[PATCH 16/19] sh: Remove use of proc_ptr
Fri Nov 9 12:49:08 UTC 2018
Update #3585.
 bsps/sh/gensh1/start/cpu_asm.c                |  3 --
 bsps/sh/gensh1/start/ispsh7032.c              |  4 +--
 bsps/sh/gensh2/start/cpu_asm.c                |  3 --
 bsps/sh/gensh2/start/ispsh7045.c              |  4 +--
 bsps/sh/gensh4/start/cpu_asm.c                |  3 --
 bsps/sh/shared/start/setvec.c                 |  2 +-
 bsps/sh/shsim/start/ispshgdb.c                |  4 +--
 cpukit/score/cpu/sh/cpu.c                     | 43 +++++++--------------------
 cpukit/score/cpu/sh/include/rtems/score/cpu.h | 27 +++++++----------
 9 files changed, 27 insertions(+), 66 deletions(-)
diff --git a/bsps/sh/gensh1/start/cpu_asm.c b/bsps/sh/gensh1/start/cpu_asm.c
index 57c5c11796..2556623c47 100644
--- a/bsps/sh/gensh1/start/cpu_asm.c
+++ b/bsps/sh/gensh1/start/cpu_asm.c
@@ -41,9 +41,6 @@
 #include <rtems/score/iosh7032.h>
 #include <rtems/score/sh_io.h>
-/* from cpu_isps.c */
-extern proc_ptr         _Hardware_isr_Table[];
 unsigned long *_old_stack_ptr;
 register unsigned long  *stack_ptr __asm__ ("r15");
diff --git a/bsps/sh/gensh1/start/ispsh7032.c b/bsps/sh/gensh1/start/ispsh7032.c
index 05ba2f1e90..9857b755ab 100644
--- a/bsps/sh/gensh1/start/ispsh7032.c
+++ b/bsps/sh/gensh1/start/ispsh7032.c
@@ -25,7 +25,7 @@
  *  http://www.rtems.org/license/LICENSE.
-#include <rtems/system.h>
+#include <rtems/score/cpu.h>
 #include <rtems/score/ispsh7032.h>
@@ -33,7 +33,7 @@
  * It has the same structure like the actual vector table (vectab)
-proc_ptr _Hardware_isr_Table[256]={
+CPU_ISR_raw_handler _Hardware_isr_Table[256]={
 _dummy_isp, _dummy_isp, _dummy_isp, _dummy_isp,
diff --git a/bsps/sh/gensh2/start/cpu_asm.c b/bsps/sh/gensh2/start/cpu_asm.c
index 7d6e09c4c4..479b771d73 100644
--- a/bsps/sh/gensh2/start/cpu_asm.c
+++ b/bsps/sh/gensh2/start/cpu_asm.c
@@ -39,9 +39,6 @@
 #include <rtems/score/iosh7045.h>
diff --git a/bsps/sh/gensh2/start/ispsh7045.c b/bsps/sh/gensh2/start/ispsh7045.c
index 4e6dabed3f..874d930ba1 100644
--- a/bsps/sh/gensh2/start/ispsh7045.c
+++ b/bsps/sh/gensh2/start/ispsh7045.c
@@ -37,7 +37,7 @@
  *	by the authors or by TGA Technologies.
  * This is a exception vector table
@@ -49,7 +49,7 @@
 /* SH-2 ISR Table */
 #include <rtems/score/ispsh7045.h>
 _dummy_isp, _dummy_isp, _dummy_isp, _dummy_isp,		/* PWRon Reset, Maual Reset,...*/
diff --git a/bsps/sh/gensh4/start/cpu_asm.c b/bsps/sh/gensh4/start/cpu_asm.c
index 7618db3e27..6b530fe8b7 100644
--- a/bsps/sh/gensh4/start/cpu_asm.c
+++ b/bsps/sh/gensh4/start/cpu_asm.c
@@ -39,9 +39,6 @@
 #include <rtems/score/sh4_regs.h>
diff --git a/bsps/sh/shared/start/setvec.c b/bsps/sh/shared/start/setvec.c
index c3f4071aea..5d11e64f72 100644
--- a/bsps/sh/shared/start/setvec.c
+++ b/bsps/sh/shared/start/setvec.c
@@ -48,7 +48,7 @@ sh_isr_entry set_vector(      		/* returns old vector */
   if ( type )
     rtems_interrupt_catch( handler, vector, (rtems_isr_entry *) &previous_isr );
   else {
-    _CPU_ISR_install_raw_handler( vector, handler, (proc_ptr*) &previous_isr );
+    _CPU_ISR_install_raw_handler( vector, handler, &previous_isr );
   return previous_isr;
diff --git a/bsps/sh/shsim/start/ispshgdb.c b/bsps/sh/shsim/start/ispshgdb.c
index 09843172d9..f69ea10955 100644
--- a/bsps/sh/shsim/start/ispshgdb.c
+++ b/bsps/sh/shsim/start/ispshgdb.c
@@ -27,7 +27,7 @@
  *  Modified to reflect dummy isp entries for GDB SH simulator by Joel.
@@ -37,7 +37,7 @@
 void _dummy_isp(uint32_t);
diff --git a/cpukit/score/cpu/sh/cpu.c b/cpukit/score/cpu/sh/cpu.c
index b1e8766ff0..9f8be46b93 100644
--- a/cpukit/score/cpu/sh/cpu.c
+++ b/cpukit/score/cpu/sh/cpu.c
@@ -37,11 +37,7 @@
 #include <rtems/score/sh.h>
 /* referenced in start.S */
-extern proc_ptr vectab[] ;
-proc_ptr vectab[256] ;
+CPU_ISR_raw_handler vectab[256] ;
 #if SH_HAS_FPU
 Context_Control_fp _CPU_Null_fp_context;
@@ -98,21 +94,18 @@ uint32_t   _CPU_ISR_Get_level( void )
   return ( _mask);
- *  _CPU_ISR_install_raw_handler
 void _CPU_ISR_install_raw_handler(
-  uint32_t    vector,
-  proc_ptr    new_handler,
-  proc_ptr   *old_handler
+  uint32_t             vector,
+  CPU_ISR_raw_handler  new_handler,
+  CPU_ISR_raw_handler *old_handler
    *  This is where we install the interrupt handler into the "raw" interrupt
    *  table used by the CPU to dispatch interrupt handlers.
-  volatile proc_ptr	*vbr ;
+  volatile CPU_ISR_raw_handler *vbr ;
 #if SH_PARANOID_ISR
   uint32_t  		level ;
@@ -131,30 +124,14 @@ void _CPU_ISR_install_raw_handler(
 #endif
- *  _CPU_ISR_install_vector
- *  This kernel routine installs the RTEMS handler for the
- *  specified vector.
- *  Input parameters:
- *    vector      - interrupt vector number
- *    old_handler - former ISR for this vector number
- *    new_handler - replacement ISR for this vector number
- *  Output parameters:  NONE
 void _CPU_ISR_install_vector(
-  uint32_t    vector,
+  uint32_t         vector,
+  CPU_ISR_handler  new_handler,
+  CPU_ISR_handler *old_handler
 #if defined(__sh1__) || defined(__sh2__)
-   proc_ptr ignored ;
+   CPU_ISR_raw_handler ignored ;
 #endif
    *old_handler = _ISR_Vector_table[ vector ];
diff --git a/cpukit/score/cpu/sh/include/rtems/score/cpu.h b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
index 61d8e56448..0d633b0c68 100644
--- a/cpukit/score/cpu/sh/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/include/rtems/score/cpu.h
@@ -546,29 +546,22 @@ void _CPU_Context_Initialize(
 void _CPU_Initialize(void);
- *  This routine installs a "raw" interrupt handler directly into the
- *  processor's vector table.
+typedef void ( *CPU_ISR_raw_handler )( void );
+extern CPU_ISR_raw_handler _Hardware_isr_Table[];
-  uint32_t    vector,
+  uint32_t             vector,
- *  This routine installs an interrupt vector.
+typedef void ( *CPU_ISR_handler )( uint32_t );
-  uint32_t    vector,
+  uint32_t         vector,
 void *_CPU_Thread_Idle_body( uintptr_t ignored );
2.16.4
