[PATCH] 5: Update Newlib
Sebastian Huber
Thu Nov 8 13:12:24 UTC 2018
Fix v850 target issue related to the new -fdata-sections build.
Remove <machine/param.h> include from <sys/_cpuset.h>.
rtems/config/5/rtems-default.bset | 2 +-
rtems/config/5/rtems-epiphany.bset | 2 +-
rtems/config/5/rtems-m32c.bset | 2 +-
rtems/config/5/rtems-or1k.bset | 2 +-
rtems/config/5/rtems-riscv.bset | 2 +-
...ib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg | 10 ++++++
...ib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg | 20 ++++++++++++
...ib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg | 37 ++++++++++++++++++++++
9 files changed, 82 insertions(+), 5 deletions(-)
create mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
create mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
create mode 100644 rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
create mode 100644 rtems/config/tools/rtems-gcc-7.3.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
index bdd93e9..0fdd34d 100644
--- a/rtems/config/5/rtems-default.bset
+++ b/rtems/config/5/rtems-default.bset
@@ -18,6 +18,6 @@ devel/expat-2.1.0-1
tools/rtems-gdb-8.0.1-1
tools/rtems-binutils-2.31.1
-tools/rtems-gcc-7.3.0-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b
+tools/rtems-gcc-7.3.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f
tools/rtems-tools-5-1
tools/rtems-kernel-5
diff --git a/rtems/config/5/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
index a01a50d..eb39d8e 100644
--- a/rtems/config/5/rtems-epiphany.bset
+++ b/rtems/config/5/rtems-epiphany.bset
@@ -34,6 +34,6 @@
5/rtems-autotools
devel/expat-2.1.0-1
tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/5/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
index 646b2e2..e7ee926 100644
--- a/rtems/config/5/rtems-m32c.bset
+++ b/rtems/config/5/rtems-m32c.bset
@@ -41,6 +41,6 @@
5/rtems-autotools
devel/expat-2.1.0-1
-tools/rtems-gcc-4.8.3-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b
+tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f
diff --git a/rtems/config/5/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
index 47ec7da..87ccbfc 100644
--- a/rtems/config/5/rtems-or1k.bset
+++ b/rtems/config/5/rtems-or1k.bset
@@ -33,6 +33,6 @@
5/rtems-autotools
devel/expat-2.1.0-1
-tools/rtems-gcc-4.9.3-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b
+tools/rtems-gcc-4.9.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f
tools/rtems-gdb-7.11-2
diff --git a/rtems/config/5/rtems-riscv.bset b/rtems/config/5/rtems-riscv.bset
index f55d021..b8353b6 100644
--- a/rtems/config/5/rtems-riscv.bset
+++ b/rtems/config/5/rtems-riscv.bset
@@ -11,7 +11,7 @@
devel/expat-2.1.0-1
tools/rtems-binutils-906c6f2c54425f18eccb30e3ae54cbe620f0fe86
-tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-08eab6396f678cf5e5968acaed0bae9fd129983b
+tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f
tools/rtems-gdb-ce73f310150418a9a1625ab60a527d959096a9e2
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
new file mode 100644
index 0000000..b2618c6
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
@@ -0,0 +1,10 @@
+%define gcc_version 4.8.3
+%hash sha512 gcc-%{gcc_version}.tar.bz2 2b40d231e8445f9c1654137df509f09ce1187b475138ca7f648f710d922a1718f740b2d8a37c26e16b5e27900c60358be98229ae884a6f1f70e9df44ad24d02b
+%define newlib_version 2ab57ad59bc35dafffa69cd4da5e228971de069f
+%define newlib_external 1
+%define newlib_expand_name sourceware-mirror-newlib-cygwin-%{newlib_version}
+%source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
+%hash sha512 newlib-%{newlib_version}.tar.gz e8c33201fda8182151513c9f1a5bfc6198b33ec1c844f150751532f1a9ee00b2d5dd2de29ae315a7b9c397e43c83d82263839faad482044fde0345d14c19882f
+%include tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
index 0000000..e63b252
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
@@ -0,0 +1,10 @@
+%define gcc_version 4.9.3
+%hash sha512 gcc-%{gcc_version}.tar.bz2 9ac57377a6975fc7adac704ec81355262b9f537def6955576753b87715470a20ee6a2a3144a79cc8fcba3443f7b44c7337d79d704b522d053f54f79aa6b442df
+%include tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg b/rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
index 0000000..ebd78da
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc-62cab5089882f91865e9040672f7932ae8d09db1-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
@@ -0,0 +1,20 @@
+%include %{_configdir}/checks.cfg
+%include %{_configdir}/base.cfg
+%define gcc_version 62cab5089882f91865e9040672f7932ae8d09db1
+%define gcc_external 1
+%define gcc_expand_name gnu-mirror-gcc-%{gcc_version}
+%source set gcc --rsb-file=%{gcc_expand_name}.tar.gz https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/%{gcc_version}
+%hash sha512 %{gcc_expand_name}.tar.gz bae48539c8f45f1b8c1876838232b9048d33dd01b321f4159a8321328590c52b343f70559e1549d55cf9ab71fd82ebfda94c42027cbabe9634fe18a1da89b492
+%define with_threads 1
+%define with_plugin 0
+%define with_iconv 1
+%include %{_configdir}/gcc-9.cfg
diff --git a/rtems/config/tools/rtems-gcc-7.3.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg b/rtems/config/tools/rtems-gcc-7.3.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
index 0000000..238f5c7
--- /dev/null
+++ b/rtems/config/tools/rtems-gcc-7.3.0-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f.cfg
@@ -0,0 +1,37 @@
+# FreeBSD specific fix for MIPS
+%if %{_build_os} == freebsd || %{_build_os} == darwin
+ %patch add gcc --rsb-file=freebsd-libgcc-sed-fix.patch -p0 https://gcc.gnu.org/bugzilla/attachment.cgi?id=41380
+ %hash sha256 freebsd-libgcc-sed-fix.patch 8a11bd619c2e55466688e328da00b387d02395c1e8ff4a99225152387a1e60a4
+%endif
+%define gcc_version 7.3.0
+%hash sha512 gcc-%{gcc_version}.tar.xz ad41a7e4584e40e92cdf860bc0288500fbaf5dfb7e8c3fcabe9eba809c87bcfa85b46c19c19921b0cdf6d05483faede8287bb9ea120c0d1559449a70e602c8d4
+%define isl_version 0.16.1
+%hash sha512 isl-%{isl_version}.tar.bz2 c188667a84dc5bdddb4ab7c35f89c91bf15a8171f4fcaf41301cf285fb7328846d9a367c096012fec4cc69d244f0bc9e95d84c09ec097394cd4093076f2a041b
+%define mpfr_version 3.1.4
+%hash sha512 mpfr-%{mpfr_version}.tar.bz2 51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
+%define mpc_version 1.0.3
+%hash sha512 mpc-%{mpc_version}.tar.gz 0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
+%define gmp_version 6.1.0
+%hash sha512 gmp-%{gmp_version}.tar.bz2 3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
+%include %{_configdir}/gcc-7.2-1.cfg
2.16.4
