Adding Benchmark test for the test case " mq_receive: not available: block"(GCI 2018)
Shashvat Jain
shashvatjain2002 at gmail.com
Mon Nov 12 04:56:32 UTC 2018
Thank you for the clarification. :)
On Mon, Nov 12, 2018 at 10:15 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Nov 11, 2018, 9:33 PM Shashvat Jain <shashvatjain2002 at gmail.com
> wrote:
>> hello ,
>> multiple test cases have been defined in a single test
>> https://git.rtems.org/rtems/tree/testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc
>> The task instructs me to add a new test , just for clarification , will
>> it be right to add the test case "mq_receive: not available: block" in
>> the same test?
> I don't think so. It would need to follow the same multiple task blocking
> pattern used by something a mutex or semaphore unavailable and block.
> Answering from my phone but task blocking and unblocking tests tend to
> have multiple threads and be standalone tests
> But if this case is missing, you found a legitimate one to add.
> --joel
>> thank you
>> --Shashvat
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181112/6acb7f37/attachment-0001.html>
