[PATCH 4/5] rtems: Deprecate rtems_thread_cpu_usage_t
Thu Nov 8 07:05:50 UTC 2018
The rtems_thread_cpu_usage_t typedef as no corresponding API.  It
violates the POSIX namespace.  A user can do nothing with it.
Close #3593.
 cpukit/include/rtems/rtems/ratemon.h | 8 ++++----
 cpukit/include/rtems/rtems/types.h   | 2 +-
 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/cpukit/include/rtems/rtems/ratemon.h b/cpukit/include/rtems/rtems/ratemon.h
index ca48a92983..eec5e48fea 100644
--- a/cpukit/include/rtems/rtems/ratemon.h
+++ b/cpukit/include/rtems/rtems/ratemon.h
@@ -120,11 +120,11 @@ typedef struct {
   uint32_t     missed_count;
   /** This field contains the least amount of CPU time used in a period. */
-  rtems_thread_cpu_usage_t             min_cpu_time;
+  struct timespec min_cpu_time;
   /** This field contains the highest amount of CPU time used in a period. */
-  rtems_thread_cpu_usage_t             max_cpu_time;
+  struct timespec max_cpu_time;
   /** This field contains the total amount of wall time used in a period. */
-  rtems_thread_cpu_usage_t             total_cpu_time;
+  struct timespec total_cpu_time;
   /** This field contains the least amount of wall time used in a period. */
   rtems_rate_monotonic_period_time_t   min_wall_time;
@@ -181,7 +181,7 @@ typedef struct {
    *  was last initiated.  If the period is expired or has not been initiated,
    *  then this field has no meaning.
-  rtems_thread_cpu_usage_t             executed_since_last_period;
+  struct timespec                      executed_since_last_period;
   /** This is the count of postponed jobs of this period. */
   uint32_t                             postponed_jobs_count;
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index d551fce213..bb98100ead 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -129,7 +129,7 @@ typedef Watchdog_Interval rtems_interval;
  * When using nanoseconds granularity timing, RTEMS may internally use a
  * variety of representations.
-typedef struct timespec rtems_thread_cpu_usage_t;
+typedef struct timespec rtems_thread_cpu_usage_t RTEMS_DEPRECATED;
  * @brief Data structure to manage and manipulate calendar
2.16.4
