[PATCH 06/19] epiphany: Remove use of proc_ptr
Fri Nov 9 12:48:58 UTC 2018
Update #3585.
 bsps/epiphany/epiphany_sim/btimer/btimer.c         |  3 +--
 cpukit/score/cpu/epiphany/cpu.c                    | 18 -------------
 .../score/cpu/epiphany/include/rtems/score/cpu.h   | 30 ----------------------
 3 files changed, 1 insertion(+), 50 deletions(-)
diff --git a/bsps/epiphany/epiphany_sim/btimer/btimer.c b/bsps/epiphany/epiphany_sim/btimer/btimer.c
index 5df9448e01..9cb8526822 100644
--- a/bsps/epiphany/epiphany_sim/btimer/btimer.c
+++ b/bsps/epiphany/epiphany_sim/btimer/btimer.c
@@ -56,8 +56,7 @@ void benchmark_timer_initialize( void )
   /* Install interrupt handler for timer 1 */
-  proc_ptr *table =
-    (proc_ptr *) bsp_start_vector_table_begin;
+  void (**table)(void) = (void (**)(void)) bsp_start_vector_table_begin;
   table[TIMER1] = benchmark_timer1_interrupt_handler;
diff --git a/cpukit/score/cpu/epiphany/cpu.c b/cpukit/score/cpu/epiphany/cpu.c
index 489576cfc7..d025d92a6e 100644
--- a/cpukit/score/cpu/epiphany/cpu.c
+++ b/cpukit/score/cpu/epiphany/cpu.c
@@ -65,24 +65,6 @@ uint32_t  _CPU_ISR_Get_level( void )
   return 0;
-void _CPU_ISR_install_raw_handler(
-  uint32_t   vector,
-  proc_ptr    new_handler,
-  proc_ptr   *old_handler
-  /* Do nothing */
-void _CPU_ISR_install_vector(
-  uint32_t    vector,
-  /* Do nothing */
 CPU_Counter_ticks _CPU_Counter_read( void )
   static CPU_Counter_ticks counter;
diff --git a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
index d5c046a1fa..fe42c1f80d 100644
--- a/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/epiphany/include/rtems/score/cpu.h
@@ -582,36 +582,6 @@ void _CPU_Initialize(
   void
- *  _CPU_ISR_install_raw_handler
- *  This routine installs a "raw" interrupt handler directly into the
- *  processor's vector table.
-  uint32_t    vector,
- *  _CPU_ISR_install_vector
- *  This routine installs an interrupt vector.
- *  NO_CPU Specific Information:
- *  XXX document implementation including references if appropriate
-  uint32_t    vector,
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
2.16.4
