[PATCH] tester: Support testing all riscv bsps on Spike
Hesham Almatary heshamelmatary at gmail.com
Fri Nov 9 09:58:08 UTC 2018
On Thu, 8 Nov 2018 at 23:05, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Nov 8, 2018 at 5:01 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 09/11/2018 07:43, Hesham Almatary wrote:
>> >  tester/rtems/testing/bsps/rv32i_spike.ini     | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv32iac_spike.ini   | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv32im_spike.ini    | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv32imac_spike.ini  | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv32imafc_spike.ini | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv32imafd_spike.ini | 38 +++++++++++++++++++
>> >  .../rtems/testing/bsps/rv32imafdc_spike.ini   | 38 +++++++++++++++++++
>> >  .../testing/bsps/rv64imac_medany_spike.ini    | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv64imac_spike.ini  | 38 +++++++++++++++++++
>> >  .../testing/bsps/rv64imafd_medany_spike.ini   | 38 +++++++++++++++++++
>> >  tester/rtems/testing/bsps/rv64imafd_spike.ini | 38 +++++++++++++++++++
>> >  .../testing/bsps/rv64imafdc_medany_spike.ini  | 38 +++++++++++++++++++
>> >  .../rtems/testing/bsps/rv64imafdc_spike.ini   | 38 +++++++++++++++++++
>> >  13 files changed, 494 insertions(+)
>> >  create mode 100644 tester/rtems/testing/bsps/rv32i_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv32iac_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv32im_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv32imac_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv32imafc_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv32imafd_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv32imafdc_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv64imac_medany_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv64imac_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv64imafd_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
>> >  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_spike.ini
>> Looks good. OK to push.
> Please push.
> Thank you.
> Out of curiosity, will qemu run all the variants also?
Yes, QEMU supports all RISC-V exntesions (IMAFDC).
> --joel
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
Hesham
