[PATCH] score: Optimize Objects_Information
Mon Nov 5 10:40:55 UTC 2018
Reduce structure internal padding.  Group members used by _Objects_Get()
together.  Reduce size of some members.
Format and simplify _Objects_Extend_information().
 cpukit/include/rtems/score/objectimpl.h    |  28 +++----
 cpukit/score/src/objectextendinformation.c | 116 +++++++++++++----------------
 2 files changed, 66 insertions(+), 78 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 1bef14b116..bf4d45df4a 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -120,36 +120,36 @@ typedef void ( *Objects_Thread_queue_Extract_callout )(
  *  manage each class of objects.
 typedef struct {
-  /** This field indicates the API of this object class. */
-  Objects_APIs      the_api;
-  /** This is the class of this object set. */
-  uint16_t          the_class;
   /** This is the minimum valid id of this object class. */
   Objects_Id        minimum_id;
   /** This is the maximum valid id of this object class. */
   Objects_Id        maximum_id;
+  /** This points to the table of local objects. */
+  Objects_Control **local_table;
   /** This is the maximum number of objects in this class. */
   Objects_Maximum   maximum;
+  /** This is the number of objects on the Inactive list. */
+  Objects_Maximum   inactive;
+  /** This is the number of objects in a block. */
+  Objects_Maximum   allocation_size;
+  /** This is the maximum length of names. */
+  uint16_t          name_length;
+  /** This field indicates the API of this object class. */
+  uint8_t           the_api;
+  /** This is the class of this object set. */
+  uint8_t           the_class;
   /** This is true if names are strings. */
   bool              is_string;
   /** This is the true if unlimited objects in this class. */
   bool              auto_extend;
-  /** This is the number of objects in a block. */
-  Objects_Maximum   allocation_size;
   /** This is the size in bytes of each object instance. */
   size_t            size;
-  /** This points to the table of local objects. */
-  Objects_Control **local_table;
   /** This is the chain of inactive control blocks. */
   Chain_Control     Inactive;
-  /** This is the number of objects on the Inactive list. */
-  Objects_Maximum   inactive;
   /** This is the number of inactive objects per block. */
-  uint32_t         *inactive_per_block;
+  Objects_Maximum  *inactive_per_block;
   /** This is a table to the chain of inactive object memory blocks. */
-  void            **object_blocks;
-  /** This is the maximum length of names. */
-  uint16_t          name_length;
+  Objects_Control **object_blocks;
   #if defined(RTEMS_MULTIPROCESSING)
     /** This is this object class' method called when extracting a thread. */
     Objects_Thread_queue_Extract_callout extract;
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index f4ac11be43..d2ee7fdf8b 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -51,8 +51,8 @@ void _Objects_Extend_information(
   uint32_t          minimum_index;
   uint32_t          index;
   uint32_t          maximum;
-  size_t            block_size;
-  void             *new_object_block;
+  size_t            object_block_size;
+  Objects_Control  *new_object_block;
   bool              do_extend;
   _Assert(
@@ -100,13 +100,13 @@ void _Objects_Extend_information(
    * Allocate the name table, and the objects and if it fails either return or
    * generate a fatal error depending on auto-extending being active.
-  block_size = information->allocation_size * information->size;
+  object_block_size = information->allocation_size * information->size;
   if ( information->auto_extend ) {
-    new_object_block = _Workspace_Allocate( block_size );
+    new_object_block = _Workspace_Allocate( object_block_size );
     if ( !new_object_block )
       return;
   } else {
-    new_object_block = _Workspace_Allocate_or_fatal_error( block_size );
+    new_object_block = _Workspace_Allocate_or_fatal_error( object_block_size );
@@ -114,13 +114,13 @@ void _Objects_Extend_information(
   if ( do_extend ) {
     ISR_lock_Context  lock_context;
     void             *old_tables;
+    size_t            table_size;
     uintptr_t         object_blocks_size;
-    uintptr_t         inactive_per_block_size;
+    uintptr_t         local_table_size;
      *  Growing the tables means allocating a new area, doing a copy and
@@ -129,58 +129,49 @@ void _Objects_Extend_information(
      *  If the maximum is minimum we do not have a table to copy. First
      *  time through.
-     *  The allocation has :
+     *  The allocation has:
-     *      void            *objects[block_count];
-     *      uint32_t         inactive_count[block_count];
-     *      Objects_Control *local_table[maximum];
+     *      Objects_Control *object_blocks[ block_count ];
+     *      Objects_Control *local_table[ maximum ];
+     *      Objects_Maximum  inactive_count[ block_count ];
      *  This is the order in memory. Watch changing the order. See the memcpy
      *  below.
-     *  Up the block count and maximum
+     *  Up the block count and maximum.
     block_count++;
-     *  Allocate the tables and break it up. The tables are:
-     *      1. object_blocks        : void*
-     *      2. inactive_per_blocks : uint32_t
-     *      3. local_table         : Objects_Name*
+     *  Allocate the tables and break it up.
-    object_blocks_size = (uintptr_t)_Addresses_Align_up(
-        (void*)(block_count * sizeof(void*)),
-        CPU_ALIGNMENT
-    inactive_per_block_size =
-        (uintptr_t)_Addresses_Align_up(
-            (void*)(block_count * sizeof(uint32_t)),
-            CPU_ALIGNMENT
-    block_size = object_blocks_size + inactive_per_block_size +
-        ((maximum + minimum_index) * sizeof(Objects_Control *));
+    object_blocks_size = block_count * sizeof( *object_blocks );
+    local_table_size = ( maximum + minimum_index ) * sizeof( *local_table );
+    table_size = object_blocks_size
+      + local_table_size
+      + block_count * sizeof( *inactive_per_block );
-      object_blocks = _Workspace_Allocate( block_size );
+      object_blocks = _Workspace_Allocate( table_size );
       if ( !object_blocks ) {
         _Workspace_Free( new_object_block );
         return;
     } else {
-      object_blocks = _Workspace_Allocate_or_fatal_error( block_size );
+      object_blocks = _Workspace_Allocate_or_fatal_error( table_size );
      *  Break the block into the various sections.
-    inactive_per_block = (uint32_t *) _Addresses_Add_offset(
-        object_blocks,
+    local_table = _Addresses_Add_offset(
+      object_blocks,
-    local_table = (Objects_Control **) _Addresses_Add_offset(
-        inactive_per_block,
+    inactive_per_block = _Addresses_Add_offset(
+      local_table,
+      local_table_size
@@ -190,23 +181,26 @@ void _Objects_Extend_information(
     block_count--;
     if ( information->maximum > minimum_index ) {
        *  Copy each section of the table over. This has to be performed as
        *  separate parts as size of each block has changed.
-      memcpy( object_blocks,
-              information->object_blocks,
-              block_count * sizeof(void*) );
-      memcpy( inactive_per_block,
-              information->inactive_per_block,
-              block_count * sizeof(uint32_t) );
-      memcpy( local_table,
-              information->local_table,
-              (information->maximum + minimum_index) * sizeof(Objects_Control *) );
+      memcpy(
+        object_blocks,
+        information->object_blocks,
+        block_count * sizeof( *object_blocks )
+      memcpy(
+        inactive_per_block,
+        information->inactive_per_block,
+      memcpy(
+        local_table,
+        information->local_table,
+        ( information->maximum + minimum_index ) * sizeof( *local_table )
     } else {
        *  Deal with the special case of the 0 to minimum_index
@@ -218,9 +212,6 @@ void _Objects_Extend_information(
      *  Initialise the new entries in the table.
-    object_blocks[block_count] = NULL;
-    inactive_per_block[block_count] = 0;
     for ( index = index_base ; index < index_end ; ++index ) {
       local_table[ index ] = NULL;
@@ -235,11 +226,11 @@ void _Objects_Extend_information(
     information->local_table = local_table;
     information->maximum = (Objects_Maximum) maximum;
     information->maximum_id = _Objects_Build_id(
-        information->the_api,
-        information->the_class,
-        _Objects_Local_node,
-        information->maximum
+      information->the_api,
+      information->the_class,
+      _Objects_Local_node,
+      information->maximum
     _ISR_lock_ISR_enable( &lock_context );
@@ -252,11 +243,13 @@ void _Objects_Extend_information(
    *  Assign the new object block to the object block table.
   information->object_blocks[ block ] = new_object_block;
+  information->inactive_per_block[ block ] = information->allocation_size;
+  information->inactive += information->allocation_size;
    *  Append to inactive chain.
-  the_object = information->object_blocks[ block ];
+  the_object = new_object_block;
     the_object->id = _Objects_Build_id(
@@ -268,11 +261,6 @@ void _Objects_Extend_information(
     _Chain_Initialize_node( &the_object->Node );
     _Chain_Append_unprotected( &information->Inactive, &the_object->Node );
-    the_object = (Objects_Control *)
-      ( (char *) the_object + information->size );
+    the_object = _Addresses_Add_offset( the_object, information->size );
-  information->inactive_per_block[ block ] = information->allocation_size;
-  information->inactive =
-    (Objects_Maximum)(information->inactive + information->allocation_size);
2.16.4
