>>> >>> notice,
> >>>>> >>> +# this list of conditions and the following disclaimer in the
> >>>>> >>> documentation
> >>>>> >>> +# and/or other materials provided with the distribution.
> >>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> >>>>> >>> CONTRIBUTORS
> >>>>> >>> 'AS IS'
> >>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> >>>>> >>> LIMITED TO,
> >>>>> >>> THE
> >>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> >>>>> >>> PARTICULAR
> >>>>> >>> PURPOSE
> >>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> >>>>> >>> CONTRIBUTORS
> >>>>> >>> BE
> >>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> EXEMPLARY,
> >>>>> >>> OR
> >>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> >>>>> >>> PROCUREMENT OF
> >>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
> OR
> >>>>> >>> BUSINESS
> >>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> >>>>> >>> WHETHER
> >>>>> >>> IN
> >>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> >>>>> >>> OTHERWISE)
> >>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> >>>>> >>> ADVISED OF
> >>>>> >>> THE
> >>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
> >>>>> >>> +from rtemstoolkit import error
> >>>>> >>> +from rtemstoolkit import path
> >>>>> >>> +from rtemstoolkit import log
> >>>>> >>> +from rtemstoolkit import execute
> >>>>> >>> +from rtemstoolkit import macros
> >>>>> >>> +from datetime import datetime
> >>>>> >>> +from . import options
> >>>>> >>> +import shutil
> >>>>> >>> +import os
> >>>>> >>> +try:
> >>>>> >>> +    import configparser
> >>>>> >>> +except:
> >>>>> >>> +    import ConfigParser as configparser
> >>>>> >>> +class summary:
> >>>>> >>> +    def __init__(self, p_summary_dir):
> >>>>> >>> +        self.summary_file_path = path.join(p_summary_dir,
> >>>>> >>> 'summary.txt')
> >>>>> >>> +        self.index_file_path = path.join(p_summary_dir,
> >>>>> >>> 'index.html')
> >>>>> >>> +        self.bytes_analyzed = 0
> >>>>> >>> +        self.bytes_not_executed = 0
> >>>>> >>> +        self.percentage_executed = 0.0
> >>>>> >>> +        self.percentage_not_executed = 100.0
> >>>>> >>> +        self.ranges_uncovered = 0
> >>>>> >>> +        self.branches_uncovered = 0
> >>>>> >>> +        self.branches_total = 0
> >>>>> >>> +        self.branches_always_taken = 0
> >>>>> >>> +        self.branches_never_taken = 0
> >>>>> >>> +        self.percentage_branches_covered = 0.0
> >>>>> >>> +        self.is_failure = False
> >>>>> >>> +    def parse(self):
> >>>>> >>> +        if(not path.exists(self.summary_file_path)):
> >>>>> >>> +            log.notice('summary file %s does not exist!' %
> >>>>> >>> +            self.is_failure = True
> >>>>> >>> +            return
> >>>>> >>> +        with open(self.summary_file_path,'r') as summary_file:
> >>>>> >>> self._get_next_with_colon(summary_file)
> >>>>> >>> self._get_next_without_colon(summary_file)
> >>>>> >>> +        if len(self.branches_uncovered) > 0 and
> >>>>> >>> len(self.branches_total)
> >>>>> >>> > 0:
> >>>>> >>> +            self.percentage_branches_covered = \
> >>>>> >>> +            1 - (float(self.branches_uncovered) /
> >>>>> >>> float(self.branches_total))
> >>>>> >>> +        else:
> >>>>> >>> +        return
> >>>>> >>> +    def _get_next_with_colon(self, summary_file):
> >>>>> >>> +        line = summary_file.readline()
> >>>>> >>> +        if ':' in line:
> >>>>> >>> +            return line.split(':')[1].strip()
> >>>>> >>> +        else:
> >>>>> >>> +            return ''
> >>>>> >>> +    def _get_next_without_colon(self, summary_file):
> >>>>> >>> +        return line.strip().split(' ')[0]
> >>>>> >>> +class report_gen_html:
> >>>>> >>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
> >>>>> >>> +        self.symbol_sets_list = ['score']
> >>>>> >>> +        self.build_dir = build_dir
> >>>>> >>> +        self.partial_reports_files = list(["index.html",
> >>>>> >>> "summary.txt"])
> >>>>> >>> +        self.number_of_columns = 1
> >>>>> >>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
> >>>>> >>> +    def _find_partial_reports(self):
> >>>>> >>> +        partial_reports = {}
> >>>>> >>> +        for symbol_set in self.symbol_sets_list:
> >>>>> >>> +            set_summary = summary(path.join(self.build_dir,
> >>>>> >>> "coverage",
> >>>>> >>> +                                  symbol_set))
> >>>>> >>> +            set_summary.parse()
> >>>>> >>> +            partial_reports[symbol_set] = set_summary
> >>>>> >>> +        return partial_reports
> >>>>> >>> +    def _prepare_head_section(self):
> >>>>> >>> +        head_section = '''
> >>>>> >>> +        <head>
> >>>>> >>> +        <title>RTEMS coverage report</title>
> >>>>> >>> +        <style type="text/css">
> >>>>> >>> +            progress[value] {
> >>>>> >>> +              -webkit-appearance: none;
> >>>>> >>> +               appearance: none;
> >>>>> >>> +              width: 150px;
> >>>>> >>> +              height: 15px;
> >>>>> >>> +        </style>
> >>>>> >>> +        </head>'''
> >>>>> >>> +        return head_section
> >>>>> >>> +    def _prepare_index_content(self, partial_reports):
> >>>>> >>> +        header = "<h1> RTEMS coverage analysis report </h1>"
> >>>>> >>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
> >>>>> >>> +        table = "<table>"
> >>>>> >>> +        table += self._header_row()
> >>>>> >>> +        for symbol_set in partial_reports:
> >>>>> >>> +            table += self._row(symbol_set,
> >>>>> >>> partial_reports[symbol_set])
> >>>>> >>> +        table += "</table> </br>"
> >>>>> >>> +        timestamp = "Analysis performed on " +
> >>>>> >>> datetime.now().ctime()
> >>>>> >>> +        return "<body>\n" + header + table + timestamp +
> >>>>> >>> "\n</body>"
> >>>>> >>> +    def _row(self, symbol_set, summary):
> >>>>> >>> +        row = "<tr>"
> >>>>> >>> +        row += "<td>" + symbol_set + "</td>"
> >>>>> >>> +        if summary.is_failure:
> >>>>> >>> +            row += ' <td colspan="' +
> >>>>> >>> str(self.number_of_columns-1) \
> >>>>> >>> +            + '" style="background-color:red">FAILURE</td>'
> >>>>> >>> +        else:
> >>>>> >>> +            row += " <td>" +
> >>>>> >>> self._link(summary.index_file_path,"Index")
> >>>>> >>> +            + "</td>"
> >>>>> >>> +            row += " <td>" +
> >>>>> >>> self._link(summary.summary_file_path,"Summary") \
> >>>>> >>> +            + "</td>"
> >>>>> >>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
> >>>>> >>> +            row += " <td>" + summary.bytes_not_executed +
> "</td>"
> >>>>> >>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
> >>>>> >>> +            row += " <td>" + summary.percentage_executed +
> >>>>> >>> "%</td>"
> >>>>> >>> +            row += " <td>" + summary.percentage_not_executed +
> >>>>> >>> "%</td>"
> >>>>> >>> +            row += ' <td><progress value="' +
> >>>>> >>> summary.percentage_executed \
> >>>>> >>> +            + '" max="100"></progress></td>'
> >>>>> >>> +            row += " <td>" + summary.branches_uncovered +
> "</td>"
> >>>>> >>> +            row += " <td>" + summary.branches_total + "</td>"
> >>>>> >>> +            row += " <td> {:.3%}
> >>>>> >>> </td>".format(summary.percentage_branches_covered)
> >>>>> >>> +            row += ' <td><progress value="{:.3}"
> >>>>> >>> max="100"></progress></td>'.format(100*summary.percentage_
> branches_covered)
> >>>>> >>> +            row += "</tr>\n"
> >>>>> >>> +        return row
> >>>>> >>> +    def _header_row(self):
> >>>>> >>> +        row = "<tr>"
> >>>>> >>> +        row += "<th> Symbols set name </th>"
> >>>>> >>> +        row += "<th> Index file </th>"
> >>>>> >>> +        row += "<th> Summary file </th>"
> >>>>> >>> +        row += "<th> Bytes analyzed </th>"
> >>>>> >>> +        row += "<th> Bytes not executed </th>"
> >>>>> >>> +        row += "<th> Uncovered ranges </th>"
> >>>>> >>> +        row += "<th> Percentage covered </th>"
> >>>>> >>> +        row += "<th> Percentage uncovered </th>"
> >>>>> >>> +        row += "<th> Instruction coverage </th>"
> >>>>> >>> +        row += "<th> Branches uncovered </th>"
> >>>>> >>> +        row += "<th> Branches total </th>"
> >>>>> >>> +        row += "<th> Branches covered percentage </th>"
> >>>>> >>> +        row += "<th> Branches coverage </th>"
> >>>>> >>> +        row += "</tr>\n"
> >>>>> >>> +        self.number_of_columns = row.count('<th>')
> >>>>> >>> +        return row
> >>>>> >>> +    def _link(self, address, text):
> >>>>> >>> +        return '<a href="' + address + '">' + text + '</a>'
> >>>>> >>> +    def _create_index_file(self, head_section, content):
> >>>>> >>> +        with open(path.join(self.build_dir,"report.html"),'w')
> as
> >>>>> >>> f:
> >>>>> >>> +            f.write(head_section)
> >>>>> >>> +            f.write(content)
> >>>>> >>> +    def generate(self):
> >>>>> >>> +        partial_reports = self._find_partial_reports()
> >>>>> >>> +        head_section = self._prepare_head_section()
> >>>>> >>> +        index_content =
> >>>>> >>> self._prepare_index_content(partial_reports)
> >>>>> >>> +        self._create_index_file(head_section,index_content)
> >>>>> >>> +    def add_covoar_src_path(self):
> >>>>> >>> +        table_js_path = path.join(self.covoar_src_path,
> >>>>> >>> 'table.js')
> >>>>> >>> +        covoar_css_path = path.join(self.covoar_src_path,
> >>>>> >>> 'covoar.css')
> >>>>> >>> +            symbol_set_dir = path.join(self.build_dir,
> "coverage",
> >>>>> >>> symbol_set)
> >>>>> >>> +            html_files = os.listdir(symbol_set_dir)
> >>>>> >>> +            for html_file in html_files:
> >>>>> >>> +                html_file = path.join(symbol_set_dir, html_file)
> >>>>> >>> +                if path.exists(html_file) and 'html' in
> html_file:
> >>>>> >>> +                    with open(html_file, 'r') as f:
> >>>>> >>> +                        file_data = f.read()
> >>>>> >>> +                    file_data = file_data.replace('table.js',
> >>>>> >>> table_js_path)
> >>>>> >>> +                    file_data = file_data.replace('covoar.css',
> covoar_css_path)
> >>>>> >>> +                    with open(html_file, 'w') as f:
> >>>>> >>> +                        f.write(file_data)
> >>>>> >>> +class build_path_generator(object):
> >>>>> >>> +    Generates the build path from the path to executables
> >>>>> >>> +    def __init__(self, executables, target):
> >>>>> >>> +        self.executables = executables
> >>>>> >>> +        self.target = target
> >>>>> >>> +    def run(self):
> >>>>> >>> +        build_path = '/'
> >>>>> >>> +        Path = self.executables[0].split('/')
> >>>>> >>> +        for P in Path:
> >>>>> >>> +            if P == self.target:
> >>>>> >>> +                break;
> >>>>> >>> +            else:
> >>>>> >>> +                build_path = path.join(build_path, P)
> >>>>> >>> +        return build_path
> >>>>> >>> +class symbol_parser(object):
> >>>>> >>> +    Parse the symbol sets ini and create custom ini file for
> >>>>> >>> covoar
> >>>>> >>> +    def __init__(self, symbol_config_path,
> >>>>> >>> +                 symbol_select_path, coverage_arg, build_dir):
> >>>>> >>> +        self.symbol_select_file = symbol_select_path
> >>>>> >>> +        self.symbol_file = symbol_config_path
> >>>>> >>> +        self.symbol_sets = {}
> >>>>> >>> +        self.cov_arg = coverage_arg
> >>>>> >>> +        self.ssets = []
> >>>>> >>> +    def parse(self):
> >>>>> >>> +        config = configparser.ConfigParser()
> >>>>> >>> +        try:
> >>>>> >>> +            config.read(self.symbol_file)
> >>>>> >>> +            if self.cov_arg:
> >>>>> >>> +                self.ssets = self.cov_arg.split(',')
> >>>>> >>> +            else:
> >>>>> >>> +                self.ssets = config.get('symbol-sets',
> >>>>> >>> 'sets').split(',')
> >>>>> >>> +                self.ssets = [ sset.encode('utf-8') for sset in
> >>>>> >>> self.ssets]
> >>>>> >>> +            for sset in self.ssets:
> >>>>> >>> +                lib = path.join(self.build_dir,
> >>>>> >>> +                                config.get('libraries', sset))
> >>>>> >>> +                self.symbol_sets[sset] = lib.encode('utf-8')
> >>>>> >>> +        except:
> >>>>> >>> +            raise error.general('Symbol set parsing failed')
> >>>>> >>> +    def _write_ini(self):
> >>>>> >>> +        try:
> >>>>> >>> +            sets = ', '.join(self.symbol_sets.keys())
> >>>>> >>> +            config.add_section('symbol-sets')
> >>>>> >>> +            config.set('symbol-sets', 'sets', sets)
> >>>>> >>> +            for key in self.symbol_sets.keys():
> >>>>> >>> +                config.add_section(key)
> >>>>> >>> +                config.set(key, 'libraries',
> >>>>> >>> self.symbol_sets[key])
> >>>>> >>> +            with open(self.symbol_select_file, 'w') as conf:
> >>>>> >>> +                config.write(conf)
> >>>>> >>> +        except:
> >>>>> >>> +            raise error.general('write failed')
> >>>>> >>> +    def run(self):
> >>>>> >>> +        self.parse()
> >>>>> >>> +        self._write_ini()
> >>>>> >>> +class covoar(object):
> >>>>> >>> +    Covoar runner
> >>>>> >>> +    def __init__(self, base_result_dir, config_dir, executables,
> >>>>> >>> explanations_txt):
> >>>>> >>> +        self.base_result_dir = base_result_dir
> >>>>> >>> +        self.config_dir = config_dir
> >>>>> >>> +        self.executables = ' '.join(executables)
> >>>>> >>> +        self.explanations_txt = explanations_txt
> >>>>> >>> +        self.project_name = 'RTEMS-5'
> >>>>> >>> +    def run(self, set_name, symbol_file):
> >>>>> >>> +        covoar_result_dir = path.join(self.base_result_dir,
> >>>>> >>> set_name)
> >>>>> >>> +        if (not path.exists(covoar_result_dir)):
> >>>>> >>> +            path.mkdir(covoar_result_dir)
> >>>>> >>> +        if (not path.exists(symbol_file)):
> >>>>> >>> +            raise error.general('symbol set file: coverage %s
> was
> >>>>> >>> not
> >>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
> >>>>> >>> +        command = ('covoar -S ' + symbol_file
> >>>>> >>> +                  + ' -O ' + covoar_result_dir
> >>>>> >>> +                  + ' -E ' + self.explanations_txt
> >>>>> >>> +                  + ' -p ' + self.project_name + ' ' +
> >>>>> >>> self.executables)
> >>>>> >>> +        log.notice('Running covoar for %s' % (set_name))
> >>>>> >>> +        print( 'covoar results directory:\n' +
> covoar_result_dir )
> >>>>> >>> +        executor = execute.execute(verbose = True, output =
> >>>>> >>> self.output_handler)
> >>>>> >>> +        exit_code = executor.shell(command, cwd=os.getcwd())
> >>>>> >>> +        if (exit_code[0] != 0):
> >>>>> >>> +            raise error.general('covoar failure exit code: %d' %
> >>>>> >>> (exit_code[0]))
> >>>>> >>> +        log.notice('Coverage run for %s finished successfully.'
> >>>>> >>> (set_name))
> >>>>> >>> log.notice('-----------------------------------------------')
> >>>>> >>> +    def output_handler(self, text):
> >>>>> >>> +        log.notice('%s' % (text))
> >>>>> >>> +class coverage_run(object):
> >>>>> >>> +    Coverage analysis support for rtems-test
> >>>>> >>> +    def __init__(self, p_macros, coverage_arg, target):
> >>>>> >>> +        Constructor
> >>>>> >>> +        self.macros = p_macros
> >>>>> >>> +        self.build_dir = self.macros['_cwd']
> >>>>> >>> self.macros.expand(self.macros['cov_explanations'])
> >>>>> >>> +        self.test_dir = path.join(self.build_dir, 'coverage')
> >>>>> >>> +        if (not path.exists(self.test_dir)):
> >>>>> >>> +            path.mkdir(self.test_dir)
> >>>>> >>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
> >>>>> >>> +        self.rtscripts =
> >>>>> >>> self.macros.expand(self.macros['_rtscripts'])
> >>>>> >>> +        self.coverage_config_path = path.join(self.rtscripts,
> >>>>> >>> 'coverage')
> >>>>> >>> +        self.symbol_config_path =
> >>>>> >>> path.join(self.coverage_config_path,
> >>>>> >>> +                                            'symbol-sets.ini')
> >>>>> >>> +        self.symbol_select_path =
> >>>>> >>> +                                            'symbol-select.ini')
> >>>>> >>> +        self.executables = None
> >>>>> >>> +        self.symbol_sets = []
> >>>>> >>> +        self.no_clean = int(self.macros['_no_clean'])
> >>>>> >>> +        self.report_format = self.macros['cov_report_format']
> >>>>> >>> +        self.coverage_arg = coverage_arg
> >>>>> >>> +    def run(self):
> >>>>> >>> +        try:
> >>>>> >>> +            if self.executables is None:
> >>>>> >>> +                raise error.general('no test executables
> >>>>> >>> provided.')
> >>>>> >>> +            build_dir = build_path_generator(self.executables,
> >>>>> >>> self.target).run()
> >>>>> >>> +            parser = symbol_parser(self.symbol_config_path,
> >>>>> >>> +                                   self.symbol_select_path,
> >>>>> >>> +                                   self.coverage_arg,
> >>>>> >>> +                                   build_dir)
> >>>>> >>> +            parser.run()
> >>>>> >>> +            covoar_runner = covoar(self.test_dir,
> >>>>> >>> +                                   self.executables,
> >>>>> >>> self.explanations_txt)
> >>>>> >>> +            covoar_runner.run('score', self.symbol_select_path)
> >>>>> >>> +            self._generate_reports();
> >>>>> >>> +            self._summarize();
> >>>>> >>> +        finally:
> >>>>> >>> +            self._cleanup();
> >>>>> >>> +    def _generate_reports(self):
> >>>>> >>> +        log.notice('Generating reports')
> >>>>> >>> +        if self.report_format == 'html':
> >>>>> >>> +            report = report_gen_html(self.symbol_sets,
> >>>>> >>> +                                     self.build_dir,
> >>>>> >>> +                                     self.rtdir)
> >>>>> >>> +            report.generate()
> >>>>> >>> +            report.add_covoar_src_path()
> >>>>> >>> +    def _cleanup(self):
> >>>>> >>> +        if not self.no_clean:
> >>>>> >>> +            log.notice('***Cleaning tempfiles***')
> >>>>> >>> +            for exe in self.executables:
> >>>>> >>> +                trace_file = exe + '.cov'
> >>>>> >>> +                if path.exists(trace_file):
> >>>>> >>> +                    os.remove(trace_file)
> >>>>> >>> +    def _summarize(self):
> >>>>> >>> +        log.notice('Coverage analysis finished. You can find
> >>>>> >>> results in
> >>>>> >>> %s' % (self.build_dir))
> >>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
> >>>>> >>> index f4d9b5c..84dff01 100644
> >>>>> >>> --- a/tester/rt/test.py
> >>>>> >>> +++ b/tester/rt/test.py
> >>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
> >>>>> >>>  from rtemstoolkit import reraise
> >>>>> >>>  from rtemstoolkit import stacktraces
> >>>>> >>>  from rtemstoolkit import version
> >>>>> >>> +from rtemstoolkit import check
> >>>>> >>>  from . import bsps
> >>>>> >>>  from . import config
> >>>>> >>>  from . import console
> >>>>> >>>  from . import report
> >>>>> >>> +from . import coverage
> >>>>> >>>  class log_capture(object):
> >>>>> >>>      def __init__(self):
> >>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
> >>>>> >>>      def run(self):
> >>>>> >>>          self.thread = threading.Thread(target = self.runner,
> >>>>> >>> -                                       name = 'test[%s]' %
> >>>>> >>> path.basename(self.executable))
> >>>>> >>> +                            name = 'test[%s]' %
> >>>>> >>>          self.thread.start()
> >>>>> >>>      def is_alive(self):
> >>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
> >>>>> >>>      for test in tests:
> >>>>> >>>          test.kill()
> >>>>> >>> +def coverage_run(opts, coverage, executables):
> >>>>> >>> +    coverage.executables = executables
> >>>>> >>> +    coverage.run()
> >>>>> >>>  def run(command_path = None):
> >>>>> >>>      import sys
> >>>>> >>>      tests = []
> >>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
> >>>>> >>>      opts = None
> >>>>> >>>      default_exefilter = '*.exe'
> >>>>> >>>      try:
> >>>>> >>> -        optargs = { '--rtems-tools': 'The path to the RTEMS
> >>>>> >>> tools',
> >>>>> >>> -                    '--rtems-bsp':   'The RTEMS BSP to run the
> >>>>> >>> test on',
> >>>>> >>> -                    '--user-config': 'Path to your local user
> >>>>> >>> configuration INI file',
> >>>>> >>> -                    '--report-mode': 'Reporting modes, failures
> >>>>> >>> (default),all,none',
> >>>>> >>> -                    '--list-bsps':   'List the supported BSPs',
> >>>>> >>> -                    '--debug-trace': 'Debug trace based on
> >>>>> >>> specific
> >>>>> >>> flags',
> >>>>> >>> -                    '--filter':      'Glob that executables must
> >>>>> >>> match
> >>>>> >>> to run (default: ' +
> >>>>> >>> +        optargs = { '--rtems-tools':    'The path to the RTEMS
> >>>>> >>> tools',
> >>>>> >>> +                    '--rtems-bsp':      'The RTEMS BSP to run
> the
> >>>>> >>> test
> >>>>> >>> on',
> >>>>> >>> +                    '--user-config':    'Path to your local user
> >>>>> >>> +                    '--report-mode':    'Reporting modes,
> failures
> >>>>> >>> +                    '--list-bsps':      'List the supported
> BSPs',
> >>>>> >>> +                    '--debug-trace':    'Debug trace based on
> >>>>> >>> specific
> >>>>> >>> flags',
> >>>>> >>> +                    '--filter':         'Glob that executables
> >>>>> >>> must
> >>>>> >>> match to run (default: ' +
> >>>>> >>>                                default_exefilter + ')',
> >>>>> >>> -                    '--stacktrace':  'Dump a stack trace on a
> user
> >>>>> >>> termination (^C)' }
> >>>>> >>> +                    '--stacktrace':     'Dump a stack trace on a
> >>>>> >>> user
> >>>>> >>> termination (^C)',
> >>>>> >>> +                    '--coverage':       'Perform coverage
> analysis
> >>>>> >>> of
> >>>>> >>> test executables.'}
> >>>>> >>>          mailer.append_options(optargs)
> >>>>> >>>          opts = options.load(sys.argv,
> >>>>> >>>                              optargs = optargs,
> >>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
> >>>>> >>>              raise error.general('RTEMS BSP not provided or an
> >>>>> >>> invalid
> >>>>> >>> option')
> >>>>> >>>          bsp = config.load(bsp[1], opts)
> >>>>> >>>          bsp_config = opts.defaults.expand(opts.
> defaults['tester'])
> >>>>> >>> +        coverage_enabled = opts.find_arg('--coverage')
> >>>>> >>> +        if coverage_enabled:
> >>>>> >>> +            if len(coverage_enabled) == 2:
> >>>>> >> Is this to check if sets have been provided to
> >>>>> >> --coverage=score,sapi, that
> >>>>> >> kind of thing? If so the variable name coverage_enabled doesn't
> make
> >>>>> >> sense
> >>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will
> make
> >>>>> >> more
> >>>>> >> sense for both cases.
> >>>>> > That's a good point.
> >>>>> > How about changing it to just 'coverage' instead ?
> >>>>> > Because it's still checking whether the option is given or
> >>>>> > not. symbol_sets might create confusion.
> >>>>> > Will that be OK ?
> >>>>> That name might collide with your class object (coverage)?
> >>>> That's actually why I kept it as coverage_enabled.
> >>>> I think we can go for coverage_option (?)
> >>>>> >>> +                coverage_runner =
> >>>>> >>> coverage.coverage_run(opts.defaults,
> >>>>> >>> coverage_enabled[1],
> >>>>> >>> opts.defaults['target'])
> >>>>> >>> +            else:
> >>>>> >>> +                coverage_runner =
> >>>>> >>> 0,
> >>>>> >>>          report_mode = opts.find_arg('--report-mode')
> >>>>> >>>          if report_mode:
> >>>>> >>>              if report_mode[1] != 'failures' and \
> >>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
> >>>>> >>>                      reports.failures(),
> >>>>> >>>                      'Log', '===', ''] + output.get()
> >>>>> >>>              mail.send(to_addr, subject, os.linesep.join(body))
> >>>>> >>> +            coverage_run(opts, coverage_runner, executables)
> >>>>> >>>      except error.general as gerr:
> >>>>> >>>          print(gerr)
> >>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>>>> >>> index 6b5e7e6..2f89117 100644
> >>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
> >>>>> >>> @@ -31,9 +31,10 @@
> >>>>> >>>  # The Leon 3 QEMU BSP
> >>>>> >>> -[leon3-qemu]
> >>>>> >>> +[leon3-qemu-cov]
> >>>>> >>>  bsp               = leon3-qemu
> >>>>> >>>  arch              = sparc
> >>>>> >>> +target            = sparc-rtems5
> >>>>> >>>  tester            = %{_rtscripts}/qemu.cfg
> >>>>> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
> >>>>> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
> >>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
> >>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
> >>>>> >>> index 0000000..a2ec7bc
> >>>>> >>> --- /dev/null
> >>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> >>>>> >>> @@ -0,0 +1,36 @@
> >>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
> >>>>> >>> without
> >>>>> >>> conditions are
> >>>>> >>> met:
> >>>>> >>> copyright
> >>>>> >>> notice,
> >>>>> >>> copyright
> >>>>> >>> notice,
> >>>>> >>> documentation
> >>>>> >>> CONTRIBUTORS
> >>>>> >>> "AS IS"
> >>>>> >>> LIMITED TO,
> >>>>> >>> THE
> >>>>> >>> PARTICULAR
> >>>>> >>> PURPOSE
> >>>>> >>> CONTRIBUTORS
> >>>>> >>> BE
> EXEMPLARY,
> >>>>> >>> OR
> >>>>> >>> PROCUREMENT OF
> OR
> >>>>> >>> BUSINESS
> >>>>> >>> WHETHER
> >>>>> >>> IN
> >>>>> >>> OTHERWISE)
> >>>>> >>> ADVISED OF
> >>>>> >>> THE
> >>>>> >>> +[symbol-sets]
> >>>>> >>> +sets = score,rtems
> >>>>> >>> +[libraries]
> >>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> >>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> >>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
> >>>>> >>> b/tester/rtems/testing/qemu.cfg
> >>>>> >>> index bfcd2f5..52a3752 100644
> >>>>> >>> --- a/tester/rtems/testing/qemu.cfg
> >>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
> >>>>> >>> @@ -51,8 +51,8 @@
> >>>>> >>>  # Qemu common option patterns.
> >>>>> >>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
> >>>>> >>> -nographic
> >>>>> >>> -%define qemu_opts_base   -no-reboot -serial null -serial
> mon:stdio
> >>>>> >>> -nographic
> >>>>> >>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
> >>>>> >>> -nographic
> >>>>> >>> +#%define qemu_opts_base   -no-reboot -serial null -serial
> >>>>> >>> mon:stdio
> >>>>> >>> -nographic
> >>>>> >>>  %define qemu_opts_no_net -net none
> >>>>> >>> 2.14.3
> >>>>> >>> _______________________________________________
> >>>>> >>> devel mailing list
> >>>>> >>> devel at rtems.org
> >>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
> >>>>> > devel mailing list
> >>>>> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/e82b73fe/attachment-0002.html>
