[PATCH] score: Use RTEMS_DEPRECATED for deprecated types
Sebastian Huber
Wed Nov 7 13:28:30 UTC 2018
Update #3584.
cpukit/include/rtems/rtems/types.h | 6 +++---
cpukit/include/rtems/score/basedefs.h | 6 +++---
2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index 82c0edd3c3..806fa44eb6 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -47,21 +47,21 @@ extern "C" {
* @deprecated Use @c float instead.
-typedef single_precision rtems_single;
+typedef single_precision rtems_single RTEMS_DEPRECATED;
* @brief Double precision float type.
* @deprecated Use @c double instead.
-typedef double_precision rtems_double;
+typedef double_precision rtems_double RTEMS_DEPRECATED;
* @brief RTEMS boolean type.
* @deprecated Use @c bool instead
-typedef boolean rtems_boolean;
+typedef boolean rtems_boolean RTEMS_DEPRECATED;
#endif
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 0a2bf8dd17..5e425cedf0 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -460,9 +460,9 @@ extern void RTEMS_DEQUALIFY_types_not_compatible(void);
#ifndef ASM
#ifdef RTEMS_DEPRECATED_TYPES
- typedef bool boolean;
- typedef float single_precision;
- typedef double double_precision;
+ typedef bool boolean RTEMS_DEPRECATED;
+ typedef float single_precision RTEMS_DEPRECATED;
+ typedef double double_precision RTEMS_DEPRECATED;
#endif
2.16.4
