Move *_Control types of API objects to separate header file
Thu Nov 8 06:22:33 UTC 2018
On 08/11/2018 05:36, Chris Johns wrote:
> On 08/11/2018 00:14, Sebastian Huber wrote:
>> the <rtems.h> header file still exposes a lot of implementation details via the
>> definition of the *_Control structures of the API objects. They are only
>> necessary for the application configuration. I would like to move them to
>> separate header files. Currently we have:
>> <rtems/rtems/XYZ.h>
>> <rtems/rtems/XYZimpl.h>
>> I need a new name for this header file. For example:
>> <rtems/rtems/XYZdata.h>
>> An example patch is attached. Comments?
>>   cpukit/include/rtems/confdefs.h          |   1 +
>>   cpukit/include/rtems/rtems/ratemon.h     | 111 +---------------------------
>>   cpukit/include/rtems/rtems/ratemondata.h | 123 +++++++++++++++++++++++++++++++
> This is the ratemon "control struct" so does `ratemonctrl.h` work?
It contains also Rate_monotonic_Statistics, but most of the time it is
just XYZ_Control.
> Which ever way you go please make sure it will work for all the cases you wish
> to change, for example these do not work `foodatadata.h`, or `fooctrlctrl.h`.
It would be:
rtems/posix/mqueuectrl.h
rtems/posix/psignalctrl.h
rtems/posix/semaphorectrl.h
rtems/posix/shmctrl.h
rtems/posix/timerctrl.h
rtems/rtems/asrctrl.h
rtems/rtems/attrctrl.h
rtems/rtems/barrierctrl.h
rtems/rtems/dpmemctrl.h
rtems/rtems/eventctrl.h
rtems/rtems/messagectrl.h
rtems/rtems/modesctrl.h
rtems/rtems/optionsctrl.h
rtems/rtems/partctrl.h
rtems/rtems/ratemonctrl.h
rtems/rtems/regionctrl.h
rtems/rtems/semctrl.h
rtems/rtems/signalctrl.h
rtems/rtems/statusctrl.h
rtems/rtems/tasksctrl.h
rtems/rtems/timerctrl.h
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
