[PATCH 14/19] or1k: Remove use of proc_ptr
Fri Nov 9 12:49:06 UTC 2018
Update #3585.
 bsps/or1k/generic_or1k/clock/clockdrv.c         |  5 +--
 cpukit/score/cpu/or1k/cpu.c                     | 22 +++++--------
 cpukit/score/cpu/or1k/include/rtems/score/cpu.h | 41 ++++++++++---------------
 3 files changed, 25 insertions(+), 43 deletions(-)
diff --git a/bsps/or1k/generic_or1k/clock/clockdrv.c b/bsps/or1k/generic_or1k/clock/clockdrv.c
index e2a8e4db17..44365aa02c 100644
--- a/bsps/or1k/generic_or1k/clock/clockdrv.c
+++ b/bsps/or1k/generic_or1k/clock/clockdrv.c
@@ -33,9 +33,6 @@ static struct timecounter or1ksim_tc;
 /* CPU counter */
 static CPU_Counter_ticks cpu_counter_ticks;
-/* This prototype is added here to Avoid warnings */
-void Clock_isr(void *arg);
 static void generic_or1k_clock_at_tick(void)
   uint32_t TTMR;
@@ -56,7 +53,7 @@ static void generic_or1k_clock_at_tick(void)
   cpu_counter_ticks += TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT;
-static void generic_or1k_clock_handler_install(proc_ptr new_isr)
+static void generic_or1k_clock_handler_install(CPU_ISR_handler new_isr)
   rtems_status_code sc = RTEMS_SUCCESSFUL;
   _CPU_ISR_install_vector(OR1K_EXCEPTION_TICK_TIMER,
diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
index b4cbe00f9b..75abb2f3f0 100644
--- a/cpukit/score/cpu/or1k/cpu.c
+++ b/cpukit/score/cpu/or1k/cpu.c
@@ -69,22 +69,14 @@ uint32_t  _CPU_ISR_Get_level( void )
 void _CPU_ISR_install_raw_handler(
-  uint32_t   vector,
-  proc_ptr    new_handler,
-  proc_ptr   *old_handler
+  uint32_t             vector,
+  CPU_ISR_raw_handler  new_handler,
+  CPU_ISR_raw_handler *old_handler
-void _CPU_ISR_install_vector(
-  uint32_t    vector,
-   proc_ptr *table =
-     (proc_ptr *) bsp_start_vector_table_begin;
-   proc_ptr current_handler;
+   CPU_ISR_raw_handler *table =
+     (CPU_ISR_raw_handler *) bsp_start_vector_table_begin;
+   CPU_ISR_raw_handler current_handler;
    ISR_Level level;
@@ -94,7 +86,7 @@ void _CPU_ISR_install_vector(
   /* The current handler is now the old one */
   if (old_handler != NULL) {
-    *old_handler = (proc_ptr) current_handler;
+    *old_handler = current_handler;
   /* Write only if necessary to avoid writes to a maybe read-only memory */
diff --git a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
index 8d66ccf522..0d1566a0c9 100644
--- a/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/or1k/include/rtems/score/cpu.h
@@ -590,35 +590,28 @@ void _CPU_Initialize(
   void
- *  _CPU_ISR_install_raw_handler
- *  This routine installs a "raw" interrupt handler directly into the
- *  processor's vector table.
+typedef void ( *CPU_ISR_raw_handler )( uint32_t, CPU_Exception_frame * );
-  uint32_t    vector,
+  uint32_t             vector,
- *  _CPU_ISR_install_vector
- *  This routine installs an interrupt vector.
- *  NO_CPU Specific Information:
- *  XXX document implementation including references if appropriate
+typedef void ( *CPU_ISR_handler )( uint32_t );
-  uint32_t    vector,
+RTEMS_INLINE_ROUTINE void _CPU_ISR_install_vector(
+  uint32_t         vector,
+  CPU_ISR_handler  new_handler,
+  CPU_ISR_handler *old_handler
+  _CPU_ISR_install_raw_handler(
+    vector,
+    (CPU_ISR_raw_handler) new_handler,
+    (CPU_ISR_raw_handler *) old_handler
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
2.16.4
