arm/altera-cyclone-v doxygen patch
Thu Nov 8 06:42:09 UTC 2018
On 08/11/2018 04:52, Gedare Bloom wrote:
> Attached is a patch from GCI 2018 adding doxygen to the altera-cyclone-v.
> 6545323948244992_1541638792_0001-arm-altera-cyclone-v-Update-Doxygen-GCI-2018.patch
>  From f69a935ea34fb617cab4632830e60184fe380d30 Mon Sep 17 00:00:00 2001
> From: shashvatjain<shashvatjain2002 at gmail.com>
> Date: Thu, 8 Nov 2018 06:17:49 +0530
> Subject: [PATCH] arm/altera cyclone v: Update Doxygen (GCI 2018)
>   bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h |  9 ++++++++
>   bsps/arm/altera-cyclone-v/include/bsp.h       | 18 +++++++++++++++
>   bsps/arm/altera-cyclone-v/include/bsp/hwlib.h | 16 ++++++++++++++
>   .../arm/altera-cyclone-v/include/bsp/i2cdrv.h | 17 ++++++++++++++
>   bsps/arm/altera-cyclone-v/include/bsp/irq.h   | 22 ++++++++++++++++++-
>   5 files changed, 81 insertions(+), 1 deletion(-)
> diff --git a/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h b/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
> index 650974751e..529d19980f 100644
> --- a/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
> +++ b/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
> @@ -1,3 +1,12 @@
> + * @file
> + * @ingroup altera-cyclone-v_i2c
I think CamelCase is used in most places for Doxygen internal names.
> + * @brief Drivers for I2C
>    * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> diff --git a/bsps/arm/altera-cyclone-v/include/bsp.h b/bsps/arm/altera-cyclone-v/include/bsp.h
> index 860a15c5bf..92bc95531b 100644
> --- a/bsps/arm/altera-cyclone-v/include/bsp.h
> +++ b/bsps/arm/altera-cyclone-v/include/bsp.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @ingroup arm_altera-cyclone-v
> + * @brief Global BSP definitions.
>    * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
> @@ -50,3 +58,13 @@ extern "C" {
>   #endif /* ASM */
>   #endif /* LIBBSP_ARM_ALTERA_CYCLONE_V_BSP_H */
> + * @defgroup arm_altera-cyclone-v Altera Cyclone V Support
> + * @ingroup bsp_arm
> + * @brief Altera Cyclone V support package.
> diff --git a/bsps/arm/altera-cyclone-v/include/bsp/hwlib.h b/bsps/arm/altera-cyclone-v/include/bsp/hwlib.h
> index aba7e877c4..8aad5d7b32 100644
> --- a/bsps/arm/altera-cyclone-v/include/bsp/hwlib.h
> +++ b/bsps/arm/altera-cyclone-v/include/bsp/hwlib.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @ingroup altera-cyclone-v_hwlib
> + * @brief The type definition for status codes returned by the HWLIB.
>   * Copyright 2013 Altera Corporation. All Rights Reserved.
> @@ -48,6 +56,14 @@ extern "C"
>   #endif  /* __cplusplus */
> + * @defgroup altera-cyclone-v_hwlib Hwlib
>    * The type definition for status codes returned by the HWLIB.
> diff --git a/bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h b/bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h
> index 9a4411d637..114d8a6219 100644
> --- a/bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h
> +++ b/bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h
> @@ -1,3 +1,11 @@
> + * @file
> @@ -21,6 +29,15 @@
>   extern "C" {
> + * @defgroup altera-cyclone-v_i2c I2C Support
> + * @brief I2C Support
>   rtems_device_driver i2cdrv_initialize(
>     rtems_device_major_number major,
>     rtems_device_minor_number minor,
> diff --git a/bsps/arm/altera-cyclone-v/include/bsp/irq.h b/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> index c136500415..f7455af9b4 100644
> --- a/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> +++ b/bsps/arm/altera-cyclone-v/include/bsp/irq.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @ingroup altera-cyclone-v_interrupt
> + * @brief Interrupt definitions.
>    * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
> @@ -28,6 +36,18 @@
>   extern "C" {
> + * @defgroup altera-cyclone-v_interrupt Interrupt Support
> + * @ingroup bsp_interrupt
Does it work to place it into two groups?
> + * @brief Interrupt Support for Altera cyclone V
Cyclone
>   /* Use interrupt IDs as defined in alt_interrupt_common.h */
>   #define BSP_INTERRUPT_VECTOR_MIN ALT_INT_INTERRUPT_SGI0
>   #define BSP_INTERRUPT_VECTOR_MAX ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ
> @@ -38,4 +58,4 @@ extern "C" {
>   #endif /* ASM */
> -#endif /* LIBBSP_ARM_ALTERA_CYCLONE_V_IRQ_H */
> \ No newline at end of file
> +#endif /* LIBBSP_ARM_ALTERA_CYCLONE_V_IRQ_H */
> -- 2.17.1
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
