[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Thu May 31 22:18:43 UTC 2018
On Fri, 1 Jun 2018, 03:40 Joel Sherrill, <joel at rtems.org> wrote:
> On Thu, May 31, 2018 at 4:57 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On 1 June 2018 at 02:50, Joel Sherrill <joel at rtems.org> wrote:
>>> On Thu, May 31, 2018 at 4:15 PM, Cillian O'Donnell <
>>> cpodonnell8 at gmail.com> wrote:
>>>> On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <
>>>>> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> There is now a seperate bsp config for coverage, leon3-qemu-cov. That
>>>>>> is enough to trigger coverage now and --coverage could be reserved for
>>>>>> picking sets, probably renamed to --coverage-sets=... Or require sets to be
>>>>>> chosen --coverage-sets=all or specific sets --coverage-sets=score,sapi,core
>>>>>> Actually the idea of having separate bsp configs for cov
>>>>> in each of the bsps will create a lot of files. The intention is
>>>>> to make it simple for the user. just adding --coverage
>>>>> should run coverage analysis. There's a plan to include
>>>>> the 'coverage' section into the bsp ini file, and hence the user
>>>>> wouldn't
>>>>> have to keep switching the bsp config files.
>>>> Actually that's exactly the way I had it working before Chris' recent
>>>> changes, he had a look at the way it's working and chose to create seperate
>>>> bsp config files. That may be the way he'd prefer. This was before the
>>>> --coverage option had another use other than triggering coverage, so his
>>>> thoughts may have changed on it.
>>> Chris should comment on the separate ini files. I think that might have
>>> been
>>> driven by couverture vs regular qemu before couverture was available from
>>> the RSB.
>>> Okay, we wait for Chris to comment on it then.
>>> I think it would be nice to have --coverage and if the BSP ini file
>>> doesn't support
>>> coverage, give an error.
>> Is the set option in the Python and processed by covoar in a way that
>>> still
>>> lets covoar be used on something besides RTEMS?
>> yes, it is totally handled by the script to 'feed' covoar with the
>> options,
>> without changing the way it works.
>> I have a question/doubt.
>> By adding separate bsp config for cov. Are we not assuming that
>> the provided bsp ini supports coverage ?
> I think having two leon3 configurations like we do now is temporary
> just to have something that works. Any changes to the coverage
> version don't impact the baseline.
Understood. Thanks.
> I am hoping Chris has an idea to unified these. :)
>>>>> The idea of modifying it to --coverage-sets=all ;
>>>>> --coverage-sets=set1,set2,set3..... can surely be implemented
>>>>> in place of --coverage ; --coverage=set1,set2....
>>>>>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>>>>>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> So is it checking whether it's --coverage or --coverage=set1,set2?
>>>>>>>> Are those the 2 possibilities your checking?
>>>>>>>> Yes, right. :)
>>>>>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <
>>>>>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>>>>>> >> wrote:
>>>>>>>>>> >>> Add support in tester to run covoar and generate an html
>>>>>>>>>> report to
>>>>>>>>>> >>> display
>>>>>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>>>> >>>  tester/rt/coverage.py                         | 379
>>>>>>>>>> >>>  tester/rt/test.py                             |  36 ++-
>>>>>>>>>> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>>>>>>> >>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>>>>>>> >>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>>>>>>> >>>  5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>>>>>> >>>  create mode 100644 tester/rt/coverage.py
>>>>>>>>>> >>>  create mode 100644
>>>>>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>>>>>> >>> new file mode 100644
>>>>>>>>>> >>> index 0000000..25fbb9d
>>>>>>>>>> >>> --- /dev/null
>>>>>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>>>>>> >>> +# All rights reserved.
>>>>>>>>>> >>> +# This file is part of the RTEMS Tools package in
>>>>>>>>>> 'rtems-tools'.
>>>>>>>>>> >>> +# Redistribution and use in source and binary forms, with or
>>>>>>>>>> without
>>>>>>>>>> >>> +# modification, are permitted provided that the following
>>>>>>>>>> conditions are
>>>>>>>>>> >>> met:
>>>>>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>>>>>> copyright
>>>>>>>>>> >>> notice,
>>>>>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>>>>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>>>>>>>>> copyright
>>>>>>>>>> >>> notice,
>>>>>>>>>> >>> +# this list of conditions and the following disclaimer in the
>>>>>>>>>> >>> documentation
>>>>>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>> >>> 'AS IS'
>>>>>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>>>>> LIMITED TO,
>>>>>>>>>> >>> THE
>>>>>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>>>> PARTICULAR
>>>>>>>>>> >>> PURPOSE
>>>>>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>> >>> BE
>>>>>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
>>>>>>>>>> PROFITS; OR
>>>>>>>>>> >>> BUSINESS
>>>>>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
>>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>>> >>> IN
>>>>>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
>>>>>>>>>> OR
>>>>>>>>>> >>> OTHERWISE)
>>>>>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
>>>>>>>>>> IF ADVISED OF
>>>>>>>>>> >>> THE
>>>>>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>>>>>> >>> +from rtemstoolkit import error
>>>>>>>>>> >>> +from rtemstoolkit import path
>>>>>>>>>> >>> +from rtemstoolkit import log
>>>>>>>>>> >>> +from rtemstoolkit import execute
>>>>>>>>>> >>> +from rtemstoolkit import macros
>>>>>>>>>> >>> +from datetime import datetime
>>>>>>>>>> >>> +from . import options
>>>>>>>>>> >>> +import shutil
>>>>>>>>>> >>> +import os
>>>>>>>>>> >>> +try:
>>>>>>>>>> >>> +    import configparser
>>>>>>>>>> >>> +except:
>>>>>>>>>> >>> +    import ConfigParser as configparser
>>>>>>>>>> >>> +class summary:
>>>>>>>>>> >>> +    def __init__(self, p_summary_dir):
>>>>>>>>>> >>> +        self.summary_file_path = path.join(p_summary_dir,
>>>>>>>>>> 'summary.txt')
>>>>>>>>>> >>> +        self.index_file_path = path.join(p_summary_dir,
>>>>>>>>>> 'index.html')
>>>>>>>>>> >>> +        self.bytes_analyzed = 0
>>>>>>>>>> >>> +        self.bytes_not_executed = 0
>>>>>>>>>> >>> +        self.percentage_executed = 0.0
>>>>>>>>>> >>> +        self.percentage_not_executed = 100.0
>>>>>>>>>> >>> +        self.ranges_uncovered = 0
>>>>>>>>>> >>> +        self.branches_uncovered = 0
>>>>>>>>>> >>> +        self.branches_total = 0
>>>>>>>>>> >>> +        self.branches_always_taken = 0
>>>>>>>>>> >>> +        self.branches_never_taken = 0
>>>>>>>>>> >>> +        self.percentage_branches_covered = 0.0
>>>>>>>>>> >>> +        self.is_failure = False
>>>>>>>>>> >>> +    def parse(self):
>>>>>>>>>> >>> +        if(not path.exists(self.summary_file_path)):
>>>>>>>>>> >>> +            log.notice('summary file %s does not exist!' %
>>>>>>>>>> >>> +            self.is_failure = True
>>>>>>>>>> >>> +            return
>>>>>>>>>> >>> +        with open(self.summary_file_path,'r') as
>>>>>>>>>> summary_file:
>>>>>>>>>> self._get_next_with_colon(summary_file)
>>>>>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>>>>>> >>> +        if len(self.branches_uncovered) > 0 and
>>>>>>>>>> len(self.branches_total)
>>>>>>>>>> >>> > 0:
>>>>>>>>>> >>> +            self.percentage_branches_covered = \
>>>>>>>>>> >>> +            1 - (float(self.branches_uncovered) /
>>>>>>>>>> >>> float(self.branches_total))
>>>>>>>>>> >>> +        else:
>>>>>>>>>> >>> +        return
>>>>>>>>>> >>> +    def _get_next_with_colon(self, summary_file):
>>>>>>>>>> >>> +        line = summary_file.readline()
>>>>>>>>>> >>> +        if ':' in line:
>>>>>>>>>> >>> +            return line.split(':')[1].strip()
>>>>>>>>>> >>> +        else:
>>>>>>>>>> >>> +            return ''
>>>>>>>>>> >>> +    def _get_next_without_colon(self, summary_file):
>>>>>>>>>> >>> +        return line.strip().split(' ')[0]
>>>>>>>>>> >>> +class report_gen_html:
>>>>>>>>>> >>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>>>>>>>> >>> +        self.symbol_sets_list = ['score']
>>>>>>>>>> >>> +        self.build_dir = build_dir
>>>>>>>>>> >>> +        self.partial_reports_files = list(["index.html",
>>>>>>>>>> "summary.txt"])
>>>>>>>>>> >>> +        self.number_of_columns = 1
>>>>>>>>>> >>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>>>>>> >>> +    def _find_partial_reports(self):
>>>>>>>>>> >>> +        partial_reports = {}
>>>>>>>>>> >>> +        for symbol_set in self.symbol_sets_list:
>>>>>>>>>> >>> +            set_summary = summary(path.join(self.build_dir,
>>>>>>>>>> "coverage",
>>>>>>>>>> >>> +                                  symbol_set))
>>>>>>>>>> >>> +            set_summary.parse()
>>>>>>>>>> >>> +            partial_reports[symbol_set] = set_summary
>>>>>>>>>> >>> +        return partial_reports
>>>>>>>>>> >>> +    def _prepare_head_section(self):
>>>>>>>>>> >>> +        head_section = '''
>>>>>>>>>> >>> +        <head>
>>>>>>>>>> >>> +        <title>RTEMS coverage report</title>
>>>>>>>>>> >>> +        <style type="text/css">
>>>>>>>>>> >>> +            progress[value] {
>>>>>>>>>> >>> +              -webkit-appearance: none;
>>>>>>>>>> >>> +               appearance: none;
>>>>>>>>>> >>> +              width: 150px;
>>>>>>>>>> >>> +              height: 15px;
>>>>>>>>>> >>> +        </style>
>>>>>>>>>> >>> +        </head>'''
>>>>>>>>>> >>> +        return head_section
>>>>>>>>>> >>> +    def _prepare_index_content(self, partial_reports):
>>>>>>>>>> >>> +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>>>>>>>> >>> +        header += "<h3>Coverage reports by symbols
>>>>>>>>>> sets:</h3>"
>>>>>>>>>> >>> +        table = "<table>"
>>>>>>>>>> >>> +        table += self._header_row()
>>>>>>>>>> >>> +        for symbol_set in partial_reports:
>>>>>>>>>> >>> +            table += self._row(symbol_set,
>>>>>>>>>> partial_reports[symbol_set])
>>>>>>>>>> >>> +        table += "</table> </br>"
>>>>>>>>>> >>> +        timestamp = "Analysis performed on " +
>>>>>>>>>> datetime.now().ctime()
>>>>>>>>>> >>> +        return "<body>\n" + header + table + timestamp +
>>>>>>>>>> "\n</body>"
>>>>>>>>>> >>> +    def _row(self, symbol_set, summary):
>>>>>>>>>> >>> +        row = "<tr>"
>>>>>>>>>> >>> +        row += "<td>" + symbol_set + "</td>"
>>>>>>>>>> >>> +        if summary.is_failure:
>>>>>>>>>> >>> +            row += ' <td colspan="' +
>>>>>>>>>> str(self.number_of_columns-1) \
>>>>>>>>>> >>> +            + '" style="background-color:red">FAILURE</td>'
>>>>>>>>>> >>> +        else:
>>>>>>>>>> >>> +            row += " <td>" +
>>>>>>>>>> self._link(summary.index_file_path,"Index")
>>>>>>>>>> >>> +            + "</td>"
>>>>>>>>>> >>> +            row += " <td>" +
>>>>>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>>>>>> >>> +            + "</td>"
>>>>>>>>>> >>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>>>>>>> >>> +            row += " <td>" + summary.bytes_not_executed +
>>>>>>>>>> "</td>"
>>>>>>>>>> >>> +            row += " <td>" + summary.ranges_uncovered +
>>>>>>>>>> "</td>"
>>>>>>>>>> >>> +            row += " <td>" + summary.percentage_executed +
>>>>>>>>>> "%</td>"
>>>>>>>>>> >>> +            row += " <td>" + summary.percentage_not_executed
>>>>>>>>>> + "%</td>"
>>>>>>>>>> >>> +            row += ' <td><progress value="' +
>>>>>>>>>> >>> summary.percentage_executed \
>>>>>>>>>> >>> +            + '" max="100"></progress></td>'
>>>>>>>>>> >>> +            row += " <td>" + summary.branches_uncovered +
>>>>>>>>>> "</td>"
>>>>>>>>>> >>> +            row += " <td>" + summary.branches_total + "</td>"
>>>>>>>>>> >>> +            row += " <td> {:.3%}
>>>>>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>>>>>> >>> +            row += ' <td><progress value="{:.3}"
>>>>>>>>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>>>>>>>> >>> +            row += "</tr>\n"
>>>>>>>>>> >>> +        return row
>>>>>>>>>> >>> +    def _header_row(self):
>>>>>>>>>> >>> +        row = "<tr>"
>>>>>>>>>> >>> +        row += "<th> Symbols set name </th>"
>>>>>>>>>> >>> +        row += "<th> Index file </th>"
>>>>>>>>>> >>> +        row += "<th> Summary file </th>"
>>>>>>>>>> >>> +        row += "<th> Bytes analyzed </th>"
>>>>>>>>>> >>> +        row += "<th> Bytes not executed </th>"
>>>>>>>>>> >>> +        row += "<th> Uncovered ranges </th>"
>>>>>>>>>> >>> +        row += "<th> Percentage covered </th>"
>>>>>>>>>> >>> +        row += "<th> Percentage uncovered </th>"
>>>>>>>>>> >>> +        row += "<th> Instruction coverage </th>"
>>>>>>>>>> >>> +        row += "<th> Branches uncovered </th>"
>>>>>>>>>> >>> +        row += "<th> Branches total </th>"
>>>>>>>>>> >>> +        row += "<th> Branches covered percentage </th>"
>>>>>>>>>> >>> +        row += "<th> Branches coverage </th>"
>>>>>>>>>> >>> +        row += "</tr>\n"
>>>>>>>>>> >>> +        self.number_of_columns = row.count('<th>')
>>>>>>>>>> >>> +        return row
>>>>>>>>>> >>> +    def _link(self, address, text):
>>>>>>>>>> >>> +        return '<a href="' + address + '">' + text + '</a>'
>>>>>>>>>> >>> +    def _create_index_file(self, head_section, content):
>>>>>>>>>> >>> +        with
>>>>>>>>>> open(path.join(self.build_dir,"report.html"),'w') as f:
>>>>>>>>>> >>> +            f.write(head_section)
>>>>>>>>>> >>> +            f.write(content)
>>>>>>>>>> >>> +    def generate(self):
>>>>>>>>>> >>> +        partial_reports = self._find_partial_reports()
>>>>>>>>>> >>> +        head_section = self._prepare_head_section()
>>>>>>>>>> >>> +        index_content =
>>>>>>>>>> self._prepare_index_content(partial_reports)
>>>>>>>>>> >>> +        self._create_index_file(head_section,index_content)
>>>>>>>>>> >>> +    def add_covoar_src_path(self):
>>>>>>>>>> >>> +        table_js_path = path.join(self.covoar_src_path,
>>>>>>>>>> 'table.js')
>>>>>>>>>> >>> +        covoar_css_path = path.join(self.covoar_src_path,
>>>>>>>>>> 'covoar.css')
>>>>>>>>>> >>> +            symbol_set_dir = path.join(self.build_dir,
>>>>>>>>>> "coverage",
>>>>>>>>>> >>> symbol_set)
>>>>>>>>>> >>> +            html_files = os.listdir(symbol_set_dir)
>>>>>>>>>> >>> +            for html_file in html_files:
>>>>>>>>>> >>> +                html_file = path.join(symbol_set_dir,
>>>>>>>>>> html_file)
>>>>>>>>>> >>> +                if path.exists(html_file) and 'html' in
>>>>>>>>>> html_file:
>>>>>>>>>> >>> +                    with open(html_file, 'r') as f:
>>>>>>>>>> >>> +                        file_data = f.read()
>>>>>>>>>> >>> +                    file_data = file_data.replace('table.js',
>>>>>>>>>> >>> table_js_path)
>>>>>>>>>> >>> +                    file_data =
>>>>>>>>>> file_data.replace('covoar.css',
>>>>>>>>>> covoar_css_path)
>>>>>>>>>> >>> +                    with open(html_file, 'w') as f:
>>>>>>>>>> >>> +                        f.write(file_data)
>>>>>>>>>> >>> +class build_path_generator(object):
>>>>>>>>>> >>> +    Generates the build path from the path to executables
>>>>>>>>>> >>> +    def __init__(self, executables, target):
>>>>>>>>>> >>> +        self.executables = executables
>>>>>>>>>> >>> +        self.target = target
>>>>>>>>>> >>> +    def run(self):
>>>>>>>>>> >>> +        build_path = '/'
>>>>>>>>>> >>> +        Path = self.executables[0].split('/')
>>>>>>>>>> >>> +        for P in Path:
>>>>>>>>>> >>> +            if P == self.target:
>>>>>>>>>> >>> +                break;
>>>>>>>>>> >>> +            else:
>>>>>>>>>> >>> +                build_path = path.join(build_path, P)
>>>>>>>>>> >>> +        return build_path
>>>>>>>>>> >>> +class symbol_parser(object):
>>>>>>>>>> >>> +    Parse the symbol sets ini and create custom ini file for
>>>>>>>>>> covoar
>>>>>>>>>> >>> +    def __init__(self, symbol_config_path,
>>>>>>>>>> >>> +                 symbol_select_path, coverage_arg,
>>>>>>>>>> build_dir):
>>>>>>>>>> >>> +        self.symbol_select_file = symbol_select_path
>>>>>>>>>> >>> +        self.symbol_file = symbol_config_path
>>>>>>>>>> >>> +        self.symbol_sets = {}
>>>>>>>>>> >>> +        self.cov_arg = coverage_arg
>>>>>>>>>> >>> +        self.ssets = []
>>>>>>>>>> >>> +    def parse(self):
>>>>>>>>>> >>> +        config = configparser.ConfigParser()
>>>>>>>>>> >>> +        try:
>>>>>>>>>> >>> +            config.read(self.symbol_file)
>>>>>>>>>> >>> +            if self.cov_arg:
>>>>>>>>>> >>> +                self.ssets = self.cov_arg.split(',')
>>>>>>>>>> >>> +            else:
>>>>>>>>>> >>> +                self.ssets = config.get('symbol-sets',
>>>>>>>>>> >>> 'sets').split(',')
>>>>>>>>>> >>> +                self.ssets = [ sset.encode('utf-8') for sset
>>>>>>>>>> in
>>>>>>>>>> >>> self.ssets]
>>>>>>>>>> >>> +            for sset in self.ssets:
>>>>>>>>>> >>> +                lib = path.join(self.build_dir,
>>>>>>>>>> >>> +                                config.get('libraries',
>>>>>>>>>> sset))
>>>>>>>>>> >>> +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>>>>>>>> >>> +        except:
>>>>>>>>>> >>> +            raise error.general('Symbol set parsing failed')
>>>>>>>>>> >>> +    def _write_ini(self):
>>>>>>>>>> >>> +        try:
>>>>>>>>>> >>> +            sets = ', '.join(self.symbol_sets.keys())
>>>>>>>>>> >>> +            config.add_section('symbol-sets')
>>>>>>>>>> >>> +            config.set('symbol-sets', 'sets', sets)
>>>>>>>>>> >>> +            for key in self.symbol_sets.keys():
>>>>>>>>>> >>> +                config.add_section(key)
>>>>>>>>>> >>> +                config.set(key, 'libraries',
>>>>>>>>>> self.symbol_sets[key])
>>>>>>>>>> >>> +            with open(self.symbol_select_file, 'w') as conf:
>>>>>>>>>> >>> +                config.write(conf)
>>>>>>>>>> >>> +        except:
>>>>>>>>>> >>> +            raise error.general('write failed')
>>>>>>>>>> >>> +    def run(self):
>>>>>>>>>> >>> +        self.parse()
>>>>>>>>>> >>> +        self._write_ini()
>>>>>>>>>> >>> +class covoar(object):
>>>>>>>>>> >>> +    Covoar runner
>>>>>>>>>> >>> +    def __init__(self, base_result_dir, config_dir,
>>>>>>>>>> executables,
>>>>>>>>>> >>> explanations_txt):
>>>>>>>>>> >>> +        self.base_result_dir = base_result_dir
>>>>>>>>>> >>> +        self.config_dir = config_dir
>>>>>>>>>> >>> +        self.executables = ' '.join(executables)
>>>>>>>>>> >>> +        self.explanations_txt = explanations_txt
>>>>>>>>>> >>> +        self.project_name = 'RTEMS-5'
>>>>>>>>>> >>> +    def run(self, set_name, symbol_file):
>>>>>>>>>> >>> +        covoar_result_dir = path.join(self.base_result_dir,
>>>>>>>>>> set_name)
>>>>>>>>>> >>> +        if (not path.exists(covoar_result_dir)):
>>>>>>>>>> >>> +            path.mkdir(covoar_result_dir)
>>>>>>>>>> >>> +        if (not path.exists(symbol_file)):
>>>>>>>>>> >>> +            raise error.general('symbol set file: coverage
>>>>>>>>>> %s was not
>>>>>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>>>>>> >>> +        command = ('covoar -S ' + symbol_file
>>>>>>>>>> >>> +                  + ' -O ' + covoar_result_dir
>>>>>>>>>> >>> +                  + ' -E ' + self.explanations_txt
>>>>>>>>>> >>> +                  + ' -p ' + self.project_name + ' ' +
>>>>>>>>>> self.executables)
>>>>>>>>>> >>> +        log.notice('Running covoar for %s' % (set_name))
>>>>>>>>>> >>> +        print( 'covoar results directory:\n' +
>>>>>>>>>> covoar_result_dir )
>>>>>>>>>> >>> +        executor = execute.execute(verbose = True, output =
>>>>>>>>>> >>> self.output_handler)
>>>>>>>>>> >>> +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>>>>>>>> >>> +        if (exit_code[0] != 0):
>>>>>>>>>> >>> +            raise error.general('covoar failure exit code:
>>>>>>>>>> %d' %
>>>>>>>>>> >>> (exit_code[0]))
>>>>>>>>>> >>> +        log.notice('Coverage run for %s finished
>>>>>>>>>> successfully.' %
>>>>>>>>>> >>> (set_name))
>>>>>>>>>> log.notice('-----------------------------------------------')
>>>>>>>>>> >>> +    def output_handler(self, text):
>>>>>>>>>> >>> +        log.notice('%s' % (text))
>>>>>>>>>> >>> +class coverage_run(object):
>>>>>>>>>> >>> +    Coverage analysis support for rtems-test
>>>>>>>>>> >>> +    def __init__(self, p_macros, coverage_arg, target):
>>>>>>>>>> >>> +        Constructor
>>>>>>>>>> >>> +        self.macros = p_macros
>>>>>>>>>> >>> +        self.build_dir = self.macros['_cwd']
>>>>>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>>>>>> >>> +        self.test_dir = path.join(self.build_dir, 'coverage')
>>>>>>>>>> >>> +        if (not path.exists(self.test_dir)):
>>>>>>>>>> >>> +            path.mkdir(self.test_dir)
>>>>>>>>>> >>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>>>>>> >>> +        self.rtscripts =
>>>>>>>>>> self.macros.expand(self.macros['_rtscripts'])
>>>>>>>>>> >>> +        self.coverage_config_path = path.join(self.rtscripts,
>>>>>>>>>> >>> 'coverage')
>>>>>>>>>> >>> +        self.symbol_config_path =
>>>>>>>>>> path.join(self.coverage_config_path,
>>>>>>>>>> 'symbol-sets.ini')
>>>>>>>>>> >>> +        self.symbol_select_path =
>>>>>>>>>> 'symbol-select.ini')
>>>>>>>>>> >>> +        self.executables = None
>>>>>>>>>> >>> +        self.symbol_sets = []
>>>>>>>>>> >>> +        self.no_clean = int(self.macros['_no_clean'])
>>>>>>>>>> >>> +        self.report_format = self.macros['cov_report_format']
>>>>>>>>>> >>> +        self.coverage_arg = coverage_arg
>>>>>>>>>> >>> +    def run(self):
>>>>>>>>>> >>> +        try:
>>>>>>>>>> >>> +            if self.executables is None:
>>>>>>>>>> >>> +                raise error.general('no test executables
>>>>>>>>>> provided.')
>>>>>>>>>> >>> +            build_dir =
>>>>>>>>>> build_path_generator(self.executables,
>>>>>>>>>> >>> self.target).run()
>>>>>>>>>> >>> +            parser = symbol_parser(self.symbol_config_path,
>>>>>>>>>> >>> +                                   self.symbol_select_path,
>>>>>>>>>> >>> +                                   self.coverage_arg,
>>>>>>>>>> >>> +                                   build_dir)
>>>>>>>>>> >>> +            parser.run()
>>>>>>>>>> >>> +            covoar_runner = covoar(self.test_dir,
>>>>>>>>>> >>> +                                   self.executables,
>>>>>>>>>> >>> self.explanations_txt)
>>>>>>>>>> >>> +            covoar_runner.run('score',
>>>>>>>>>> self.symbol_select_path)
>>>>>>>>>> >>> +            self._generate_reports();
>>>>>>>>>> >>> +            self._summarize();
>>>>>>>>>> >>> +        finally:
>>>>>>>>>> >>> +            self._cleanup();
>>>>>>>>>> >>> +    def _generate_reports(self):
>>>>>>>>>> >>> +        log.notice('Generating reports')
>>>>>>>>>> >>> +        if self.report_format == 'html':
>>>>>>>>>> >>> +            report = report_gen_html(self.symbol_sets,
>>>>>>>>>> >>> +                                     self.build_dir,
>>>>>>>>>> >>> +                                     self.rtdir)
>>>>>>>>>> >>> +            report.generate()
>>>>>>>>>> >>> +            report.add_covoar_src_path()
>>>>>>>>>> >>> +    def _cleanup(self):
>>>>>>>>>> >>> +        if not self.no_clean:
>>>>>>>>>> >>> +            log.notice('***Cleaning tempfiles***')
>>>>>>>>>> >>> +            for exe in self.executables:
>>>>>>>>>> >>> +                trace_file = exe + '.cov'
>>>>>>>>>> >>> +                if path.exists(trace_file):
>>>>>>>>>> >>> +                    os.remove(trace_file)
>>>>>>>>>> >>> +    def _summarize(self):
>>>>>>>>>> >>> +        log.notice('Coverage analysis finished. You can find
>>>>>>>>>> results in
>>>>>>>>>> >>> %s' % (self.build_dir))
>>>>>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>>>>>> >>> --- a/tester/rt/test.py
>>>>>>>>>> >>> +++ b/tester/rt/test.py
>>>>>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>>>>> >>>  from rtemstoolkit import reraise
>>>>>>>>>> >>>  from rtemstoolkit import stacktraces
>>>>>>>>>> >>>  from rtemstoolkit import version
>>>>>>>>>> >>> +from rtemstoolkit import check
>>>>>>>>>> >>>  from . import bsps
>>>>>>>>>> >>>  from . import config
>>>>>>>>>> >>>  from . import console
>>>>>>>>>> >>>  from . import report
>>>>>>>>>> >>> +from . import coverage
>>>>>>>>>> >>>  class log_capture(object):
>>>>>>>>>> >>>      def __init__(self):
>>>>>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>>>>> >>>      def run(self):
>>>>>>>>>> >>>          self.thread = threading.Thread(target = self.runner,
>>>>>>>>>> >>> -                                       name = 'test[%s]' %
>>>>>>>>>> >>> path.basename(self.executable))
>>>>>>>>>> >>> +                            name = 'test[%s]' %
>>>>>>>>>> >>>          self.thread.start()
>>>>>>>>>> >>>      def is_alive(self):
>>>>>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>>>>>> >>>      for test in tests:
>>>>>>>>>> >>>          test.kill()
>>>>>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>>>>>> >>> +    coverage.executables = executables
>>>>>>>>>> >>> +    coverage.run()
>>>>>>>>>> >>>  def run(command_path = None):
>>>>>>>>>> >>>      import sys
>>>>>>>>>> >>>      tests = []
>>>>>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>>>>>> >>>      opts = None
>>>>>>>>>> >>>      default_exefilter = '*.exe'
>>>>>>>>>> >>>      try:
>>>>>>>>>> >>> -        optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>>>>>> tools',
>>>>>>>>>> >>> -                    '--rtems-bsp':   'The RTEMS BSP to run
>>>>>>>>>> the test on',
>>>>>>>>>> >>> -                    '--user-config': 'Path to your local user
>>>>>>>>>> >>> configuration INI file',
>>>>>>>>>> >>> -                    '--report-mode': 'Reporting modes,
>>>>>>>>>> failures
>>>>>>>>>> >>> (default),all,none',
>>>>>>>>>> >>> -                    '--list-bsps':   'List the supported
>>>>>>>>>> BSPs',
>>>>>>>>>> >>> -                    '--debug-trace': 'Debug trace based on
>>>>>>>>>> specific
>>>>>>>>>> >>> flags',
>>>>>>>>>> >>> -                    '--filter':      'Glob that executables
>>>>>>>>>> must match
>>>>>>>>>> >>> to run (default: ' +
>>>>>>>>>> >>> +        optargs = { '--rtems-tools':    'The path to the
>>>>>>>>>> RTEMS tools',
>>>>>>>>>> >>> +                    '--rtems-bsp':      'The RTEMS BSP to
>>>>>>>>>> run the test
>>>>>>>>>> >>> on',
>>>>>>>>>> >>> +                    '--user-config':    'Path to your local
>>>>>>>>>> user
>>>>>>>>>> >>> +                    '--report-mode':    'Reporting modes,
>>>>>>>>>> failures
>>>>>>>>>> >>> +                    '--list-bsps':      'List the supported
>>>>>>>>>> BSPs',
>>>>>>>>>> >>> +                    '--debug-trace':    'Debug trace based
>>>>>>>>>> on specific
>>>>>>>>>> >>> flags',
>>>>>>>>>> >>> +                    '--filter':         'Glob that
>>>>>>>>>> executables must
>>>>>>>>>> >>> match to run (default: ' +
>>>>>>>>>> >>>                                default_exefilter + ')',
>>>>>>>>>> >>> -                    '--stacktrace':  'Dump a stack trace on
>>>>>>>>>> a user
>>>>>>>>>> >>> termination (^C)' }
>>>>>>>>>> >>> +                    '--stacktrace':     'Dump a stack trace
>>>>>>>>>> on a user
>>>>>>>>>> >>> termination (^C)',
>>>>>>>>>> >>> +                    '--coverage':       'Perform coverage
>>>>>>>>>> analysis of
>>>>>>>>>> >>> test executables.'}
>>>>>>>>>> >>>          mailer.append_options(optargs)
>>>>>>>>>> >>>          opts = options.load(sys.argv,
>>>>>>>>>> >>>                              optargs = optargs,
>>>>>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>>>>>> >>>              raise error.general('RTEMS BSP not provided or
>>>>>>>>>> an invalid
>>>>>>>>>> >>> option')
>>>>>>>>>> >>>          bsp = config.load(bsp[1], opts)
>>>>>>>>>> >>>          bsp_config =
>>>>>>>>>> opts.defaults.expand(opts.defaults['tester'])
>>>>>>>>>> >>> +        coverage_enabled = opts.find_arg('--coverage')
>>>>>>>>>> >>> +        if coverage_enabled:
>>>>>>>>>> >>> +            if len(coverage_enabled) == 2:
>>>>>>>>>> >> Is this to check if sets have been provided to
>>>>>>>>>> --coverage=score,sapi, that
>>>>>>>>>> >> kind of thing? If so the variable name coverage_enabled
>>>>>>>>>> doesn't make sense
>>>>>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will
>>>>>>>>>> make more
>>>>>>>>>> >> sense for both cases.
>>>>>>>>>> > That's a good point.
>>>>>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>>>>>> > Because it's still checking whether the option is given or
>>>>>>>>>> > not. symbol_sets might create confusion.
>>>>>>>>>> > Will that be OK ?
>>>>>>>>>> That name might collide with your class object (coverage)?
>>>>>>>>> That's actually why I kept it as coverage_enabled.
>>>>>>>>> I think we can go for coverage_option (?)
>>>>>>>>>> >>> +                coverage_runner =
>>>>>>>>>> coverage.coverage_run(opts.defaults,
>>>>>>>>>> coverage_enabled[1],
>>>>>>>>>> opts.defaults['target'])
>>>>>>>>>> >>> +            else:
>>>>>>>>>> >>> +                coverage_runner =
>>>>>>>>>> >>> 0,
>>>>>>>>>> >>>          report_mode = opts.find_arg('--report-mode')
>>>>>>>>>> >>>          if report_mode:
>>>>>>>>>> >>>              if report_mode[1] != 'failures' and \
>>>>>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>>>>>> >>>                      reports.failures(),
>>>>>>>>>> >>>                      'Log', '===', ''] + output.get()
>>>>>>>>>> >>>              mail.send(to_addr, subject,
>>>>>>>>>> os.linesep.join(body))
>>>>>>>>>> >>> +            coverage_run(opts, coverage_runner, executables)
>>>>>>>>>> >>>      except error.general as gerr:
>>>>>>>>>> >>>          print(gerr)
>>>>>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>>>>>> >>>  # The Leon 3 QEMU BSP
>>>>>>>>>> >>> -[leon3-qemu]
>>>>>>>>>> >>> +[leon3-qemu-cov]
>>>>>>>>>> >>>  bsp               = leon3-qemu
>>>>>>>>>> >>>  arch              = sparc
>>>>>>>>>> >>> +target            = sparc-rtems5
>>>>>>>>>> >>>  tester            = %{_rtscripts}/qemu.cfg
>>>>>>>>>> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>>>>>>> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>> >>> index 0000000..a2ec7bc
>>>>>>>>>> >>> --- /dev/null
>>>>>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>>>>>> 'rtems-tools'.
>>>>>>>>>> without
>>>>>>>>>> conditions are
>>>>>>>>>> >>> met:
>>>>>>>>>> copyright
>>>>>>>>>> >>> notice,
>>>>>>>>>> copyright
>>>>>>>>>> >>> notice,
>>>>>>>>>> >>> documentation
>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>> >>> "AS IS"
>>>>>>>>>> LIMITED TO,
>>>>>>>>>> >>> THE
>>>>>>>>>> PARTICULAR
>>>>>>>>>> >>> PURPOSE
>>>>>>>>>> CONTRIBUTORS
>>>>>>>>>> >>> BE
>>>>>>>>>> EXEMPLARY, OR
>>>>>>>>>> PROCUREMENT OF
>>>>>>>>>> PROFITS; OR
>>>>>>>>>> >>> BUSINESS
>>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>>> >>> IN
>>>>>>>>>> OR
>>>>>>>>>> >>> OTHERWISE)
>>>>>>>>>> IF ADVISED OF
>>>>>>>>>> >>> THE
>>>>>>>>>> >>> +[symbol-sets]
>>>>>>>>>> >>> +sets = score,rtems
>>>>>>>>>> >>> +[libraries]
>>>>>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>>>>>> >>>  # Qemu common option patterns.
>>>>>>>>>> >>> -#%define qemu_opts_base   -no-reboot -monitor none -serial
>>>>>>>>>> stdio
>>>>>>>>>> >>> -nographic
>>>>>>>>>> >>> -%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>>>>> mon:stdio
>>>>>>>>>> >>> -nographic
>>>>>>>>>> >>> +%define qemu_opts_base   -no-reboot -monitor none -serial
>>>>>>>>>> stdio
>>>>>>>>>> >>> -nographic
>>>>>>>>>> >>> +#%define qemu_opts_base   -no-reboot -serial null -serial
>>>>>>>>>> mon:stdio
>>>>>>>>>> >>> -nographic
>>>>>>>>>> >>>  %define qemu_opts_no_net -net none
>>>>>>>>>> >>> 2.14.3
>>>>>>>>>> >>> _______________________________________________
>>>>>>>>>> >>> devel mailing list
>>>>>>>>>> >>> devel at rtems.org
>>>>>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>> > devel mailing list
>>>>>>>>>> > devel at rtems.org
>>>> devel mailing list
>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/4172b5fb/attachment-0002.html>
