[PATCH] User Manual Executable and Test documentation
Joel Sherrill
joel at rtems.org
Fri Nov 2 14:19:56 UTC 2018
Thank you for all this.
For the Ditaa and PlantUML, did you add some install advice and upstream
information for folks drawing?
On Fri, Nov 2, 2018 at 12:55 AM <chrisj at rtems.org> wrote:
> Hi,
> The following three patches update the User Manual. The first patch
> renames some of the top level heading to make them simpler so a
> collaped heading list is easier to read. The second patch adds
> support for PlantUML and Ditaa to waf. The options `--plantuml`
> images needs to be updated from the source. The 3rd patch is new
> sections, Executables and Testing. The Executables section talks
> about executables and executing RTEMS executables and Testing
> discusses the RTEMS Tester command and the configuration and
> set up to use that command.
> Note, there is a 4th patch which is the generated images which
> I have not sent for review.
> These patches can be reviewed as build doco at the following:
> https://ftp.rtems.org/pub/rtems/people/chrisj/rtems-test/docs/master/
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181102/1392f182/attachment.html>
