[PATCH] Coverage: add the style and js files to the symbol-set report directory
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Nov 4 18:14:37 UTC 2018
On Sun, 28 Oct 2018 at 21:54, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> I could run with copy_tree using this workaround
> diff --git a/rtemstoolkit/path.py b/rtemstoolkit/path.py
> index 760f4bd..df553b3 100644
> --- a/rtemstoolkit/path.py
> +++ b/rtemstoolkit/path.py
> @@ -191,10 +191,10 @@ def copy_tree(src, dst):
>      hsrc = host(src)
>      hdst = host(dst)
> -    if os.path.exists(src):
> +    if os.path.exists(src) and os.path.isdir(src):
>          names = os.listdir(src)
>      else:
> -        name = []
> +        names = []
>      if not os.path.isdir(dst):
>          os.makedirs(dst)
> But there's still an issue with the file permission as it uses
> copystat which
> copies the permission bits which is not required in this case.
> It requires a manual `rm` with root permission before rerunning the
> coverage.
>  ping :)
On Sun, 28 Oct 2018 at 16:31, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On Sun, 28 Oct 2018 at 15:46, Chris Johns <chrisj at rtems.org> wrote:
>>> On 28/10/18 8:33 pm, Vijay Kumar Banerjee wrote:
>>> > On Sun, 28 Oct 2018 at 09:00, Chris Johns <chrisj at rtems.org
>>> > <mailto:chrisj at rtems.org>> wrote:
>>> >     On 27/10/18 5:13 am, Vijay Kumar Banerjee wrote:
>>> >      >   tester/rt/coverage.py | 17 ++++-------------
>>> >      >   1 file changed, 4 insertions(+), 13 deletions(-)
>>> >      > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>> >      > index 978a8c4..4200dad 100644
>>> >      > --- a/tester/rt/coverage.py
>>> >      > +++ b/tester/rt/coverage.py
>>> >      > @@ -201,23 +201,14 @@ class report_gen_html:
>>> >      >           index_content =
>>> >     self._prepare_index_content(partial_reports)
>>> >      >           self._create_index_file(head_section,index_content)
>>> >      > -    def add_covoar_src_path(self):
>>> >      > +    def add_covoar_css(self):
>>> >      >           table_js_path = path.join(self.covoar_src_path,
>>> 'table.js')
>>> >      >           covoar_css_path = path.join(self.covoar_src_path,
>>> >     'covoar.css')
>>> >      >           for symbol_set in self.symbol_sets:
>>> >      >               symbol_set_dir = path.join(self.build_dir,
>>> >      >                                          self.bsp + '-coverage',
>>> >     symbol_set)
>>> >      > -            html_files = os.listdir(symbol_set_dir)
>>> >      > -            for html_file in html_files:
>>> >      > -                html_file = path.join(symbol_set_dir,
>>> html_file)
>>> >      > -                if path.exists(html_file) and 'html' in
>>> html_file:
>>> >      > -                    with open(html_file, 'r') as f:
>>> >      > -                        file_data = f.read()
>>> >      > -                    file_data = file_data.replace('table.js',
>>> >     table_js_path)
>>> >      > -                    file_data = file_data.replace('covoar.css',
>>> covoar_css_path)
>>> >      > -                    with open(html_file, 'w') as f:
>>> >      > -                        f.write(file_data)
>>> >      > +            shutil.copy(covoar_css_path, symbol_set_dir)
>>> >      > +            shutil.copy(table_js_path, symbol_set_dir)
>>> >     How portable are these calls?
>>> >     Please have a look at 'path.copy_tree' in the rtemstoolkit's
>>> path.py. I
>>> >     think you can use that call instead.
>>> > shutil is portable as it comes with python.
>>> It does not handle some issues on Windows.
>>> > i looked into the path.copy_tree
>>> > it uses shutil as well,
>>> It does but it handles some issues expose in the RSB over many years.
>> Understood.
>>> > but it requires the source-name to be a directory
>>> > wherefrom it will copy all the files to destination directory.
>>> It can be extended.
>> I'm getting a 'Not a directory' error as it uses listdir on the srcpath
>> and then iterates over the
>> files. Shall I write a path.copy for it ? with the WindowsError handling
>> similar to
>> copy_tree ?
>>> > Is there a reason that path.copy_tree has been used instead of
>>> > shutil.copytree ?
>>> > https://docs.python.org/2/library/shutil.html#shutil.copytree
>>> It can break on Windows.
>>> Please use the path module for all file operations to we can be
>>> portable. I think one call was pushed in the other patch which Joel
>>> merged that needs to be fixed.
>> Sorry about that. I didn't know that it breaks on Windows.
>> Can you please comment on the patch so that I can fix it?
>> I'll ping you there. :)
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181104/95f5b280/attachment.html>
