[PATCH 11/19] mips: Remove use of proc_ptr
Fri Nov 9 12:49:03 UTC 2018
Update #3585.
 cpukit/score/cpu/mips/include/rtems/score/cpu.h | 25 -------------------------
 1 file changed, 25 deletions(-)
diff --git a/cpukit/score/cpu/mips/include/rtems/score/cpu.h b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
index fbb519ed1d..6818fb49ec 100644
--- a/cpukit/score/cpu/mips/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/include/rtems/score/cpu.h
@@ -753,31 +753,6 @@ extern void mips_break( int error );
 void _CPU_Initialize(void);
- *  _CPU_ISR_install_raw_handler
- *  This routine installs a "raw" interrupt handler directly into the
- *  processor's vector table.
-void _CPU_ISR_install_raw_handler(
-  uint32_t    vector,
-  proc_ptr    new_handler,
-  proc_ptr   *old_handler
- *  _CPU_ISR_install_vector
- *  This routine installs an interrupt vector.
-void _CPU_ISR_install_vector(
-  uint32_t    vector,
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
2.16.4
