[PATCH v2] tester: Add script to generate html coverage report from covoar output
Thu May 31 21:20:03 UTC 2018
On Thu, May 31, 2018 at 4:15 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
wrote:
> On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> There is now a seperate bsp config for coverage, leon3-qemu-cov. That is
>>> enough to trigger coverage now and --coverage could be reserved for picking
>>> sets, probably renamed to --coverage-sets=... Or require sets to be chosen
>>> --coverage-sets=all or specific sets --coverage-sets=score,sapi,core
>>> Actually the idea of having separate bsp configs for cov
>> in each of the bsps will create a lot of files. The intention is
>> to make it simple for the user. just adding --coverage
>> should run coverage analysis. There's a plan to include
>> the 'coverage' section into the bsp ini file, and hence the user wouldn't
>> have to keep switching the bsp config files.
> Actually that's exactly the way I had it working before Chris' recent
> changes, he had a look at the way it's working and chose to create seperate
> bsp config files. That may be the way he'd prefer. This was before the
> --coverage option had another use other than triggering coverage, so his
> thoughts may have changed on it.
Chris should comment on the separate ini files. I think that might have been
driven by couverture vs regular qemu before couverture was available from
the RSB.
I think it would be nice to have --coverage and if the BSP ini file doesn't
support
coverage, give an error.
Is the set option in the Python and processed by covoar in a way that still
lets covoar be used on something besides RTEMS?
>> The idea of modifying it to --coverage-sets=all ;
>> --coverage-sets=set1,set2,set3..... can surely be implemented
>> in place of --coverage ; --coverage=set1,set2....
>>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> So is it checking whether it's --coverage or --coverage=set1,set2? Are
>>>>> those the 2 possibilities your checking?
>>>>> Yes, right. :)
>>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>>> >> wrote:
>>>>>>> >>> Add support in tester to run covoar and generate an html report
>>>>>>> to
>>>>>>> >>> display
>>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> >>>  tester/rt/coverage.py                         | 379
>>>>>>> >>>  tester/rt/test.py                             |  36 ++-
>>>>>>> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>>>> >>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>>>> >>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>>>> >>>  5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>>> >>>  create mode 100644 tester/rt/coverage.py
>>>>>>> >>>  create mode 100644 tester/rtems/testing/coverage/
>>>>>>> symbol-sets.ini
>>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>>> >>> new file mode 100644
>>>>>>> >>> index 0000000..25fbb9d
>>>>>>> >>> --- /dev/null
>>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>>> >>> +# All rights reserved.
>>>>>>> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>>> >>> +# Redistribution and use in source and binary forms, with or
>>>>>>> without
>>>>>>> >>> +# modification, are permitted provided that the following
>>>>>>> conditions are
>>>>>>> >>> met:
>>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>>> copyright
>>>>>>> >>> notice,
>>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>>>>>> copyright
>>>>>>> >>> notice,
>>>>>>> >>> +# this list of conditions and the following disclaimer in the
>>>>>>> >>> documentation
>>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>> CONTRIBUTORS
>>>>>>> >>> 'AS IS'
>>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>> LIMITED TO,
>>>>>>> >>> THE
>>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>> PARTICULAR
>>>>>>> >>> PURPOSE
>>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>> CONTRIBUTORS
>>>>>>> >>> BE
>>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>> EXEMPLARY, OR
>>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>> PROCUREMENT OF
>>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
>>>>>>> OR
>>>>>>> >>> BUSINESS
>>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>> WHETHER
>>>>>>> >>> IN
>>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>> >>> OTHERWISE)
>>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>> ADVISED OF
>>>>>>> >>> THE
>>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>>> >>> +from rtemstoolkit import error
>>>>>>> >>> +from rtemstoolkit import path
>>>>>>> >>> +from rtemstoolkit import log
>>>>>>> >>> +from rtemstoolkit import execute
>>>>>>> >>> +from rtemstoolkit import macros
>>>>>>> >>> +from datetime import datetime
>>>>>>> >>> +from . import options
>>>>>>> >>> +import shutil
>>>>>>> >>> +import os
>>>>>>> >>> +try:
>>>>>>> >>> +    import configparser
>>>>>>> >>> +except:
>>>>>>> >>> +    import ConfigParser as configparser
>>>>>>> >>> +class summary:
>>>>>>> >>> +    def __init__(self, p_summary_dir):
>>>>>>> >>> +        self.summary_file_path = path.join(p_summary_dir,
>>>>>>> 'summary.txt')
>>>>>>> >>> +        self.index_file_path = path.join(p_summary_dir,
>>>>>>> 'index.html')
>>>>>>> >>> +        self.bytes_analyzed = 0
>>>>>>> >>> +        self.bytes_not_executed = 0
>>>>>>> >>> +        self.percentage_executed = 0.0
>>>>>>> >>> +        self.percentage_not_executed = 100.0
>>>>>>> >>> +        self.ranges_uncovered = 0
>>>>>>> >>> +        self.branches_uncovered = 0
>>>>>>> >>> +        self.branches_total = 0
>>>>>>> >>> +        self.branches_always_taken = 0
>>>>>>> >>> +        self.branches_never_taken = 0
>>>>>>> >>> +        self.percentage_branches_covered = 0.0
>>>>>>> >>> +        self.is_failure = False
>>>>>>> >>> +    def parse(self):
>>>>>>> >>> +        if(not path.exists(self.summary_file_path)):
>>>>>>> >>> +            log.notice('summary file %s does not exist!' %
>>>>>>> >>> +            self.is_failure = True
>>>>>>> >>> +            return
>>>>>>> >>> +        with open(self.summary_file_path,'r') as summary_file:
>>>>>>> >>> +           self.bytes_analyzed = self._get_next_with_colon(
>>>>>>> summary_file)
>>>>>>> >>> self._get_next_with_colon(summary_file)
>>>>>>> >>> +           self.branches_total = self._get_next_with_colon(
>>>>>>> summary_file)
>>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>>> >>> +        if len(self.branches_uncovered) > 0 and
>>>>>>> len(self.branches_total)
>>>>>>> >>> > 0:
>>>>>>> >>> +            self.percentage_branches_covered = \
>>>>>>> >>> +            1 - (float(self.branches_uncovered) /
>>>>>>> >>> float(self.branches_total))
>>>>>>> >>> +        else:
>>>>>>> >>> +        return
>>>>>>> >>> +    def _get_next_with_colon(self, summary_file):
>>>>>>> >>> +        line = summary_file.readline()
>>>>>>> >>> +        if ':' in line:
>>>>>>> >>> +            return line.split(':')[1].strip()
>>>>>>> >>> +        else:
>>>>>>> >>> +            return ''
>>>>>>> >>> +    def _get_next_without_colon(self, summary_file):
>>>>>>> >>> +        return line.strip().split(' ')[0]
>>>>>>> >>> +class report_gen_html:
>>>>>>> >>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>>>>> >>> +        self.symbol_sets_list = ['score']
>>>>>>> >>> +        self.build_dir = build_dir
>>>>>>> >>> +        self.partial_reports_files = list(["index.html",
>>>>>>> "summary.txt"])
>>>>>>> >>> +        self.number_of_columns = 1
>>>>>>> >>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>>> >>> +    def _find_partial_reports(self):
>>>>>>> >>> +        partial_reports = {}
>>>>>>> >>> +        for symbol_set in self.symbol_sets_list:
>>>>>>> >>> +            set_summary = summary(path.join(self.build_dir,
>>>>>>> "coverage",
>>>>>>> >>> +                                  symbol_set))
>>>>>>> >>> +            set_summary.parse()
>>>>>>> >>> +            partial_reports[symbol_set] = set_summary
>>>>>>> >>> +        return partial_reports
>>>>>>> >>> +    def _prepare_head_section(self):
>>>>>>> >>> +        head_section = '''
>>>>>>> >>> +        <head>
>>>>>>> >>> +        <title>RTEMS coverage report</title>
>>>>>>> >>> +        <style type="text/css">
>>>>>>> >>> +            progress[value] {
>>>>>>> >>> +              -webkit-appearance: none;
>>>>>>> >>> +               appearance: none;
>>>>>>> >>> +              width: 150px;
>>>>>>> >>> +              height: 15px;
>>>>>>> >>> +        </style>
>>>>>>> >>> +        </head>'''
>>>>>>> >>> +        return head_section
>>>>>>> >>> +    def _prepare_index_content(self, partial_reports):
>>>>>>> >>> +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>>>>> >>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>>>> >>> +        table = "<table>"
>>>>>>> >>> +        table += self._header_row()
>>>>>>> >>> +        for symbol_set in partial_reports:
>>>>>>> >>> +            table += self._row(symbol_set,
>>>>>>> partial_reports[symbol_set])
>>>>>>> >>> +        table += "</table> </br>"
>>>>>>> >>> +        timestamp = "Analysis performed on " +
>>>>>>> datetime.now().ctime()
>>>>>>> >>> +        return "<body>\n" + header + table + timestamp +
>>>>>>> "\n</body>"
>>>>>>> >>> +    def _row(self, symbol_set, summary):
>>>>>>> >>> +        row = "<tr>"
>>>>>>> >>> +        row += "<td>" + symbol_set + "</td>"
>>>>>>> >>> +        if summary.is_failure:
>>>>>>> >>> +            row += ' <td colspan="' +
>>>>>>> str(self.number_of_columns-1) \
>>>>>>> >>> +            + '" style="background-color:red">FAILURE</td>'
>>>>>>> >>> +        else:
>>>>>>> >>> +            row += " <td>" + self._link(summary.index_file_
>>>>>>> path,"Index")
>>>>>>> >>> +            + "</td>"
>>>>>>> >>> +            row += " <td>" +
>>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>>> >>> +            + "</td>"
>>>>>>> >>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>>>> >>> +            row += " <td>" + summary.bytes_not_executed +
>>>>>>> "</td>"
>>>>>>> >>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
>>>>>>> >>> +            row += " <td>" + summary.percentage_executed +
>>>>>>> "%</td>"
>>>>>>> >>> +            row += " <td>" + summary.percentage_not_executed +
>>>>>>> "%</td>"
>>>>>>> >>> +            row += ' <td><progress value="' +
>>>>>>> >>> summary.percentage_executed \
>>>>>>> >>> +            + '" max="100"></progress></td>'
>>>>>>> >>> +            row += " <td>" + summary.branches_uncovered +
>>>>>>> "</td>"
>>>>>>> >>> +            row += " <td>" + summary.branches_total + "</td>"
>>>>>>> >>> +            row += " <td> {:.3%}
>>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>>> >>> +            row += ' <td><progress value="{:.3}"
>>>>>>> >>> max="100"></progress></td>'.format(100*summary.percentage_
>>>>>>> branches_covered)
>>>>>>> >>> +            row += "</tr>\n"
>>>>>>> >>> +        return row
>>>>>>> >>> +    def _header_row(self):
>>>>>>> >>> +        row = "<tr>"
>>>>>>> >>> +        row += "<th> Symbols set name </th>"
>>>>>>> >>> +        row += "<th> Index file </th>"
>>>>>>> >>> +        row += "<th> Summary file </th>"
>>>>>>> >>> +        row += "<th> Bytes analyzed </th>"
>>>>>>> >>> +        row += "<th> Bytes not executed </th>"
>>>>>>> >>> +        row += "<th> Uncovered ranges </th>"
>>>>>>> >>> +        row += "<th> Percentage covered </th>"
>>>>>>> >>> +        row += "<th> Percentage uncovered </th>"
>>>>>>> >>> +        row += "<th> Instruction coverage </th>"
>>>>>>> >>> +        row += "<th> Branches uncovered </th>"
>>>>>>> >>> +        row += "<th> Branches total </th>"
>>>>>>> >>> +        row += "<th> Branches covered percentage </th>"
>>>>>>> >>> +        row += "<th> Branches coverage </th>"
>>>>>>> >>> +        row += "</tr>\n"
>>>>>>> >>> +        self.number_of_columns = row.count('<th>')
>>>>>>> >>> +        return row
>>>>>>> >>> +    def _link(self, address, text):
>>>>>>> >>> +        return '<a href="' + address + '">' + text + '</a>'
>>>>>>> >>> +    def _create_index_file(self, head_section, content):
>>>>>>> >>> +        with open(path.join(self.build_dir,"report.html"),'w')
>>>>>>> as f:
>>>>>>> >>> +            f.write(head_section)
>>>>>>> >>> +            f.write(content)
>>>>>>> >>> +    def generate(self):
>>>>>>> >>> +        partial_reports = self._find_partial_reports()
>>>>>>> >>> +        head_section = self._prepare_head_section()
>>>>>>> >>> +        index_content = self._prepare_index_content(
>>>>>>> partial_reports)
>>>>>>> >>> +        self._create_index_file(head_section,index_content)
>>>>>>> >>> +    def add_covoar_src_path(self):
>>>>>>> >>> +        table_js_path = path.join(self.covoar_src_path,
>>>>>>> 'table.js')
>>>>>>> >>> +        covoar_css_path = path.join(self.covoar_src_path,
>>>>>>> 'covoar.css')
>>>>>>> >>> +            symbol_set_dir = path.join(self.build_dir,
>>>>>>> "coverage",
>>>>>>> >>> symbol_set)
>>>>>>> >>> +            html_files = os.listdir(symbol_set_dir)
>>>>>>> >>> +            for html_file in html_files:
>>>>>>> >>> +                html_file = path.join(symbol_set_dir, html_file)
>>>>>>> >>> +                if path.exists(html_file) and 'html' in
>>>>>>> html_file:
>>>>>>> >>> +                    with open(html_file, 'r') as f:
>>>>>>> >>> +                        file_data = f.read()
>>>>>>> >>> +                    file_data = file_data.replace('table.js',
>>>>>>> >>> table_js_path)
>>>>>>> >>> +                    file_data = file_data.replace('covoar.css',
>>>>>>> covoar_css_path)
>>>>>>> >>> +                    with open(html_file, 'w') as f:
>>>>>>> >>> +                        f.write(file_data)
>>>>>>> >>> +class build_path_generator(object):
>>>>>>> >>> +    Generates the build path from the path to executables
>>>>>>> >>> +    def __init__(self, executables, target):
>>>>>>> >>> +        self.executables = executables
>>>>>>> >>> +        self.target = target
>>>>>>> >>> +    def run(self):
>>>>>>> >>> +        build_path = '/'
>>>>>>> >>> +        Path = self.executables[0].split('/')
>>>>>>> >>> +        for P in Path:
>>>>>>> >>> +            if P == self.target:
>>>>>>> >>> +                break;
>>>>>>> >>> +            else:
>>>>>>> >>> +                build_path = path.join(build_path, P)
>>>>>>> >>> +        return build_path
>>>>>>> >>> +class symbol_parser(object):
>>>>>>> >>> +    Parse the symbol sets ini and create custom ini file for
>>>>>>> covoar
>>>>>>> >>> +    def __init__(self, symbol_config_path,
>>>>>>> >>> +                 symbol_select_path, coverage_arg, build_dir):
>>>>>>> >>> +        self.symbol_select_file = symbol_select_path
>>>>>>> >>> +        self.symbol_file = symbol_config_path
>>>>>>> >>> +        self.symbol_sets = {}
>>>>>>> >>> +        self.cov_arg = coverage_arg
>>>>>>> >>> +        self.ssets = []
>>>>>>> >>> +    def parse(self):
>>>>>>> >>> +        config = configparser.ConfigParser()
>>>>>>> >>> +        try:
>>>>>>> >>> +            config.read(self.symbol_file)
>>>>>>> >>> +            if self.cov_arg:
>>>>>>> >>> +                self.ssets = self.cov_arg.split(',')
>>>>>>> >>> +            else:
>>>>>>> >>> +                self.ssets = config.get('symbol-sets',
>>>>>>> >>> 'sets').split(',')
>>>>>>> >>> +                self.ssets = [ sset.encode('utf-8') for sset in
>>>>>>> >>> self.ssets]
>>>>>>> >>> +            for sset in self.ssets:
>>>>>>> >>> +                lib = path.join(self.build_dir,
>>>>>>> >>> +                                config.get('libraries', sset))
>>>>>>> >>> +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>>>>> >>> +        except:
>>>>>>> >>> +            raise error.general('Symbol set parsing failed')
>>>>>>> >>> +    def _write_ini(self):
>>>>>>> >>> +        try:
>>>>>>> >>> +            sets = ', '.join(self.symbol_sets.keys())
>>>>>>> >>> +            config.add_section('symbol-sets')
>>>>>>> >>> +            config.set('symbol-sets', 'sets', sets)
>>>>>>> >>> +            for key in self.symbol_sets.keys():
>>>>>>> >>> +                config.add_section(key)
>>>>>>> >>> +                config.set(key, 'libraries',
>>>>>>> self.symbol_sets[key])
>>>>>>> >>> +            with open(self.symbol_select_file, 'w') as conf:
>>>>>>> >>> +                config.write(conf)
>>>>>>> >>> +        except:
>>>>>>> >>> +            raise error.general('write failed')
>>>>>>> >>> +    def run(self):
>>>>>>> >>> +        self.parse()
>>>>>>> >>> +        self._write_ini()
>>>>>>> >>> +class covoar(object):
>>>>>>> >>> +    Covoar runner
>>>>>>> >>> +    def __init__(self, base_result_dir, config_dir, executables,
>>>>>>> >>> explanations_txt):
>>>>>>> >>> +        self.base_result_dir = base_result_dir
>>>>>>> >>> +        self.config_dir = config_dir
>>>>>>> >>> +        self.executables = ' '.join(executables)
>>>>>>> >>> +        self.explanations_txt = explanations_txt
>>>>>>> >>> +        self.project_name = 'RTEMS-5'
>>>>>>> >>> +    def run(self, set_name, symbol_file):
>>>>>>> >>> +        covoar_result_dir = path.join(self.base_result_dir,
>>>>>>> set_name)
>>>>>>> >>> +        if (not path.exists(covoar_result_dir)):
>>>>>>> >>> +            path.mkdir(covoar_result_dir)
>>>>>>> >>> +        if (not path.exists(symbol_file)):
>>>>>>> >>> +            raise error.general('symbol set file: coverage %s
>>>>>>> was not
>>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>>> >>> +        command = ('covoar -S ' + symbol_file
>>>>>>> >>> +                  + ' -O ' + covoar_result_dir
>>>>>>> >>> +                  + ' -E ' + self.explanations_txt
>>>>>>> >>> +                  + ' -p ' + self.project_name + ' ' +
>>>>>>> self.executables)
>>>>>>> >>> +        log.notice('Running covoar for %s' % (set_name))
>>>>>>> >>> +        print( 'covoar results directory:\n' +
>>>>>>> covoar_result_dir )
>>>>>>> >>> +        executor = execute.execute(verbose = True, output =
>>>>>>> >>> self.output_handler)
>>>>>>> >>> +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>>>>> >>> +        if (exit_code[0] != 0):
>>>>>>> >>> +            raise error.general('covoar failure exit code: %d' %
>>>>>>> >>> (exit_code[0]))
>>>>>>> >>> +        log.notice('Coverage run for %s finished successfully.'
>>>>>>> >>> (set_name))
>>>>>>> >>> +        log.notice('------------------
>>>>>>> >>> +    def output_handler(self, text):
>>>>>>> >>> +        log.notice('%s' % (text))
>>>>>>> >>> +class coverage_run(object):
>>>>>>> >>> +    Coverage analysis support for rtems-test
>>>>>>> >>> +    def __init__(self, p_macros, coverage_arg, target):
>>>>>>> >>> +        Constructor
>>>>>>> >>> +        self.macros = p_macros
>>>>>>> >>> +        self.build_dir = self.macros['_cwd']
>>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>>> >>> +        self.test_dir = path.join(self.build_dir, 'coverage')
>>>>>>> >>> +        if (not path.exists(self.test_dir)):
>>>>>>> >>> +            path.mkdir(self.test_dir)
>>>>>>> >>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>>> >>> +        self.rtscripts = self.macros.expand(self.
>>>>>>> macros['_rtscripts'])
>>>>>>> >>> +        self.coverage_config_path = path.join(self.rtscripts,
>>>>>>> >>> 'coverage')
>>>>>>> >>> +        self.symbol_config_path = path.join(self.coverage_
>>>>>>> config_path,
>>>>>>> >>> +                                            'symbol-sets.ini')
>>>>>>> >>> +        self.symbol_select_path = path.join(self.coverage_
>>>>>>> config_path,
>>>>>>> >>> +                                            'symbol-select.ini')
>>>>>>> >>> +        self.executables = None
>>>>>>> >>> +        self.symbol_sets = []
>>>>>>> >>> +        self.no_clean = int(self.macros['_no_clean'])
>>>>>>> >>> +        self.report_format = self.macros['cov_report_format']
>>>>>>> >>> +        self.coverage_arg = coverage_arg
>>>>>>> >>> +    def run(self):
>>>>>>> >>> +        try:
>>>>>>> >>> +            if self.executables is None:
>>>>>>> >>> +                raise error.general('no test executables
>>>>>>> provided.')
>>>>>>> >>> +            build_dir = build_path_generator(self.executables,
>>>>>>> >>> self.target).run()
>>>>>>> >>> +            parser = symbol_parser(self.symbol_config_path,
>>>>>>> >>> +                                   self.symbol_select_path,
>>>>>>> >>> +                                   self.coverage_arg,
>>>>>>> >>> +                                   build_dir)
>>>>>>> >>> +            parser.run()
>>>>>>> >>> +            covoar_runner = covoar(self.test_dir,
>>>>>>> >>> +                                   self.executables,
>>>>>>> >>> self.explanations_txt)
>>>>>>> >>> +            covoar_runner.run('score', self.symbol_select_path)
>>>>>>> >>> +            self._generate_reports();
>>>>>>> >>> +            self._summarize();
>>>>>>> >>> +        finally:
>>>>>>> >>> +            self._cleanup();
>>>>>>> >>> +    def _generate_reports(self):
>>>>>>> >>> +        log.notice('Generating reports')
>>>>>>> >>> +        if self.report_format == 'html':
>>>>>>> >>> +            report = report_gen_html(self.symbol_sets,
>>>>>>> >>> +                                     self.build_dir,
>>>>>>> >>> +                                     self.rtdir)
>>>>>>> >>> +            report.generate()
>>>>>>> >>> +            report.add_covoar_src_path()
>>>>>>> >>> +    def _cleanup(self):
>>>>>>> >>> +        if not self.no_clean:
>>>>>>> >>> +            log.notice('***Cleaning tempfiles***')
>>>>>>> >>> +            for exe in self.executables:
>>>>>>> >>> +                trace_file = exe + '.cov'
>>>>>>> >>> +                if path.exists(trace_file):
>>>>>>> >>> +                    os.remove(trace_file)
>>>>>>> >>> +    def _summarize(self):
>>>>>>> >>> +        log.notice('Coverage analysis finished. You can find
>>>>>>> results in
>>>>>>> >>> %s' % (self.build_dir))
>>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>>> >>> --- a/tester/rt/test.py
>>>>>>> >>> +++ b/tester/rt/test.py
>>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>> >>>  from rtemstoolkit import reraise
>>>>>>> >>>  from rtemstoolkit import stacktraces
>>>>>>> >>>  from rtemstoolkit import version
>>>>>>> >>> +from rtemstoolkit import check
>>>>>>> >>>  from . import bsps
>>>>>>> >>>  from . import config
>>>>>>> >>>  from . import console
>>>>>>> >>>  from . import report
>>>>>>> >>> +from . import coverage
>>>>>>> >>>  class log_capture(object):
>>>>>>> >>>      def __init__(self):
>>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>> >>>      def run(self):
>>>>>>> >>>          self.thread = threading.Thread(target = self.runner,
>>>>>>> >>> -                                       name = 'test[%s]' %
>>>>>>> >>> path.basename(self.executable))
>>>>>>> >>> +                            name = 'test[%s]' %
>>>>>>> >>>          self.thread.start()
>>>>>>> >>>      def is_alive(self):
>>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>>> >>>      for test in tests:
>>>>>>> >>>          test.kill()
>>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>>> >>> +    coverage.executables = executables
>>>>>>> >>> +    coverage.run()
>>>>>>> >>>  def run(command_path = None):
>>>>>>> >>>      import sys
>>>>>>> >>>      tests = []
>>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>>> >>>      opts = None
>>>>>>> >>>      default_exefilter = '*.exe'
>>>>>>> >>>      try:
>>>>>>> >>> -        optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>>> tools',
>>>>>>> >>> -                    '--rtems-bsp':   'The RTEMS BSP to run the
>>>>>>> test on',
>>>>>>> >>> -                    '--user-config': 'Path to your local user
>>>>>>> >>> configuration INI file',
>>>>>>> >>> -                    '--report-mode': 'Reporting modes, failures
>>>>>>> >>> (default),all,none',
>>>>>>> >>> -                    '--list-bsps':   'List the supported BSPs',
>>>>>>> >>> -                    '--debug-trace': 'Debug trace based on
>>>>>>> specific
>>>>>>> >>> flags',
>>>>>>> >>> -                    '--filter':      'Glob that executables
>>>>>>> must match
>>>>>>> >>> to run (default: ' +
>>>>>>> >>> +        optargs = { '--rtems-tools':    'The path to the RTEMS
>>>>>>> tools',
>>>>>>> >>> +                    '--rtems-bsp':      'The RTEMS BSP to run
>>>>>>> the test
>>>>>>> >>> on',
>>>>>>> >>> +                    '--user-config':    'Path to your local user
>>>>>>> >>> +                    '--report-mode':    'Reporting modes,
>>>>>>> failures
>>>>>>> >>> +                    '--list-bsps':      'List the supported
>>>>>>> BSPs',
>>>>>>> >>> +                    '--debug-trace':    'Debug trace based on
>>>>>>> specific
>>>>>>> >>> flags',
>>>>>>> >>> +                    '--filter':         'Glob that executables
>>>>>>> must
>>>>>>> >>> match to run (default: ' +
>>>>>>> >>>                                default_exefilter + ')',
>>>>>>> >>> -                    '--stacktrace':  'Dump a stack trace on a
>>>>>>> user
>>>>>>> >>> termination (^C)' }
>>>>>>> >>> +                    '--stacktrace':     'Dump a stack trace on
>>>>>>> a user
>>>>>>> >>> termination (^C)',
>>>>>>> >>> +                    '--coverage':       'Perform coverage
>>>>>>> analysis of
>>>>>>> >>> test executables.'}
>>>>>>> >>>          mailer.append_options(optargs)
>>>>>>> >>>          opts = options.load(sys.argv,
>>>>>>> >>>                              optargs = optargs,
>>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>>> >>>              raise error.general('RTEMS BSP not provided or an
>>>>>>> invalid
>>>>>>> >>> option')
>>>>>>> >>>          bsp = config.load(bsp[1], opts)
>>>>>>> >>>          bsp_config = opts.defaults.expand(opts.
>>>>>>> defaults['tester'])
>>>>>>> >>> +        coverage_enabled = opts.find_arg('--coverage')
>>>>>>> >>> +        if coverage_enabled:
>>>>>>> >>> +            if len(coverage_enabled) == 2:
>>>>>>> >> Is this to check if sets have been provided to
>>>>>>> --coverage=score,sapi, that
>>>>>>> >> kind of thing? If so the variable name coverage_enabled doesn't
>>>>>>> make sense
>>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will
>>>>>>> make more
>>>>>>> >> sense for both cases.
>>>>>>> > That's a good point.
>>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>>> > Because it's still checking whether the option is given or
>>>>>>> > not. symbol_sets might create confusion.
>>>>>>> > Will that be OK ?
>>>>>>> That name might collide with your class object (coverage)?
>>>>>> That's actually why I kept it as coverage_enabled.
>>>>>> I think we can go for coverage_option (?)
>>>>>>> >>> +                coverage_runner = coverage.coverage_run(opts.
>>>>>>> defaults,
>>>>>>> coverage_enabled[1],
>>>>>>> opts.defaults['target'])
>>>>>>> >>> +            else:
>>>>>>> defaults,
>>>>>>> >>> 0,
>>>>>>> >>>          report_mode = opts.find_arg('--report-mode')
>>>>>>> >>>          if report_mode:
>>>>>>> >>>              if report_mode[1] != 'failures' and \
>>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>>> >>>                      reports.failures(),
>>>>>>> >>>                      'Log', '===', ''] + output.get()
>>>>>>> >>>              mail.send(to_addr, subject, os.linesep.join(body))
>>>>>>> >>> +            coverage_run(opts, coverage_runner, executables)
>>>>>>> >>>      except error.general as gerr:
>>>>>>> >>>          print(gerr)
>>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>>> >>>  # The Leon 3 QEMU BSP
>>>>>>> >>> -[leon3-qemu]
>>>>>>> >>> +[leon3-qemu-cov]
>>>>>>> >>>  bsp               = leon3-qemu
>>>>>>> >>>  arch              = sparc
>>>>>>> >>> +target            = sparc-rtems5
>>>>>>> >>>  tester            = %{_rtscripts}/qemu.cfg
>>>>>>> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>>>> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>> >>> index 0000000..a2ec7bc
>>>>>>> >>> --- /dev/null
>>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>>> without
>>>>>>> conditions are
>>>>>>> >>> met:
>>>>>>> copyright
>>>>>>> >>> notice,
>>>>>>> copyright
>>>>>>> >>> notice,
>>>>>>> >>> documentation
>>>>>>> CONTRIBUTORS
>>>>>>> >>> "AS IS"
>>>>>>> LIMITED TO,
>>>>>>> >>> THE
>>>>>>> PARTICULAR
>>>>>>> >>> PURPOSE
>>>>>>> CONTRIBUTORS
>>>>>>> >>> BE
>>>>>>> EXEMPLARY, OR
>>>>>>> PROCUREMENT OF
>>>>>>> OR
>>>>>>> >>> BUSINESS
>>>>>>> WHETHER
>>>>>>> >>> IN
>>>>>>> >>> OTHERWISE)
>>>>>>> ADVISED OF
>>>>>>> >>> THE
>>>>>>> >>> +[symbol-sets]
>>>>>>> >>> +sets = score,rtems
>>>>>>> >>> +[libraries]
>>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>>> >>>  # Qemu common option patterns.
>>>>>>> >>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>>> >>> -nographic
>>>>>>> >>> -%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>> mon:stdio
>>>>>>> >>> -nographic
>>>>>>> >>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>>>> >>> -nographic
>>>>>>> >>> +#%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>> mon:stdio
>>>>>>> >>> -nographic
>>>>>>> >>>  %define qemu_opts_no_net -net none
>>>>>>> >>> 2.14.3
>>>>>>> >>> _______________________________________________
>>>>>>> >>> devel mailing list
>>>>>>> >>> devel at rtems.org
>>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>> > devel mailing list
>>>>>>> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/07de86ce/attachment-0002.html>
