[PATCH 1/3] spconfig02: New test program
Sebastian Huber
Tue Nov 6 12:37:11 UTC 2018
testsuites/sptests/Makefile.am | 9 ++
testsuites/sptests/configure.ac | 1 +
testsuites/sptests/spconfig02/init.c | 227 +++++++++++++++++++++++++++
testsuites/sptests/spconfig02/spconfig02.doc | 23 +++
testsuites/sptests/spconfig02/spconfig02.scn | 7 +
5 files changed, 267 insertions(+)
create mode 100644 testsuites/sptests/spconfig02/init.c
create mode 100644 testsuites/sptests/spconfig02/spconfig02.doc
create mode 100644 testsuites/sptests/spconfig02/spconfig02.scn
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 7a182430b0..80680dfe83 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -717,6 +717,15 @@ spconfig01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spconfig01) \
$(support_includes)
endif
+if TEST_spconfig02
+sp_tests += spconfig02
+sp_screens += spconfig02/spconfig02.scn
+sp_docs += spconfig02/spconfig02.doc
+spconfig02_SOURCES = spconfig02/init.c
+spconfig02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spconfig02) \
+ $(support_includes)
+endif
if TEST_spconsole01
sp_tests += spconsole01
sp_screens += spconsole01/spconsole01.scn
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 36b3a17ecd..e725b39067 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -118,6 +118,7 @@ RTEMS_TEST_CHECK([spchain])
RTEMS_TEST_CHECK([spclock_err01])
RTEMS_TEST_CHECK([spclock_err02])
RTEMS_TEST_CHECK([spconfig01])
+RTEMS_TEST_CHECK([spconfig02])
RTEMS_TEST_CHECK([spconsole01])
RTEMS_TEST_CHECK([spcontext01])
RTEMS_TEST_CHECK([spcoverage])
diff --git a/testsuites/sptests/spconfig02/init.c b/testsuites/sptests/spconfig02/init.c
new file mode 100644
index 0000000000..1bde941c74
--- /dev/null
+++ b/testsuites/sptests/spconfig02/init.c
@@ -0,0 +1,227 @@
+ * Copyright (c) 2018 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#define _GNU_SOURCE
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+const char rtems_test_name[] = "SPCONFIG 2";
+static const rtems_name name = rtems_build_name('N', 'A', 'M', 'E');
+static void test_barrier(void)
+ rtems_status_code sc;
+ rtems_id id;
+ sc = rtems_barrier_create(name, RTEMS_DEFAULT_ATTRIBUTES, 1, &id);
+ rtems_test_assert(sc == RTEMS_TOO_MANY);
+static void test_message_queue(void)
+ rtems_id id;
+ sc = rtems_message_queue_create(
+ name,
+ 1,
+ 1,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id
+static void test_partition(void)
+ rtems_id id;
+ long buf[32];
+ sc = rtems_partition_create(
+ name,
+ buf,
+ sizeof(buf),
+ sizeof(buf),
+ &id
+static void test_rate_monotonic(void)
+ rtems_id id;
+ sc = rtems_rate_monotonic_create(name, &id);
+static void test_region(void)
+ rtems_id id;
+ long buf[32];
+ sc = rtems_region_create(
+ name,
+ buf,
+ sizeof(buf),
+ 1,
+ &id
+static void test_semaphore(void)
+ rtems_id id;
+ sc = rtems_semaphore_create(
+ name,
+ 0,
+ 0,
+ &id
+static void test_task(void)
+ rtems_id id;
+ sc = rtems_task_create(
+ name,
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ &id
+static void test_timer(void)
+ rtems_id id;
+ sc = rtems_timer_create(name, &id);
+static void test_user_extensions(void)
+ rtems_id id;
+ rtems_extensions_table table;
+ memset(&table, 0, sizeof(table));
+ sc = rtems_extension_create(name, &table, &id);
+static void test_id_to_name(rtems_id api, rtems_id cls, rtems_id idx, bool *found)
+ rtems_id id;
+ rtems_name name_of_id;
+ id = rtems_build_id(api, cls, 1, idx);
+ sc = rtems_object_get_classic_name(id, &name_of_id);
+ if (sc == RTEMS_SUCCESSFUL) {
+ if (name_of_id == rtems_build_name('U', 'I', '1', ' ')) {
+ rtems_test_assert(id == rtems_task_self());
+ rtems_test_assert(!found[0]);
+ found[0] = true;
+ } else {
+ rtems_test_assert(name_of_id == rtems_build_name('I', 'D', 'L', 'E'));
+ rtems_test_assert(!found[1]);
+ found[1] = true;
+ } else {
+ rtems_test_assert(sc == RTEMS_INVALID_ID);
+static void test_some_id_to_name(void)
+ rtems_id api;
+ bool found[2];
+ found[0] = false;
+ found[1] = false;
+ for (api = 0; api < 8; ++api) {
+ rtems_id cls;
+ for (cls = 0; cls < 32; ++cls) {
+ test_id_to_name(api, cls, 0, found);
+ test_id_to_name(api, cls, 1, found);
+ test_id_to_name(api, cls, 2, found);
+ test_id_to_name(api, cls, 65535, found);
+ test_id_to_name(api, cls, 65536, found);
+ rtems_test_assert(found[0]);
+ rtems_test_assert(found[1]);
+static void Init(rtems_task_argument arg)
+ rtems_print_printer_printk(&rtems_test_printer);
+ TEST_BEGIN();
+ test_barrier();
+ test_message_queue();
+ test_partition();
+ test_rate_monotonic();
+ test_region();
+ test_semaphore();
+ test_task();
+ test_timer();
+ test_user_extensions();
+ test_some_id_to_name();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spconfig02/spconfig02.doc b/testsuites/sptests/spconfig02/spconfig02.doc
index 0000000000..0bad04f758
--- /dev/null
+++ b/testsuites/sptests/spconfig02/spconfig02.doc
@@ -0,0 +1,23 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spconfig02
+directives:
+ - rtems_barrier_create()
+ - rtems_extension_create()
+ - rtems_message_queue_create()
+ - rtems_object_get_classic_name()
+ - rtems_partition_create()
+ - rtems_rate_monotonic_create()
+ - rtems_region_create()
+ - rtems_semaphore_create()
+ - rtems_task_create()
+ - rtems_timer_create()
+concepts:
+ - Ensure that the creation of Classic API objects failes with the expected
+ status code in the default configuration.
+ - Ensure that only the expected objects are present in the default
+ configuration via rtems_object_get_classic_name().
diff --git a/testsuites/sptests/spconfig02/spconfig02.scn b/testsuites/sptests/spconfig02/spconfig02.scn
index 0000000000..39628a8de2
--- /dev/null
+++ b/testsuites/sptests/spconfig02/spconfig02.scn
@@ -0,0 +1,7 @@
+*** BEGIN OF TEST SPCONFIG 2 ***
+*** TEST VERSION: 5.0.0.5f0d0d2d272bebb13f63efe70cb186bbf7715a89
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD:
+*** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB 279e47eab88299b0123be5a1e4446fe4a9329a54, Newlib 08eab6396f678cf5e5968acaed0bae9fd129983b)
+*** END OF TEST SPCONFIG 2 ***
2.16.4
