Status of m32c port?
Thu Nov 8 15:57:09 UTC 2018
On 08/11/2018 16:16, Sebastian Huber wrote:
> On 08/11/2018 16:06, Joel Sherrill wrote:
>> On Thu, Nov 8, 2018 at 8:59 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     Hello,
>>     I try to get rid of the proc_ptr type currently. What is the
>>     status of
>>     the m32c port? Are interrupts supported at all?
>> Interrupts are not supported.
>>     If not, then I suggest to remove this port right now. The tools are
>>     already quite out dated.tools
>> DJ Delorie was/is the tools port maintainer and he recently stepped
>> down.
>> I don't see the  tool situation getting better.
>> I thought I filed a ticket heading the m32c down this path. But maybe I
>> just sent an email to the list about it.
> Yes, there was a discussion in January 2018:
> https://lists.rtems.org/pipermail/users/2018-January/031991.html
> No response from the user side. I was also under the impression that
> this was a fully functional port. I will remove this architecture next
> week if nobody objects.
> https://devel.rtems.org/ticket/3599
Should we remove the RTEMS support for m32c also from upstream GCC,
Binutils, Newlib and GDB?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
