RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
Joel Sherrill
joel at rtems.org
Sat Nov 10 18:35:52 UTC 2018
On Sat, Nov 10, 2018, 1:31 PM Misra, Avinash <Avinash.Misra at jhuapl.edu
wrote:
> Hi Joel,
> Thanks for the speedy reply. It’s not that the Application Code isn’t
> compiling, it’s that there’s nothing being generated when I try to create a
> Hello World project. It just generates a blank directory.
Oh.. I have no idea and am actually at a college football game.
For some examples that might be good code starting points, look at the
examples-v2 repository. The code is good. Use Eclipse to build it.
Sounds like the person who wrote that plugin needs to update it
> Thanks,
> Avi
> *From:* Joel Sherrill <joel at rtems.org>
> *Sent:* Saturday, November 10, 2018 1:29 PM
> *To:* Misra, Avinash <Avinash.Misra at jhuapl.edu>
> *Cc:* rtems-devel at rtems.org <devel at rtems.org>
> *Subject:* Re: RTEMS Plugin Xilinx SDK Not Generating HelloWorld Template
> Someone else developed the plugin and I have no idea what's going on with
> it relative to Eclipse but if the RTEMS applicstion code generated from the
> template isn't compiling, post it and more people can help solve that.
> On Sat, Nov 10, 2018, 1:18 PM Misra, Avinash <Avinash.Misra at jhuapl.edu
> wrote:
> Hi,
> I’m trying to get the RTEMS Plugin installed into the Xilinx SDK. The SDK
> is running Eclipse 4.6
> I’ve followed the steps from the tutorial (
> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin)to get the Xilinx
> Plugin installed from the ftp website (
> http://ftp//ftp.rtems.org/pub/rtems/eclipse/updates/
> <http://ftp/ftp.rtems.org/pub/rtems/eclipse/updates/>).
> I’ve configured Eclipse to point to the RTEMS toolchain (Installed in
> C:/opt/rtems/5/bin) and the Xilinx Zynq BSP that I generated outside of
> Eclipse as well as my MinGW and MSYS install paths.
> The issue I’m having now is that when I go to create a RTEMS HelloWorld
> project (New Project à C Project à RTEMS Hello-World Project) using the
> RTEMS Toolchain it just generates a blank project folder when I click
> finish. If I click Next and go to the select configuration page I get the
> following error “*At least one configuration should be available. Project
> cannot be created.”*
> Any idea what might be going on? I added some screenshots to aide in
> troubleshooting. Let me know if these didn’t make it through and I can send
> some links instead.
> Thanks,
> Avi Misra
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181110/1197eca3/attachment-0001.html>
