Status of m32c port?
Thu Nov 8 15:16:30 UTC 2018
On 08/11/2018 16:06, Joel Sherrill wrote:
> On Thu, Nov 8, 2018 at 8:59 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello,
>     I try to get rid of the proc_ptr type currently. What is the
>     status of
>     the m32c port? Are interrupts supported at all?
> Interrupts are not supported.
>     If not, then I suggest to remove this port right now. The tools are
>     already quite out dated.tools
> DJ Delorie was/is the tools port maintainer and he recently stepped down.
> I don't see the  tool situation getting better.
> I thought I filed a ticket heading the m32c down this path. But maybe I
> just sent an email to the list about it.
Yes, there was a discussion in January 2018:
https://lists.rtems.org/pipermail/users/2018-January/031991.html
No response from the user side. I was also under the impression that
this was a fully functional port. I will remove this architecture next
week if nobody objects.
https://devel.rtems.org/ticket/3599
> FYI the or1k is also using odd tools but a new port is about to get merged
> and I have worked with the lead on that to ensure RTEMS support is there.
> So we wait on the or1k and the tool issue will solve itself. We will
> just have
> to bump them when it gets merged.
Yes, we just have to update the RSB to use GCC 9 once it is upstream.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
