[PATCH] Remove m32c support
Sebastian Huber
Thu Nov 8 15:39:02 UTC 2018
Update #3599.
config/rtems-bsps-m32c.ini | 25 -------------------
config/rtems-bsps-tiers.ini | 3 +--
config/rtems-bsps.ini | 3 ---
tester/rtems/testing/bsps/m32csim-run.ini | 39 -----------------------------
tester/rtems/testing/bsps/m32csim.ini | 41 -------------------------------
5 files changed, 1 insertion(+), 110 deletions(-)
delete mode 100644 config/rtems-bsps-m32c.ini
delete mode 100644 tester/rtems/testing/bsps/m32csim-run.ini
delete mode 100644 tester/rtems/testing/bsps/m32csim.ini
diff --git a/config/rtems-bsps-m32c.ini b/config/rtems-bsps-m32c.ini
deleted file mode 100644
index 74c7569..0000000
--- a/config/rtems-bsps-m32c.ini
+++ /dev/null
@@ -1,25 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2017 Chris Johns (chrisj at rtems.org)
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-bsp-builder'.
-# Permission to use, copy, modify, and/or distribute this software for any
-# purpose with or without fee is hereby granted, provided that the above
-# copyright notice and this permission notice appear in all copies.
-# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
-# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
-# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
-# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
-# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
-# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
-# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
-# M32C Architecture
-[m32c]
-bsps = m32csim
-exclude = smp
diff --git a/config/rtems-bsps-tiers.ini b/config/rtems-bsps-tiers.ini
index 14c9c06..34d7143 100644
--- a/config/rtems-bsps-tiers.ini
+++ b/config/rtems-bsps-tiers.ini
@@ -36,7 +36,7 @@ bsps_powerpc = qoriq_e500
# Tier 3: no build errors, no tests run.
[tier-3]
-archs = arm, bfin, i386, lm32, m32c, m68k, mips, moxie,
+archs = arm, bfin, i386, lm32, m68k, mips, moxie,
nios2, or1k, powerpc, sh, sparc, sparc64, v850
bsps_arm = altcycv_devkit,
arm1136jfs, arm1136js, arm7tdmi, arm920, armcortexa9, atsamv,
@@ -65,7 +65,6 @@ bsps_arm = altcycv_devkit,
bsps_bfin = TLL6527M, bf537Stamp, eZKit533
bsps_i386 = pc386, pc486, pc586-sse, pc586, pcp4
bsps_lm32 = lm32_evr, lm32_evr_gdbsim, milkymist
-bsps_m32c = m32csim
bsps_m68k = av5282,
csb360,
gen68340, gen68360, gen68360_040,
diff --git a/config/rtems-bsps.ini b/config/rtems-bsps.ini
index bda2b98..bdbc7e2 100644
--- a/config/rtems-bsps.ini
+++ b/config/rtems-bsps.ini
@@ -65,7 +65,6 @@ archs = arm,
epiphany,
i386,
lm32,
- m32c,
m68k,
mips,
moxie,
@@ -81,7 +80,6 @@ bsps_bfin = ${bfin:bsps}
bsps_epiphany = ${epiphany:bsps}
bsps_i386 = ${i386:bsps}
bsps_lm32 = ${lm32:bsps}
-bsps_m32c = ${m32c:bsps}
bsps_m68k = ${m68k:bsps}
bsps_mips = ${mips:bsps}
bsps_moxie = ${moxie:bsps}
@@ -102,7 +100,6 @@ include = rtems-bsps-arm.ini,
rtems-bsps-epiphany.ini,
rtems-bsps-i386.ini,
rtems-bsps-lm32.ini,
- rtems-bsps-m32c.ini,
rtems-bsps-m68k.ini,
rtems-bsps-mips.ini,
rtems-bsps-moxie.ini,
diff --git a/tester/rtems/testing/bsps/m32csim-run.ini b/tester/rtems/testing/bsps/m32csim-run.ini
index e9189d0..0000000
--- a/tester/rtems/testing/bsps/m32csim-run.ini
+++ /dev/null
@@ -1,39 +0,0 @@
-# Copyright 2015 On-Line Applications Research Corporation (OAR).
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-# The m32csim BSP
-[m32csim-run]
-bsp = m32csim
-arch = m32c
-tester = %{_rtscripts}/run.cfg
-bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run
-bsp_run_opts = -a -nouartrx
diff --git a/tester/rtems/testing/bsps/m32csim.ini b/tester/rtems/testing/bsps/m32csim.ini
index e091086..0000000
--- a/tester/rtems/testing/bsps/m32csim.ini
+++ /dev/null
@@ -1,41 +0,0 @@
-# The m32csim BSP
-[m32csim]
-bsp = m32csim
-arch = m32c
-tester = %{_rtscripts}/gdb.cfg
-gdb_script = bsp_gdb_script
-bsp_gdb_script = target sim
- load
- run
2.16.4
