[PATCH] tester: Remove riscv_generic
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Mon Nov 12 10:29:25 UTC 2018
Now each BSP/ISA variant has its own .ini file
tester/rtems/testing/bsps/riscv64_generic.ini | 38 -------------
tester/rtems/testing/bsps/riscv_generic.ini | 38 -------------
tester/rtems/testing/bsps/riscv_generic.mc | 53 -------------------
3 files changed, 129 deletions(-)
delete mode 100644 tester/rtems/testing/bsps/riscv64_generic.ini
delete mode 100644 tester/rtems/testing/bsps/riscv_generic.ini
delete mode 100644 tester/rtems/testing/bsps/riscv_generic.mc
diff --git a/tester/rtems/testing/bsps/riscv64_generic.ini b/tester/rtems/testing/bsps/riscv64_generic.ini
deleted file mode 100644
index c596a3a..0000000
--- a/tester/rtems/testing/bsps/riscv64_generic.ini
+++ /dev/null
@@ -1,38 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-# The riscv64_generic BSP
-[riscv64_generic]
-bsp = riscv64_generic
-arch = riscv64
-tester = %{_rtscripts}/spike.cfg
-bsp_spike_opts = --isa=RV64IMAFDC -m0x10000000:0x10000000
diff --git a/tester/rtems/testing/bsps/riscv_generic.ini b/tester/rtems/testing/bsps/riscv_generic.ini
index 626b949..0000000
--- a/tester/rtems/testing/bsps/riscv_generic.ini
+++ /dev/null
@@ -1,38 +0,0 @@
-# The riscv_generic BSP
-[riscv_generic]
-bsp = riscv_generic
-arch = riscv32
-bsp_spike_opts = --isa=RV32IMAFDC -m0x10000000:0x10000000
diff --git a/tester/rtems/testing/bsps/riscv_generic.mc b/tester/rtems/testing/bsps/riscv_generic.mc
index daff7c0..0000000
--- a/tester/rtems/testing/bsps/riscv_generic.mc
+++ /dev/null
@@ -1,53 +0,0 @@
-# All paths in defaults must be Unix format. Do not store any Windows format
-# paths in the defaults.
-# Every entry must describe the type of checking a host must pass.
-# Records:
-# key: type, attribute, value
-# type : none, dir, exe, triplet
-# attribute: none, required, optional
-# value : 'single line', '''multi line'''
-[global]
-bsp: none, none, 'riscv_generic'
-[riscv_generic]
-riscv_generic: none, none, '%{_rtscripts}/spike.cfg'
-riscv_generic_arch: none, none, ''
-riscv_generic_opts: none, none, ''
2.17.1
