rtems-docs : Build failure
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Nov 12 06:30:14 UTC 2018
attached log here.
On Mon, 12 Nov 2018 at 11:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Mon, 12 Nov 2018 at 11:26, Chris Johns <chrisj at rtems.org> wrote:
>> On 12/11/2018 16:50, Vijay Kumar Banerjee wrote:
>> > I'm getting a waf failure, trying to build the documentation with
>> Fedora 28.
>> > pdfTex version --> pdfTeX 3.14159265-2.6-1.40.19 (TeX Live 2018)
>> > I'm pasting the error below.
>> I cannot tell which manual the build is failing. Can you see which manual?
>> User manual.
>> > Build failed
>> > Traceback (most recent call last):
>> > File
>> "/home/lunatic/development/rtems/docs/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Task.py",
>> > line 145, in process
>> > ret=self.run()
>> > File
>> "/home/lunatic/development/rtems/docs/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Tools/tex.py",
>> > line 216, in run
>> > self.call_latex()
>> > File
>> > line 231, in call_latex
>> > self.check_status('error when calling latex',self.texfun())
>> > File
>> > line 116, in check_status
>> > raise Errors.WafError('%r command exit status %r'%(msg,retcode))
>> > WafError: 'error when calling latex' command exit status 1
>> Is latex installed? Try:
>> $ type latex
>> latex is hashed (/usr/local/texlive/2018/bin/x86_64-linux/latex)
>> If this is OK there will be a latex log file in the manual's build
>> directory,
>> for example for the User manual it is build/user/latex/user.log and the
>> actual
>> error should be in it.
>> I only see "Undefined control sequence" errors. (attaching the log)
> I have the pdf generated though, but the waf gives this error.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181112/a2ebb370/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181112/a2ebb370/attachment-0001.bin>
