[PATCH] tester: Support testing all riscv bsps on Spike
Thu Nov 8 23:01:03 UTC 2018
On 09/11/2018 07:43, Hesham Almatary wrote:
>  tester/rtems/testing/bsps/rv32i_spike.ini     | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv32iac_spike.ini   | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv32im_spike.ini    | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv32imac_spike.ini  | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv32imafc_spike.ini | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv32imafd_spike.ini | 38 +++++++++++++++++++
>  .../rtems/testing/bsps/rv32imafdc_spike.ini   | 38 +++++++++++++++++++
>  .../testing/bsps/rv64imac_medany_spike.ini    | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv64imac_spike.ini  | 38 +++++++++++++++++++
>  .../testing/bsps/rv64imafd_medany_spike.ini   | 38 +++++++++++++++++++
>  tester/rtems/testing/bsps/rv64imafd_spike.ini | 38 +++++++++++++++++++
>  .../testing/bsps/rv64imafdc_medany_spike.ini  | 38 +++++++++++++++++++
>  .../rtems/testing/bsps/rv64imafdc_spike.ini   | 38 +++++++++++++++++++
>  13 files changed, 494 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/rv32i_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32iac_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32im_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32imac_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32imafc_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32imafd_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv32imafdc_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv64imac_medany_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv64imac_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv64imafd_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
>  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_spike.ini
Looks good. OK to push.
