Counter vs Btimer for tmtests
Wed Nov 7 18:00:39 UTC 2018
----- Am 7. Nov 2018 um 18:13 schrieb joel joel at rtems.org:
> Hi
> Do these report the same units?
Not necessarily.
> If not, there are only *tmtests which use rtems/counter.h and thus would be
> reporting numbers with different units than the btimer.
You can convert the counter value to nanoseconds:
https://docs.rtems.org/doxygen/branches/master/group__ClassicCounter.html#ga3e50a042e60bfcafdff5dbd46cad8947
This is used by some tests for the XML output which can be used to plot some graphs:
https://git.rtems.org/rtems/tree/testsuites/tmtests/tmcontext01/tmcontext01.scn
https://git.rtems.org/rtems/tree/testsuites/tmtests/tmcontext01/plot.py
