[PATCH] tester: Support testing all riscv bsps on Spike
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Thu Nov 8 20:43:59 UTC 2018
tester/rtems/testing/bsps/rv32i_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv32iac_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv32im_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv32imac_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv32imafc_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv32imafd_spike.ini | 38 +++++++++++++++++++
.../rtems/testing/bsps/rv32imafdc_spike.ini | 38 +++++++++++++++++++
.../testing/bsps/rv64imac_medany_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv64imac_spike.ini | 38 +++++++++++++++++++
.../testing/bsps/rv64imafd_medany_spike.ini | 38 +++++++++++++++++++
tester/rtems/testing/bsps/rv64imafd_spike.ini | 38 +++++++++++++++++++
.../testing/bsps/rv64imafdc_medany_spike.ini | 38 +++++++++++++++++++
.../rtems/testing/bsps/rv64imafdc_spike.ini | 38 +++++++++++++++++++
13 files changed, 494 insertions(+)
create mode 100644 tester/rtems/testing/bsps/rv32i_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv32iac_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv32im_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv32imac_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv32imafc_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv32imafd_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv32imafdc_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv64imac_medany_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv64imac_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv64imafd_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
create mode 100644 tester/rtems/testing/bsps/rv64imafdc_spike.ini
diff --git a/tester/rtems/testing/bsps/rv32i_spike.ini b/tester/rtems/testing/bsps/rv32i_spike.ini
new file mode 100644
index 0000000..e59434c
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32i_spike.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The Generic RISC-V BSP
+[rv32i_spike]
+bsp = rv32i
+arch = riscv32
+tester = %{_rtscripts}/spike.cfg
+bsp_spike_opts = --isa=RV32I
diff --git a/tester/rtems/testing/bsps/rv32iac_spike.ini b/tester/rtems/testing/bsps/rv32iac_spike.ini
index 0000000..cde1528
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32iac_spike.ini
@@ -0,0 +1,38 @@
+[rv32iac_spike]
+bsp = rv32iac
+arch = riscv32
+bsp_spike_opts = --isa=RV32IAC
diff --git a/tester/rtems/testing/bsps/rv32im_spike.ini b/tester/rtems/testing/bsps/rv32im_spike.ini
index 0000000..47d8313
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32im_spike.ini
@@ -0,0 +1,38 @@
+[rv32im_spike]
+bsp = rv32im
+arch = riscv32
+bsp_spike_opts = --isa=RV32IM
diff --git a/tester/rtems/testing/bsps/rv32imac_spike.ini b/tester/rtems/testing/bsps/rv32imac_spike.ini
index 0000000..9b07862
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32imac_spike.ini
@@ -0,0 +1,38 @@
+[rv32imac_spike]
+bsp = rv32imac
+arch = riscv32
+bsp_spike_opts = --isa=RV32IMAC
diff --git a/tester/rtems/testing/bsps/rv32imafc_spike.ini b/tester/rtems/testing/bsps/rv32imafc_spike.ini
index 0000000..52d2782
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32imafc_spike.ini
@@ -0,0 +1,38 @@
+[rv32imafc_spike]
+bsp = rv32imafc
+arch = riscv32
+bsp_spike_opts = --isa=RV32IMAFC
diff --git a/tester/rtems/testing/bsps/rv32imafd_spike.ini b/tester/rtems/testing/bsps/rv32imafd_spike.ini
index 0000000..592e249
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32imafd_spike.ini
@@ -0,0 +1,38 @@
+[rv32imafd_spike]
+bsp = rv32imafd
+arch = riscv32
+bsp_spike_opts = --isa=RV32IMAFD
diff --git a/tester/rtems/testing/bsps/rv32imafdc_spike.ini b/tester/rtems/testing/bsps/rv32imafdc_spike.ini
index 0000000..42ffa94
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv32imafdc_spike.ini
@@ -0,0 +1,38 @@
+[rv32imafdc_spike]
+bsp = rv32imafdc
+arch = riscv32
+bsp_spike_opts = --isa=RV32IMAFDC
diff --git a/tester/rtems/testing/bsps/rv64imac_medany_spike.ini b/tester/rtems/testing/bsps/rv64imac_medany_spike.ini
index 0000000..1d9a522
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv64imac_medany_spike.ini
@@ -0,0 +1,38 @@
+[rv64imac_medany_spike]
+bsp = rv64imac
+arch = riscv64
+bsp_spike_opts = --isa=RV64IMAC
diff --git a/tester/rtems/testing/bsps/rv64imac_spike.ini b/tester/rtems/testing/bsps/rv64imac_spike.ini
index 0000000..b2a35fd
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv64imac_spike.ini
@@ -0,0 +1,38 @@
+[rv64imac_spike]
+bsp = rv64imac
+arch = riscv64
+bsp_spike_opts = --isa=RV64IMAC -m0x70000000:0x10000000
diff --git a/tester/rtems/testing/bsps/rv64imafd_medany_spike.ini b/tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
index 0000000..9348131
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
@@ -0,0 +1,38 @@
+[rv64imafd_medany_spike]
+bsp = rv64imafd
+arch = riscv64
+bsp_spike_opts = --isa=RV64IMAFD
diff --git a/tester/rtems/testing/bsps/rv64imafd_spike.ini b/tester/rtems/testing/bsps/rv64imafd_spike.ini
index 0000000..74336aa
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv64imafd_spike.ini
@@ -0,0 +1,38 @@
+[rv64imafd_spike]
+bsp = rv64imafd
+arch = riscv64
+bsp_spike_opts = --isa=RV64IMAFD -m0x70000000:0x10000000
diff --git a/tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini b/tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
index 0000000..b691a60
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
@@ -0,0 +1,38 @@
+[rv64imafdc_medany_spike]
+bsp = rv64imafdc_medany
+arch = riscv64
+bsp_spike_opts = --isa=RV64IMAFDC
diff --git a/tester/rtems/testing/bsps/rv64imafdc_spike.ini b/tester/rtems/testing/bsps/rv64imafdc_spike.ini
index 0000000..b72b471
--- /dev/null
+++ b/tester/rtems/testing/bsps/rv64imafdc_spike.ini
@@ -0,0 +1,38 @@
+[rv64imafdc_spike]
+bsp = rv64imafdc
+arch = riscv64
+bsp_spike_opts = --isa=RV64IMAFDC -m0x70000000:0x10000000
2.17.1
